<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can't control CalendarExt2 with Scenes2. Hide indicators.]]></title><description><![CDATA[<p dir="auto">I can toggle between two scenes just fine but CalendarExt2 ignores the scene assignment and its calendars are always visible. Is there anything I can do about this?</p>
<p dir="auto">Also, don’t need indicators. Is it possible to run the Scenes2 module without assigning it to a region?</p>
]]></description><link>https://forum.magicmirror.builders/topic/19408/can-t-control-calendarext2-with-scenes2.-hide-indicators.</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 19:40:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19408.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 Feb 2025 09:13:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can't control CalendarExt2 with Scenes2. Hide indicators. on Fri, 07 Feb 2025 19:06:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmmmh" aria-label="Profile: mmmmh">@<bdi>mmmmh</bdi></a> OK, Here’s what I did: I can control everything else with Scenes2 and for CalendarExt I use Remote-Control’s REST API.</p>
]]></description><link>https://forum.magicmirror.builders/post/123827</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123827</guid><dc:creator><![CDATA[mmmmh]]></dc:creator><pubDate>Fri, 07 Feb 2025 19:06:58 GMT</pubDate></item><item><title><![CDATA[Reply to Can't control CalendarExt2 with Scenes2. Hide indicators. on Thu, 06 Feb 2025 15:34:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmmmh" aria-label="Profile: mmmmh">@<bdi>mmmmh</bdi></a> i do not know about scenes, but he has stopped updating Ext2</p>
]]></description><link>https://forum.magicmirror.builders/post/123799</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123799</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 06 Feb 2025 15:34:15 GMT</pubDate></item><item><title><![CDATA[Reply to Can't control CalendarExt2 with Scenes2. Hide indicators. on Thu, 06 Feb 2025 15:26:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for mentioning that. I am aware of Ext3. But I have customized everything (CSS etc.) so that it works smoothly. OTOH, if you mean that Scenes2 would work with Ext3 I would give it another look.</p>
]]></description><link>https://forum.magicmirror.builders/post/123798</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123798</guid><dc:creator><![CDATA[mmmmh]]></dc:creator><pubDate>Thu, 06 Feb 2025 15:26:53 GMT</pubDate></item><item><title><![CDATA[Reply to Can't control CalendarExt2 with Scenes2. Hide indicators. on Thu, 06 Feb 2025 13:10:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmmmh" aria-label="Profile: mmmmh">@<bdi>mmmmh</bdi></a> Ext2 has been replaced by Ext3  (a couple years ago now) which takes its events from the default calendar</p>
]]></description><link>https://forum.magicmirror.builders/post/123796</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123796</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 06 Feb 2025 13:10:32 GMT</pubDate></item></channel></rss>
