<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-FRITZ-Box-Callmonitor-py3 unknown_error]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I have reinstalled my Raspberry. Unfortunately MMM-FRITZ-Box-Callmonitor-py3 no longer works. The module says unknown error. It does not load the phone book. The settings were taken from the old system (it worked there)<br />
Can anyone help me?<br />
My data:<br />
RaspberryPi4 bookworm<br />
Packages are updated<br />
////////////////////////////////////////////////////////////////////////<br />
{<br />
module: ‘MMM-FRITZ-Box-Callmonitor-py3’,<br />
position: ‘top_right’,	<br />
header: “Letzter Anruf”,<br />
config: {<br />
fritzIP: “192.168.188.1”,<br />
fritzPort: ‘1012’,<br />
username: “name”,<br />
password: “pass”,<br />
showContactsStatus: true,<br />
vCard: false,<br />
debug: true,<br />
maximumCallDistance: 60<br />
}<br />
},<br />
<img src="/assets/uploads/files/1738231914277-unbenannt.jpg" alt="Unbenannt.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/19389/mmm-fritz-box-callmonitor-py3-unknown_error</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 22:49:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19389.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Jan 2025 10:14:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Fri, 07 Feb 2025 13:16:42 GMT]]></title><description><![CDATA[<p dir="auto">New attempt: I did not install fritzconnection via pipx, but with pip. I had to turn off the “externally managed” message beforehand.<br />
The phone book is now being read.<br />
The call is not yet displayed. The list is only displayed after a restart.</p>
]]></description><link>https://forum.magicmirror.builders/post/123813</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123813</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Fri, 07 Feb 2025 13:16:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Sun, 09 Feb 2025 08:53:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wuermchen" aria-label="Profile: wuermchen">@<bdi>wuermchen</bdi></a> Great, congratulations.</p>
<p dir="auto">Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/123878</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123878</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Sun, 09 Feb 2025 08:53:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Fri, 07 Feb 2025 14:39:00 GMT]]></title><description><![CDATA[<p dir="auto">Finally! After restarting it works.</p>
]]></description><link>https://forum.magicmirror.builders/post/123817</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123817</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Fri, 07 Feb 2025 14:39:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Fri, 07 Feb 2025 13:16:42 GMT]]></title><description><![CDATA[<p dir="auto">New attempt: I did not install fritzconnection via pipx, but with pip. I had to turn off the “externally managed” message beforehand.<br />
]]></description><link>https://forum.magicmirror.builders/post/123813</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123813</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Fri, 07 Feb 2025 13:16:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Fri, 07 Feb 2025 07:29:04 GMT]]></title><description><![CDATA[<p dir="auto">When I try to reinstall fritzconnection I get the following message:</p>
<pre><code>'fritzconnection' already seems to be installed. Not modifying existing
installation in '/root/.local/pipx/venvs/fritzconnection'. Pass '--force' to
force installation.
