<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to modify my MMM-CalendarExt3?]]></title><description><![CDATA[<p dir="auto">Hello there!</p>
<p dir="auto">First of all, thanks for the help provided in the forum it has helped my a lot during the time developing my MagicMirror. Anyway, I have not registered into the web until now because I have not found a solution for this.</p>
<p dir="auto">I have my MMM-CalendarExt3 set up and it’s working normally as you can see in the attached picture. Anyway, I just want to show the ongoing day and maybe 3-4 days after the ongoing day. Like this, I would like to have a better (bigger) view of the tasks on my calendar. So I am also looking for having bigger cells, bigger fonts and more tasks on my cells.</p>
<p dir="auto"><img src="https://i.imgur.com/DLsDT0l.png" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Any help?</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://forum.magicmirror.builders/topic/19383/how-to-modify-my-mmm-calendarext3</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 02:44:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19383.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Jan 2025 18:19:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to modify my MMM-CalendarExt3? on Tue, 28 Jan 2025 21:43:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/etnec" aria-label="Profile: etnec">@<bdi>etnec</bdi></a> the default calendar provides the events for the Ext3 family of modules<br />
just add another</p>
<pre><code>{
  url: ....
<p dir="auto">entry to the calendars:[]<br />
list</p>
]]></description><link>https://forum.magicmirror.builders/post/123530</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123530</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 28 Jan 2025 21:43:07 GMT</pubDate></item><item><title><![CDATA[Reply to How to modify my MMM-CalendarExt3? on Tue, 28 Jan 2025 21:40:24 GMT]]></title><description><![CDATA[<p dir="auto">Then use Ext3Agenda in the normal way vertical way.</p>
<p dir="auto">In any event, it sounds like you don’t want the month view - and Ext3 does have just a week view - so maybe it’s as simple as just using week view for you.</p>
<p dir="auto">Ext3Agenda supports calendars in the same way AFAIK as Ext3 - so I would expect if Ext3 works then Ext3Agenda also works</p>
]]></description><link>https://forum.magicmirror.builders/post/123529</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123529</guid><dc:creator><![CDATA[emlowe]]></dc:creator><pubDate>Tue, 28 Jan 2025 21:40:24 GMT</pubDate></item><item><title><![CDATA[Reply to How to modify my MMM-CalendarExt3? on Tue, 28 Jan 2025 20:22:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/emlowe" aria-label="Profile: emlowe">@<bdi>emlowe</bdi></a> said in <a href="/post/123525">How to modify my MMM-CalendarExt3?</a>:</p>
<p dir="auto">I would try using Ext3Agenda version in horizontal layout - it is by the same author and it sounds like the Horizontal layout might be what you want</p>
<p dir="auto"><a href="https://github.com/MMRIZE/MMM-CalendarExt3Agenda" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MMRIZE/MMM-CalendarExt3Agenda</a></p>
<p dir="auto"><a href="https://github.com/MMRIZE/MMM-CalendarExt3Agenda/wiki/Horizontal-layout" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MMRIZE/MMM-CalendarExt3Agenda/wiki/Horizontal-layout</a></p>
<p dir="auto">Thanks mate.<br />
The problem is that my mirror is not horizontal at all :D</p>
<p dir="auto">Anyway, do you know if with CalendarExt3Agenda I can add three (or maybe four) shared calendars from iOS?</p>
]]></description><link>https://forum.magicmirror.builders/post/123526</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123526</guid><dc:creator><![CDATA[etnec]]></dc:creator><pubDate>Tue, 28 Jan 2025 20:22:53 GMT</pubDate></item><item><title><![CDATA[Reply to How to modify my MMM-CalendarExt3? on Tue, 28 Jan 2025 20:01:00 GMT]]></title><description><![CDATA[<p dir="auto">I would try using Ext3Agenda version in horizontal layout - it is by the same author and it sounds like the Horizontal layout might be what you want</p>
]]></description><link>https://forum.magicmirror.builders/post/123525</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123525</guid><dc:creator><![CDATA[emlowe]]></dc:creator><pubDate>Tue, 28 Jan 2025 20:01:00 GMT</pubDate></item></channel></rss>
