    Help with Crontab starting pm2 mm.sh
    8 Posts 2 Posters 893 Views 2 Watching
      DDE12
      I am using Rasp Pi Bookworm on a Libre Sweet Potato.
      In my user Crontab:
      29 14 * * * pm2 start mm.sh >/dev/null >2&1
      sweetpotatopi:~ $ sudo systemctl status cron
      ● cron.service - Regular background program processing daemon
           Loaded: loaded (/lib/systemd/system/cron.service; enabled; preset: enabled)
           Active: active (running) since Mon 2025-02-03 14:27:37 EST; 1min 55s ago
             Docs: man:cron(8)
         Main PID: 2402 (cron)
            Tasks: 1 (limit: 1986)
           Memory: 368.0K
              CPU: 165ms
           CGroup: /system.slice/cron.service
                   └─2402 /usr/sbin/cron -f
      Feb 03 14:27:37 sweetpotatopi systemd[1]: Started cron.service - Regular background program processing daemon.
      Feb 03 14:27:37 sweetpotatopi cron[2402]: (CRON) INFO (pidfile fd = 3)
      Feb 03 14:27:37 sweetpotatopi cron[2402]: (CRON) INFO (Skipping @reboot jobs -- not system startup)
      Feb 03 14:29:01 sweetpotatopi CRON[2409]: pam_unix(cron:session): session opened for user user(uid=1000) by (uid=0)
      Feb 03 14:29:01 sweetpotatopi CRON[2410]: (user) CMD (pm2 start mm.sh >/dev/null >2&1)
      Feb 03 14:29:01 sweetpotatopi CRON[2409]: pam_unix(cron:session): session closed for user user
      But, the mirror is not starting.
      ~ $ pm2 show mm
       Describing process with id 0 - name mm
      │ status            │ stopped                            │
      │ name              │ mm                                 │
      │ namespace         │ default                            │
      │ version           │ N/A                                │
      │ restarts          │ 0                                  │
      │ uptime            │ 0                                  │
      │ script path       │ /home/user/mm.sh                  │
      │ script args       │ N/A                                │
      │ error log path    │ /home/user/.pm2/logs/mm-error.log │
      │ out log path      │ /home/user/.pm2/logs/mm-out.log   │
      │ pid path          │ /home/user/.pm2/pids/mm-0.pid     │
      │ interpreter       │ bash                               │
      │ interpreter args  │ N/A                                │
      │ script id         │ 0                                  │
      │ exec cwd          │ /home/user                        │
      │ exec mode         │ fork_mode                          │
      │ node.js version   │ N/A                                │
      │ node env          │ N/A                                │
      │ watch & reload    │ ✘                                  │
      │ unstable restarts │ 0                                  │
      │ created at        │ 2025-01-30T12:31:59.717Z           │
       Divergent env variables from local env
      │ _LXSESSION_PID │ 1234                             │
      │ SSH_AUTH_SOCK  │ /tmp/ssh-rK5CMznThwsE/agent.1234 │
      │ SSH_AGENT_PID  │ 1326                             │
      What do I have wrong? Thank you for taking a look at this.
        DDE12 @sdetweil
        @sdetweil That was the solution. Thank you!
        29 14 * * * /usr/local/bin/pm2 start mm.sh >/dev/null >2&1
          sdetweil @DDE12
          @DDE12 anotgeruser had trouble, turned out he needed the full path to pm2
          which pm2
          Should give you that path
            DDE12 @sdetweil
            • D DDE12 has marked this topic as solved on
              sdetweil @DDE12
              @DDE12 and you don’t need start mm.sh
              After you’ve done it once
              pm2 status
              Will show the apps
              Name and row number
              You can use name or row number
                DDE12
                Now I have
                PATH=/usr/local/bin:/usr/bin:/bin
                00 7 * * * pm2 start mm >/dev/null 2>&1
                  sdetweil @DDE12
                  @DDE12 awesome!!
                  i learned recently that
                  &> xxx
                  is the same as >xxx 2>&1
                    DDE12 @sdetweil
                    @sdetweil Like so
                    00 7 * * * pm2 start mm &>/dev/null
                      sdetweil @DDE12
                      @DDE12 yes