]]></description><link>https://forum.magicmirror.builders/post/123812</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123812</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Fri, 07 Feb 2025 07:29:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Thu, 06 Feb 2025 18:25:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wuermchen" aria-label="Profile: wuermchen">@<bdi>wuermchen</bdi></a> yes, but it failed</p>
]]></description><link>https://forum.magicmirror.builders/post/123806</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123806</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 06 Feb 2025 18:25:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Thu, 06 Feb 2025 17:56:58 GMT]]></title><description><![CDATA[<p dir="auto">I installed pipx before and then “sudo pipx install fritzconnection” so I don’t need a virtual environment</p>
]]></description><link>https://forum.magicmirror.builders/post/123805</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123805</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Thu, 06 Feb 2025 17:56:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Thu, 06 Feb 2025 17:15:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wuermchen" aria-label="Profile: wuermchen">@<bdi>wuermchen</bdi></a> does the pip setup require a virtual environment?<br />
which you have to enable again before launching MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/123804</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123804</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 06 Feb 2025 17:15:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Thu, 06 Feb 2025 17:01:59 GMT]]></title><description><![CDATA[<p dir="auto">I reinstalled Fritzcallmonitor. The error still exists.<br />
During installation there were changes compared to the template:</p>
<pre><code>python-dev = Doch die folgenden Pakete ersetzen es: python-dev-is-python3
sudo pip install fritzconnection  error: externally-managed-environment   sudo pipx install fritzconnection
<p dir="auto">Does anyone have any idea what I’m doing wrong?</p>
]]></description><link>https://forum.magicmirror.builders/post/123803</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123803</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Thu, 06 Feb 2025 17:01:59 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Sat, 01 Feb 2025 20:25:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wuermchen" aria-label="Profile: wuermchen">@<bdi>wuermchen</bdi></a><br />
The log info from MMM-FRITZ-Box-Callmonitor seems to be O.K. …<br />
Regards,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/123648</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123648</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Sat, 01 Feb 2025 20:25:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Fri, 31 Jan 2025 18:07:57 GMT]]></title><description><![CDATA[<ul>
<li>I tried a new config with default values, without success</li>
<li>Reinstalling and turning off the other modules, without success</li>
</ul>
<pre><code>{
		module: 'MMM-FRITZ-Box-Callmonitor-py3',
		position: 'top_right',
		header: "Recent calls",
			password: "pass",
			username: "user",
			fritzIP: "192.168.188.1",
			vCard: false
<p dir="auto">npm start has errors</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ npm start
&gt; magicmirror@2.30.0 start
&gt; npm run start:x11
&gt; magicmirror@2.30.0 start:x11
&gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
[2025-01-31 18:47:25.363] [LOG]   Starting MagicMirror: v2.30.0
[2025-01-31 18:47:25.394] [LOG]   Loading config ...
[2025-01-31 18:47:25.398] [LOG]   config template file not exists, no envsubst
[2025-01-31 18:47:26.001] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
[2025-01-31 18:47:26.140] [INFO]  Your configuration file doesn't contain syntax errors :)
[2025-01-31 18:47:26.142] [INFO]  Checking modules structure configuration ...
[2025-01-31 18:47:26.269] [INFO]  Your modules structure configuration doesn't contain errors :)
[2025-01-31 18:47:26.272] [LOG]   Loading module helpers ...
[2025-01-31 18:47:26.275] [LOG]   No helper found for module: alert.
[2025-01-31 18:47:26.283] [LOG]   Initializing new module helper ...
[2025-01-31 18:47:26.284] [LOG]   Module helper loaded: updatenotification
[2025-01-31 18:47:26.285] [LOG]   No helper found for module: clock.
[2025-01-31 18:47:26.286] [LOG]   No helper found for module: compliments.
[2025-01-31 18:47:26.461] [LOG]   Initializing new module helper ...
[2025-01-31 18:47:26.462] [LOG]   Module helper loaded: MMM-FRITZ-Box-Callmonitor-py3
[2025-01-31 18:47:26.463] [LOG]   All module helpers loaded.
[2025-01-31 18:47:26.473] [LOG]   Starting server on port 8080 ...
[2025-01-31 18:47:27.320] [LOG]   Server started ...
[2025-01-31 18:47:27.322] [LOG]   Connecting socket for: updatenotification
[2025-01-31 18:47:27.324] [LOG]   Starting module helper: updatenotification
[2025-01-31 18:47:27.325] [LOG]   Connecting socket for: MMM-FRITZ-Box-Callmonitor-py3
[2025-01-31 18:47:27.327] [LOG]   Starting module: MMM-FRITZ-Box-Callmonitor-py3
[2025-01-31 18:47:27.329] [LOG]   Sockets connected &amp; modules started ...
[2025-01-31 18:47:28.262] [LOG]   Launching application.
