<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-OpenWeatherForecast showing incorrect weather for my location]]></title><description><![CDATA[<p dir="auto">Hello - I’ve been using MMM-OpenWeatherForecast successfully for a while, but noticed the temperature is significantly different from the actual temp in my location. I’ve used <a href="http://latlong.net" target="_blank" rel="noopener noreferrer nofollow ugc">latlong.net</a> to get the right Latitude and Longitude, but it’s still not right. When I navigate to <a href="http://openweathermap.org" target="_blank" rel="noopener noreferrer nofollow ugc">openweathermap.org</a>, I see the correct temperature for my location (New Jersey, USA).</p>
<p dir="auto">Any idea what could cause this? I don’t think the config allows anything other than lat/long to determine the location (e.g., no zip code, or location ID).</p>
]]></description><link>https://forum.magicmirror.builders/topic/19339/mmm-openweatherforecast-showing-incorrect-weather-for-my-location</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 11:08:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19339.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 16 Jan 2025 02:04:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-OpenWeatherForecast showing incorrect weather for my location on Thu, 23 Jan 2025 01:30:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Good suggestion… that worked.</p>
<p dir="auto">Next, I put back the original config and changed the lat/long from a number into a string which fixed it while using my original/customized config as well.</p>
<p dir="auto">Thanks for your help troubleshooting <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ! Much appreciated</p>
]]></description><link>https://forum.magicmirror.builders/post/123294</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123294</guid><dc:creator><![CDATA[kasperb]]></dc:creator><pubDate>Thu, 23 Jan 2025 01:30:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast showing incorrect weather for my location on Thu, 23 Jan 2025 01:36:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kasperb" aria-label="Profile: kasperb">@<bdi>kasperb</bdi></a> awesome!</p>
]]></description><link>https://forum.magicmirror.builders/post/123295</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123295</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 23 Jan 2025 01:36:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast showing incorrect weather for my location on Thu, 23 Jan 2025 01:30:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Good suggestion… that worked.</p>
]]></description><link>https://forum.magicmirror.builders/post/123294</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123294</guid><dc:creator><![CDATA[kasperb]]></dc:creator><pubDate>Thu, 23 Jan 2025 01:30:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast showing incorrect weather for my location on Thu, 23 Jan 2025 01:19:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kasperb" aria-label="Profile: kasperb">@<bdi>kasperb</bdi></a> and if you start w his example config and your lat/lon and apikey?</p>
]]></description><link>https://forum.magicmirror.builders/post/123293</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123293</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 23 Jan 2025 01:19:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast showing incorrect weather for my location on Thu, 23 Jan 2025 01:15:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Removed the URL, app is loading but the same issue:</p>
<ul>
<li>10F in the app</li>
<li>15F on <a href="http://OpenWeather.org" target="_blank" rel="noopener noreferrer nofollow ugc">OpenWeather.org</a></li>
</ul>
<p dir="auto">I even double-checked the lat/long, and aligned them (‘geo coords’) exactly with what’s listed for my location on the <a href="http://OpenWeather.org" target="_blank" rel="noopener noreferrer nofollow ugc">OpenWeather.org</a> site.</p>
]]></description><link>https://forum.magicmirror.builders/post/123292</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123292</guid><dc:creator><![CDATA[kasperb]]></dc:creator><pubDate>Thu, 23 Jan 2025 01:15:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast showing incorrect weather for my location on Thu, 23 Jan 2025 01:06:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kasperb" aria-label="Profile: kasperb">@<bdi>kasperb</bdi></a> if you don’t set the apiBaseURL, then the module uses what it has defined</p>
<p dir="auto">this is one of the critical pieces of data to get the api to work. the less you specify the less chance of that trouble</p>
]]></description><link>https://forum.magicmirror.builders/post/123290</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123290</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 23 Jan 2025 01:06:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast showing incorrect weather for my location on Thu, 23 Jan 2025 00:55:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Yes, I’m using the 3.0 apikey, backed by a CC. Can you clarify what you mean with removing the ApiBase property?</p>
<p dir="auto">I’m going to play around using some lat/long from neighboring towns and see if that could help.</p>
<p dir="auto">Also, thanks for the guidance on posting config &amp; log info.</p>
]]></description><link>https://forum.magicmirror.builders/post/123289</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123289</guid><dc:creator><![CDATA[kasperb]]></dc:creator><pubDate>Thu, 23 Jan 2025 00:55:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast showing incorrect weather for my location on Fri, 17 Jan 2025 14:23:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kasperb" aria-label="Profile: kasperb">@<bdi>kasperb</bdi></a> ok, his doc says</p>
<pre><code class="language-text">At a minimum you need to supply the following required configuration parameters:
apikey
latitude
longitude
apikey needs to be specified as a String, while latitude and longitude can be specified as either a String or a Number. Both work fine.
