<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How do I start building a smart mirror for full-body outfit changes and recording them?]]></title><description><![CDATA[<p dir="auto">Hello ,</p>
<p dir="auto">I would like to build a my first  smart mirror that helps with outfit changes. The mirror should be able to record and display the differences between outfits, and allow me to change the color of each item I wear through a touchscreen. As a beginner, I need recommendations on how to get started, including suggestions on the best mirror size, monitor size, and materials to use. Any ideas would be greatly appreciated.</p>
<p dir="auto">I’m thinking  to buy a 24-inch monitor and using a screen magnifier to enlarge the display on the mirror. Would this be a good idea, or should I invest in a larger monitor?</p>
<p dir="auto">Is it possible to use a smaller monitor and magnify the display on the mirror while maintaining high quality?</p>
<p dir="auto">Thanks in advance .</p>
]]></description><link>https://forum.magicmirror.builders/topic/19356/how-do-i-start-building-a-smart-mirror-for-full-body-outfit-changes-and-recording-them</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 07:03:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19356.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Jan 2025 06:11:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How do I start building a smart mirror for full-body outfit changes and recording them? on Tue, 21 Jan 2025 18:25:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ismailfares" aria-label="Profile: Ismailfares">@<bdi>Ismailfares</bdi></a>  the monitor must be against the glass to make it visible (and careful for reverse reflections causing image echos) , so there is no room for a magnifier (whatever that it)</p>
<p dir="auto">large image will be a challenge as you meantioned… 55 in is tall AND wide</p>
]]></description><link>https://forum.magicmirror.builders/post/123255</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123255</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 21 Jan 2025 18:25:22 GMT</pubDate></item><item><title><![CDATA[Reply to How do I start building a smart mirror for full-body outfit changes and recording them? on Tue, 21 Jan 2025 17:52:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thanks for reply .<br />
If I use a screen magnifier or projector behind a mirror, will it be possible to enlarge the display, or will always appear the same size as the monitor?<br />
I want to display a full-body image, which would require a 55-inch screen, but that’s quite expensive. I’m looking for alternative solutions—any suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/post/123254</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123254</guid><dc:creator><![CDATA[Ismailfares]]></dc:creator><pubDate>Tue, 21 Jan 2025 17:52:12 GMT</pubDate></item><item><title><![CDATA[Reply to How do I start building a smart mirror for full-body outfit changes and recording them? on Tue, 21 Jan 2025 11:38:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ismailfares" aria-label="Profile: Ismailfares">@<bdi>Ismailfares</bdi></a><br />
as for monitor.<br />
MagicMirror is just showing thru a two way mirror. so your monitor size cannot be enlarged beyond the physical monitor size</p>
]]></description><link>https://forum.magicmirror.builders/post/123248</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123248</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 21 Jan 2025 11:38:52 GMT</pubDate></item><item><title><![CDATA[Reply to How do I start building a smart mirror for full-body outfit changes and recording them? on Tue, 21 Jan 2025 11:35:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ismailfares" aria-label="Profile: Ismailfares">@<bdi>Ismailfares</bdi></a> so far there has been talk of sonething like that, but nothing produced</p>
<p dir="auto">if you do a google search for</p>
<pre><code>node js augmented reality
<p dir="auto">you will see there are components one could use to do that<br />
MagicMirror is all javascript</p>
<p dir="auto">i personally think MagicMirror is the wrong platform for that,<br />
as you will be working around the MagicMirror runtime to do that function, but i suppose you could turn it on/off with an on onscreen  button , and have the MagicMirror info panel display the rest of the time</p>
]]></description><link>https://forum.magicmirror.builders/post/123247</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123247</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 21 Jan 2025 11:35:46 GMT</pubDate></item></channel></rss>