[2025-01-31 18:47:29.866] [INFO]  System information:
### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.1; virtual: false
### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.62+rpt-rpi-v8
### VERSIONS: electron: 34.0.2; used node: 20.18.1; installed node: 20.18.1; npm: 10.9.2; pm2: 5.4.3
### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
[96922:0131/184730.026384:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.026830:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.027196:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.027321:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.027499:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.027625:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.027798:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.027902:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.028061:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.028171:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.028341:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.028445:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.028602:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.028704:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.030069:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.030275:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.030478:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.030618:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.030807:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.030950:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.031137:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.031248:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.031471:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.031751:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.031946:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.032053:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.032219:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
[96922:0131/184730.032326:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
[2025-01-31 18:47:31.626] [LOG]   Received config for MMM-FRITZ-Box-Callmonitor-py3
[2025-01-31 18:47:31.631] [LOG]   MMM-FRITZ-Box-Callmonitor-py3 is waiting for incoming calls.
[2025-01-31 18:47:31.680] [INFO]  updatenotification: Updater Class Loaded!
[2025-01-31 18:47:31.682] [INFO]  updatenotification: Checking PM2 using...
[2025-01-31 18:47:31.684] [INFO]  updatenotification: [PM2] You are not using pm2
[2025-01-31 18:47:31.689] [INFO]  Checking git for module: MMM-FRITZ-Box-Callmonitor-py3
[2025-01-31 18:47:31.730] [INFO]  Checking git for module: MagicMirror
[2025-01-31 18:48:11.502] [INFO]  updatenotification: Updater Class Loaded!
[2025-01-31 18:48:11.503] [INFO]  updatenotification: Checking PM2 using...
[2025-01-31 18:48:11.503] [INFO]  updatenotification: [PM2] You are not using pm2
]]></description><link>https://forum.magicmirror.builders/post/123633</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123633</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Fri, 31 Jan 2025 18:07:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Thu, 30 Jan 2025 17:45:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a> bad post, didn’t check source, he had one too</p>
]]></description><link>https://forum.magicmirror.builders/post/123603</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123603</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 30 Jan 2025 17:45:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Thu, 30 Jan 2025 15:50:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/123593">MMM-FRITZ-Box-Callmonitor-py3 unknown_error</a>:</p>
<p dir="auto">i do not know how the module works but i suspect this<br />
<a href="https://forum.magicmirror.builders/post/123380">https://forum.magicmirror.builders/post/123380</a></p>
<p dir="auto">Where do you see the connection? The maintainer of  <a href="https://github.com/drtorchwood/MMM-FRITZ-Box-Callmonitor-py3" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-FRITZ-Box-Callmonitor-py3</a> is drtorchwood.</p>
]]></description><link>https://forum.magicmirror.builders/post/123602</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123602</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Thu, 30 Jan 2025 15:50:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Thu, 30 Jan 2025 14:46:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wuermchen" aria-label="Profile: wuermchen">@<bdi>wuermchen</bdi></a><br />
Hi.<br />
I guess it SHOULD work - at least it works for me at current github status (approx. 2-3 old - not sure what you have archived).<br />
At my own initial setup I got the same error message and after some researches it was caused by refused authentication on the fritzbox side.</p>
<p dir="auto">So I would start at this point initially - not at module side.<br />
My first attempt was login without password (as possible for console) - this doesn’t work.<br />
I’ve created a separate user on AVM side with full access to phonebook and so on and this worked from scratch.<br />
I see that you have an explicite user/pw as well - so I would double check if this user exists on AVM side and do have the right access privileges.</p>
<p dir="auto">For being sure I would recommend to delete all parameters from configuration you do not really need and experiment with the base parameters.<br />
E.g. you have set the Port number - at default - I would delete this one.</p>
<p dir="auto">I’m not sure if you are aware but you can find the documentation of the module in your module folder as well - you do not need the - closed - github entry.<br />
“<a href="http://README.md" target="_blank" rel="noopener noreferrer nofollow ugc">README.md</a>” is the file.</p>
<p dir="auto">Good luck!<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/123600</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123600</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Thu, 30 Jan 2025 14:46:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FRITZ-Box-Callmonitor-py3 unknown_error on Thu, 30 Jan 2025 17:45:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wuermchen" aria-label="Profile: wuermchen">@<bdi>wuermchen</bdi></a></p>
<p dir="auto">sorry bad post</p>
]]></description><link>https://forum.magicmirror.builders/post/123593</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123593</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 30 Jan 2025 17:45:03 GMT</pubDate></item></channel></rss>