By default the module uses the OpenWeater One Call API in version 3.0 now cause version 2.5 has been shut down in June 2024. If you know what you are doing you can use the config option apiBaseURL to specify the URL you like.
<p dir="auto">SO, you don’t need the apiBase property</p>
<p dir="auto">and you DID get a new 3.0 apikey, (which is backed by a credit card), right?</p>
<p dir="auto">the old (2.5) apiKey will not work with the 3.0 /onecall endpoint</p>
<p dir="auto">also, for future… all config and log info in a code block please here on the forum</p>
<p dir="auto">to do</p>
<p dir="auto">paste text into editor, blank line above and below<br />
select text just pasted<br />
hit &lt;/&gt; button above editor</p>
<p dir="auto">the code block markers will be added… they MUST start a new line by themselves(why the blank line above/below)</p>
]]></description><link>https://forum.magicmirror.builders/post/123160</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123160</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 17 Jan 2025 14:23:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast showing incorrect weather for my location on Fri, 17 Jan 2025 14:17:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto"><strong>Here is the config:</strong></p>
<pre><code>{
    module: "MMM-OpenWeatherForecast",
    disabled: false,
    header: "",
      apikey: "_DELETED_", //SUPER SECRET
      latitude: &lt;RM FOR PRIVACY&gt;,
      longitude: &lt;RM FOR PRIVACY,
      units: "imperial",
      debug: true,
      apiBaseURL: "https://api.openweathermap.org/data/3.0/onecall?",
      iconset: "3m",
      colored: false,
      concise: true,
      requestDelay: "2000",
      showFeelsLikeTemp: true,
      showCurrentConditions: true,
      showSummary: true,
      showExtraCurrentConditions: true,
      extraCurrentConditions: {
        highLowTemp: true,
        precipitation: true,
        sunrise: false,
        sunset: false,
        wind: true,
        barometricPressure: false,
        humidity: true,
        dewPoint: false,
        uvIndex: true,
        visibility: false
      forecastLayout: "table",
      forecastHeaderText: "",
      hourlyForecastTableHeaderText: "Hourly",
      showHourlyForecast: true,
      showHourlyTableHeaderRow: true,
      hourlyForecastInterval: 3,
      maxHourliesToShow: 3,
      hourlyExtras: {
        wind: true,
        humidity: false,
        dewPoint: false,
        uvIndex: false,
        visibility: false
      dailyForecastTableHeaderText: "Weekly",
      showDailyForecast: true,
      showDailyTableHeaderRow: true,
      maxDailiesToShow: 5,
      dailyExtras: {
        sunrise: false,
        sunset: false,
        wind: true,
        humidity: false,
        dewPoint: false,
        uvIndex: false
<p dir="auto"><strong>This is the output of the command:</strong></p>
<p dir="auto">origin	<a href="https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast</a> (fetch)<br />
origin	<a href="https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast</a> (push)</p>
]]></description><link>https://forum.magicmirror.builders/post/123159</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123159</guid><dc:creator><![CDATA[kasperb]]></dc:creator><pubDate>Fri, 17 Jan 2025 14:17:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast showing incorrect weather for my location on Thu, 16 Jan 2025 20:16:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kasperb" aria-label="Profile: kasperb">@<bdi>kasperb</bdi></a> can you show the module config?</p>
<p dir="auto">which source for the module?<br />
in the module folder do</p>
<pre><code>git remote -v
]]></description><link>https://forum.magicmirror.builders/post/123132</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123132</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 16 Jan 2025 20:16:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast showing incorrect weather for my location on Thu, 16 Jan 2025 12:22:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hi - just regular numbers e.g,</p>
<p dir="auto">40.712776,<br />
-74.005974,</p>
]]></description><link>https://forum.magicmirror.builders/post/123131</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123131</guid><dc:creator><![CDATA[kasperb]]></dc:creator><pubDate>Thu, 16 Jan 2025 12:22:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast showing incorrect weather for my location on Thu, 16 Jan 2025 02:08:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kasperb" aria-label="Profile: kasperb">@<bdi>kasperb</bdi></a> did you out them in config as numbers or quoted strings?  need numbers</p>
]]></description><link>https://forum.magicmirror.builders/post/123128</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123128</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 16 Jan 2025 02:08:11 GMT</pubDate></item></channel></rss>
