<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar Recurring events on wrong day]]></title><description><![CDATA[<p dir="auto">I know that there have been several different threads about this over the years, but I have been unable to find something that describes the current state of displaying recurring events correctly.</p>
<p dir="auto">The Issue:<br />
Some recurring events (those later in the day) end up being displayed incorrectly.  A calendar item that was started on January 16th at 9pm (Thursday) will also display on January 17th at 9pm (Friday) and then repeat on Friday’s going forward.</p>
<p dir="auto">I have looked at several posts, including the following that recommended changing the node ics calendar version:<br />
<a href="https://forum.magicmirror.builders/topic/18388/default-calendar-module-not-showing-some-recurring-events">https://forum.magicmirror.builders/topic/18388/default-calendar-module-not-showing-some-recurring-events</a></p>
<p dir="auto">Is this still the preferred method of fixing this, or have other fixes been discussed?</p>
<p dir="auto">Setup:<br />
I currently am running MagicMirror using a docker image ( thanks to khassel at <a href="https://khassel.gitlab.io/magicmirror/" target="_blank" rel="noopener noreferrer nofollow ugc">https://khassel.gitlab.io/magicmirror/</a>) on a Synology NAS so that I can host it on my network.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19341/calendar-recurring-events-on-wrong-day</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 17:38:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19341.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 16 Jan 2025 16:25:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar Recurring events on wrong day on Fri, 14 Mar 2025 15:56:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morangen" aria-label="Profile: morangen">@<bdi>morangen</bdi></a> did you get this resolved?</p>
]]></description><link>https://forum.magicmirror.builders/post/124879</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124879</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 14 Mar 2025 15:56:19 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Recurring events on wrong day on Thu, 23 Jan 2025 21:59:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morangen" aria-label="Profile: morangen">@<bdi>morangen</bdi></a> did you pull the new container? and is everything  ok now?</p>
]]></description><link>https://forum.magicmirror.builders/post/123328</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123328</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 23 Jan 2025 21:59:24 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Recurring events on wrong day on Thu, 16 Jan 2025 19:55:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morangen" aria-label="Profile: morangen">@<bdi>morangen</bdi></a> said in <a href="/post/123151">Calendar Recurring events on wrong day</a>:</p>
<p dir="auto">I’ll have to make sure it is actually updating and or pulling the latest version in.</p>
<p dir="auto">yes, not everyone wants auto updating if a new image is available.</p>
<p dir="auto">For this you can use tools like watchtower (as <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> already mentioned).</p>
<p dir="auto">The docker image is updated weekly (for getting updates of the underlying debian) but because mm only releases every 3 months there are no mm changes inside.</p>
<p dir="auto">So beside auto updating you could do a manual <code>docker pull ...</code> every 3 months to get the new mm release …</p>
]]></description><link>https://forum.magicmirror.builders/post/123155</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123155</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Thu, 16 Jan 2025 19:55:04 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Recurring events on wrong day on Fri, 17 Jan 2025 00:12:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morangen" aria-label="Profile: morangen">@<bdi>morangen</bdi></a> unless you have watchtower  watching it only pulls on start … it won’t repull while running (that’s watch watchtower does, be careful with latest , SOMETIMEs you get a lot of fun!!)</p>
<p dir="auto">like my zigbee2mqtt updated,  but wouldn’t talk to my coordinator hardware anymore… oops</p>
]]></description><link>https://forum.magicmirror.builders/post/123153</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123153</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 17 Jan 2025 00:12:06 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Recurring events on wrong day on Thu, 16 Jan 2025 18:13:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> That is great to know.  My docker container is setup to pull the latest, but it looks like my MM is still loading version 2.28.</p>
<p dir="auto">Thanks for your reply!</p>
]]></description><link>https://forum.magicmirror.builders/post/123151</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123151</guid><dc:creator><![CDATA[morangen]]></dc:creator><pubDate>Thu, 16 Jan 2025 18:13:21 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Recurring events on wrong day on Thu, 16 Jan 2025 16:33:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morangen" aria-label="Profile: morangen">@<bdi>morangen</bdi></a> the current MM release 2.30 , released Jan 1, 2025 solves the prior date issues with the calendar</p>
<p dir="auto">I am running the same container and the current release uses MM 2.30</p>
<p dir="auto">you could add a watchtower container and have it auto pull the ‘latest’ container update when released</p>
]]></description><link>https://forum.magicmirror.builders/post/123140</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123140</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 16 Jan 2025 16:33:14 GMT</pubDate></item></channel></rss>
