<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Caldav freezes saying "loading"]]></title><description><![CDATA[<p dir="auto">I have 2 different Caldavs that I pull from the same server.  One works fine the other always displays “loading …”.  I have looked in the output from pms logs and I don’t see any errors relating to the calendar.  It just says:<br />
Calendar-fetcher:  Broadcasting 64 events<br />
I was wondering if there is anywhere else that I can look to find more errors that might explain what is happening.  This has worked in the past and for some reason now it just won’t.  I was thinking that perhaps there could be some character or entry in one of my calendar events that is causing an issue.  But I don’t know where to go to find specific calendar errors.  The mirror is running on a raspberry pi 3B</p>
]]></description><link>https://forum.magicmirror.builders/topic/19343/caldav-freezes-saying-loading</link><generator>RSS for Node</generator><lastBuildDate>Sun, 09 Aug 2026 07:44:48 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19343.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 16 Jan 2025 18:09:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Caldav freezes saying "loading" on Wed, 29 Jan 2025 18:25:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/theaddies" aria-label="Profile: theaddies">@<bdi>theaddies</bdi></a> there have been reports of the broadcast from the helper to the front end not being received<br />
see <a href="https://github.com/MagicMirrorOrg/MagicMirror/issues/3380" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MagicMirrorOrg/MagicMirror/issues/3380</a></p>
<p dir="auto">as a test can you refresh the screen ctrl-r</p>
]]></description><link>https://forum.magicmirror.builders/post/123571</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123571</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 29 Jan 2025 18:25:18 GMT</pubDate></item></channel></rss>
