    MagicMirrorOS build intermittently not starting mm container (Version 2.30)
    23 Posts 3 Posters 7.5k Views 3 Watching
      scottwalsh
      I’ve recently built a mm using MagicMirrorOS (which uses the docker install) to use as a family calendar on the wall. Have in configured for the information I want
      However, I am finding if power cycle it, sometimes the calendar does not load up and just have a blank screen.
      If execute:
      scottwalsh@calendar:/opt/mm/run $ docker compose up -d --force-recreate
      Then, it loads.
      Have some Linux background from many years ago, but docker is new to me - so not sure where to look to work out how to resolve.
      From looking at the logs (some extracts below), looks like the mm container isn’t connecting to Xserver.
      Any suggestions where to look for useful logs to work out the issue?
      Thanks, Scott
      scottwalsh@calendar:/opt/mm/run $ docker ps
      CONTAINER ID   IMAGE                          COMMAND                  CREATED       STATUS                 PORTS        NAMES
      00d6a9d4ab86   karsten13/mmpm:latest          "/home/node/entrypoi…"   3 hours ago   Up 2 hours             0.0.0.0:6789->6789/tcp, :::6789->6789/tcp, 0.0.0.0:7890-7891->7890-7891/tcp, :::7890-7891->7890-7891/tcp, 0.0.0.0:8907->8907/tcp, :::8907->8907/tcp   mmpm
      62d9fe5220c6   karsten13/labwc:latest         "/entrypoint.sh"         3 hours ago   Up 2 hours        labwc
      f43c6ecab44b   karsten13/magicmirror:latest   "/usr/bin/tini -- ./…"   2 days ago    Up 23 seconds        mm
      9643b13d7183   containrrr/watchtower:latest   "/watchtower --inter…"   2 days ago    Up 2 hours (healthy)   8080/tcp        watchtower
      scottwalsh@calendar:/opt/mm/run $ docker logs mm
      [entrypoint 06:55:28.611] [INFO]   ***WARNING*** could write to /etc/localtime
      [entrypoint 06:55:28.626] [INFO]   copy default modules
      [entrypoint 06:55:28.824] [INFO]   copy css files
      > magicmirror@2.30.0 start
      > npm run start:x11
      > magicmirror@2.30.0 start:x11
      [2025-02-14 06:55:44.929] [LOG]   Starting MagicMirror: v2.30.0
      [2025-02-14 06:55:45.661] [LOG]   Loading config ...
      [2025-02-14 06:55:45.672] [LOG]   config template file not exists, no envsubst
      [2025-02-14 06:55:47.716] [INFO]  Checking config file /opt/magic_mirror/config/config.js ...
      [2025-02-14 06:55:47.925] [INFO]  Your configuration file doesn't contain syntax errors :)
      [2025-02-14 06:55:47.928] [INFO]  Checking modules structure configuration ...
      [2025-02-14 06:55:48.246] [INFO]  Your modules structure configuration doesn't contain errors :)
      [2025-02-14 06:55:48.253] [LOG]   Loading module helpers ...
      [2025-02-14 06:55:48.271] [LOG]   Initializing new module helper ...
      [2025-02-14 06:55:48.274] [LOG]   Module helper loaded: MMM-mmpm
      [2025-02-14 06:55:48.276] [LOG]   No helper found for module: alert.
      [2025-02-14 06:55:48.293] [LOG]   Initializing new module helper ...
      [2025-02-14 06:55:48.294] [LOG]   Module helper loaded: updatenotification
      [2025-02-14 06:55:49.209] [LOG]   Initializing new module helper ...
      [2025-02-14 06:55:49.210] [LOG]   Module helper loaded: calendar
      [2025-02-14 06:55:49.230] [LOG]   No helper found for module: MMM-CalendarExt3.
      [2025-02-14 06:55:49.232] [LOG]   No helper found for module: clock.
      [2025-02-14 06:55:49.234] [LOG]   No helper found for module: weather.
      [2025-02-14 06:55:49.235] [LOG]   All module helpers loaded.
      [2025-02-14 06:55:49.262] [LOG]   Starting server on port 8080 ...
      [2025-02-14 06:55:49.271] [WARN]  You're using a full whitelist configuration to allow for all IPs
      [2025-02-14 06:55:50.319] [LOG]   Server started ...
      [2025-02-14 06:55:50.322] [LOG]   Connecting socket for: MMM-mmpm
      [2025-02-14 06:55:50.325] [LOG]   Starting module helper: MMM-mmpm
      [2025-02-14 06:55:50.326] [LOG]   Connecting socket for: updatenotification
      [2025-02-14 06:55:50.328] [LOG]   Starting module helper: updatenotification
      [2025-02-14 06:55:50.329] [LOG]   Connecting socket for: calendar
      [2025-02-14 06:55:50.331] [LOG]   Starting node helper for: calendar
      [2025-02-14 06:55:50.333] [LOG]   Sockets connected & modules started ...
      [58:0214/065550.892616:ERROR:ozone_platform_x11.cc(245)] Missing X server or $DISPLAY
      [58:0214/065550.893706:ERROR:env.cc(258)] The platform failed to initialize.  Exiting.
      /opt/magic_mirror/node_modules/electron/dist/electron exited with signal SIGSEGV
      [entrypoint 06:56:00.774] [INFO]   ***WARNING*** could write to /etc/localtime
      [entrypoint 06:56:00.791] [INFO]   copy default modules
      [entrypoint 06:56:00.981] [INFO]   copy css files
      > npm run start:x11
      [2025-02-14 06:56:16.871] [LOG]   Starting MagicMirror: v2.30.0
      [2025-02-14 06:56:18.897] [LOG]   Loading config ...
      [2025-02-14 06:56:18.918] [LOG]   config template file not exists, no envsubst
      [2025-02-14 06:56:20.944] [INFO]  Checking config file /opt/magic_mirror/config/config.js ...
      [2025-02-14 06:56:21.141] [INFO]  Your configuration file doesn't contain syntax errors :)
      [2025-02-14 06:56:21.143] [INFO]  Checking modules structure configuration ...
      [2025-02-14 06:56:21.433] [INFO]  Your modules structure configuration doesn't contain errors :)
      [2025-02-14 06:56:21.441] [LOG]   Loading module helpers ...
      [2025-02-14 06:56:21.459] [LOG]   Initializing new module helper ...
      [2025-02-14 06:56:21.461] [LOG]   Module helper loaded: MMM-mmpm
      [2025-02-14 06:56:21.463] [LOG]   No helper found for module: alert.
      [2025-02-14 06:56:21.478] [LOG]   Initializing new module helper ...
      [2025-02-14 06:56:21.479] [LOG]   Module helper loaded: updatenotification
      [2025-02-14 06:56:21.959] [LOG]   Initializing new module helper ...
      [2025-02-14 06:56:21.960] [LOG]   Module helper loaded: calendar
      [2025-02-14 06:56:21.971] [LOG]   No helper found for module: MMM-CalendarExt3.
      [2025-02-14 06:56:21.973] [LOG]   No helper found for module: clock.
      [2025-02-14 06:56:21.974] [LOG]   No helper found for module: weather.
      [2025-02-14 06:56:21.975] [LOG]   All module helpers loaded.
      [2025-02-14 06:56:21.996] [LOG]   Starting server on port 8080 ...
      [2025-02-14 06:56:22.003] [WARN]  You're using a full whitelist configuration to allow for all IPs
      [2025-02-14 06:56:23.024] [LOG]   Server started ...
      [2025-02-14 06:56:23.026] [LOG]   Connecting socket for: MMM-mmpm
      scottwalsh@calendar:/opt/mm/run $ docker logs labwc
      00:00:00.000 [INFO] [seatd/seat.c:48] Created VT-bound seat seat0
      00:00:00.000 [INFO] [seatd/seatd.c:194] seatd started
      00:00:03.286 [INFO] [seatd/server.c:145] New client connected (pid: 13, uid: 1000, gid: 1000)
      00:00:03.286 [INFO] [seatd/seat.c:239] Added client 1 to seat0
      00:00:03.286 [INFO] [seatd/seat.c:563] Opened client 1 on seat0
      00:00:00.000 [INFO] [seatd/seatd.c:167] Removing leftover socket at /run/seatd.sock
      00:00:02.811 [INFO] [seatd/server.c:145] New client connected (pid: 13, uid: 1000, gid: 1000)
      00:00:02.812 [INFO] [seatd/seat.c:239] Added client 1 to seat0
      00:00:02.812 [INFO] [seatd/seat.c:563] Opened client 1 on seat0
      S karsten13K 4 Replies Last reply Reply Quote 0
        scottwalsh
        As an update, based on the pointers from @KARSTEN13 and @SDETWEIL, have a workaround.
        Had three issues going on.
        1:
        I found that on a graceful reboot (shutdown -r now) that it would generally start fine, but not on an ungraceful reboot (power cycle the machine).
        Looks like when it was ungraceful reboot, the labwc container would show with uptime of (for example) five hours when ‘docker ps’, even though the machine was rebooted 20min ago after ‘docker compose up’ was executed by install.sh. Whereas the magicmirror container would have recently started.
        I assume kind of lock file confusing things?
        Workaround was to change the first ‘docker compose up’ install.sh to ‘docker compose up -d --force-recreate’
        2:
        I’d also included a pause and --force-recreate at the end of the install.sh and noted it was never executing as per @KARSTEN13’s suggestion.
        Looked like the install.sh script was hanging at docker compose pull.
        Commented that out.
        3:
        Lastly, the initial ‘docker compose up -d --force-recreate’ in install.sh would still fail often with the mm container restarting with logs as per the original post.
        With a 7 min pause and then second ‘docker compose up -d --force-recreate’ it seems to start the second time well (3min wasn’t enough, 5min was better, 7min seems to work).
        Workaround is a bit on the slow side, at some point will see if can refactor it a bit so that a pull for updates occurs.
        Extract of resulting install.sh below.
        _info "--> Pulling docker images and starting magicmirror"
        # need sudo for docker here if docker was installed with this script
        # use up so mm can start if there are already local images
        _info "--> Pre Start Pause for 2min"
        sleep 120
        _info "--> Start and recreate"
        $_sudo docker compose up -d --force-recreate
        #_info "--> Pull Pause for 1 min"
        #sleep 60
        # pull new images
        #_info "--> Image Pull"
        #$_sudo docker compose pull
        #_info "--> Restart Pause for 1 min"
        #sleep 60
        # restart (only if new images pulled)
        #_info "--> Restart stopped"
        #$_sudo docker compose up -d
        _info "--> Final Pause for 7 min"
        sleep 720
        _info "--> Final  start and recreate"
        if [[ "$_sudo" == "sudo" ]]; then
          _info "--> Reboot needed, starting in 120 sec. (use ctrl-c to skip)"
          sleep 120
          sudo reboot now
        fi
        # cleanup
        $_sudo docker image prune -f
          sdetweil @scottwalsh
          @scottwalsh that is not MagicMirrorOS
          that is karstens docker container
            @scottwalsh what host is the docker host? pi, unix, nas?
            mine is running on synology nas
            • karsten13K Offline
              karsten13 @scottwalsh
              @scottwalsh said in MagicMirrorOS build intermittently not starting mm container (Version 2.30):
              I don’t know if this is related to the docker setup but I think not. I have encountered similar problems depending on slow hardware and/or heavy load on start due to many modules starting in parallel or starting after fresh boot.
              So you could try to change the start order of the modules (order in config.js), e.g. put the calendar as first.
              @sdetweil said in MagicMirrorOS build intermittently not starting mm container (Version 2.30):
              mmos uses my docker setup
                sdetweil @karsten13
                @karsten13
                since when?
                  karsten13 @sdetweil
                  from the beginning
                    sdetweil @karsten13
                    @karsten13 hm…
                      karsten13 @sdetweil
                      well, I did not promote it because the image base was to old (beside other problems) but in 2024 I decided to do a complete refactor so now the image build (iso, not docker) is done by me with gitlab based on the current raspian bookworm os lite.
                        @scottwalsh please dont double post
                          scottwalsh @sdetweil
                          The host is a pi zero 2w - so is on the low spec side.
                            Apologies, user error.
                              @scottwalsh how big is the swap file?
                              free -m
                              will tell you
                              S karsten13K 2 Replies Last reply Reply Quote 0
                                free -m
                                scottwalsh@calendar:~ $ free -m
                                               total        used        free      shared  buff/cache   available
                                Mem:             425         210          66           0         204         214
                                Swap:           1023         203         820
                                  sdetweil @karsten13
                                  @karsten13 @scottwalsh
                                  bookworm is about 500m bigger that bullseye
                                  so swap is critical on small memory machines
                                    karsten13 @sdetweil
                                    mmos is critical with pi zero 2w, I had a user who gave up, but it depends on installed modules and quality of used sd-card.
                                    CONF_SWAPSIZE=1024 (if not changed by user)
                                      @scottwalsh can you show w MagicMirror running…
                                        scottwalsh
                                        An observation, if I power cycle the pi, there is a good chance of it not starting up with the errors in the original post.
                                        Once leave it for five min for all the processes to start (and fail), then run docker compose up -d --force-recreate, it seems to be stable from then on and works well.
                                          [+] Running 5/5
                                           ✔ Container watchtower  Started        42.0s
                                           ✔ Container labwc       Started        41.9s
                                           ✔ Container init        Started        42.2s
                                           ✔ Container mmpm        Started        42.4s
                                           ✔ Container mm          Started        5.3s
                                          a1cb1b400de1   karsten13/mmpm:latest          "/home/node/entrypoi…"   3 minutes ago   Up 2 minutes             0.0.0.0:6789->6789/tcp, :::6789->6789/tcp, 0.0.0.0:7890-7891->7890-7891/tcp, :::7890-7891->7890-7891/tcp, 0.0.0.0:8907->8907/tcp, :::8907->8907/tcp   mmpm
                                          f7ec5d32f0bd   karsten13/magicmirror:latest   "/usr/bin/tini -- ./…"   3 minutes ago   Up About a minute        mm
                                          74193ae14fbf   karsten13/labwc:latest         "/entrypoint.sh"         3 minutes ago   Up 2 minutes        labwc
                                          bcf30cd7bb10   containrrr/watchtower:latest   "/watchtower --inter…"   3 minutes ago   Up 2 minutes (healthy)   8080/tcp        watchtower
                                          scottwalsh@calendar:/opt/mm/run $ free -m
                                          Mem:             425         236         134          36         141         189
                                          Swap:           1023         296         727
                                            @scottwalsh probably swap file speed bound
                                              @scottwalsh
                                              the script /opt/mm/install/install.sh is executed with every reboot.
                                              As workaround you could add
                                              sleep 10s
                                              at the end (where you have to play with the sleep seconds).
