<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM always black screen with cursor]]></title><description><![CDATA[<p dir="auto">Hello guys,<br />
it’s been a whole week since I’m trying to install MagicMirror on a Raspberry PI 3 model A+.<br />
I waited like 3 years and now I have the free time to setting it up.<br />
I’m writing on this forum because there is no way to make it work.<br />
The principal issue is when I start the service the screen will became black with cursor on it and it wont display anything. Neither the clock.</p>
<p dir="auto">Raspberry is not freeze, if I press CTRL + Q it return on desktop, and work normally.</p>
<p dir="auto">I tried, no joking, like one million times…<br />
with manual installation’s first because I usually prefer manual methods and, as latest trying, I tried automatic script from “sdetweil”.</p>
<p dir="auto">On every test I made I started from a clean installation so:<br />
1- wipe the sd<br />
2- install bookworm 64 bit with desktop with “raspberry pi imager”. OS downloaded from  raspberry site.<br />
4- boot and start the update/installation</p>
<p dir="auto">First times I update the OS before nodejs and MM installation, on the last times I didn’t update OS just to check if like this it will work.</p>
<p dir="auto">Another detail is I tried to disable pihole  (installed in another raspberry) for 40 minutes, in order to complete the script installation without any network interferences but nothing.<br />
Honestly I think pihole is not connected to my issue, but I tried before disturb you in the forum.</p>
<p dir="auto">So every time, after the installation, I have a black screen with cursor.<br />
Another detail:<br />
Now I’m using an lcd (9-10 inches) connected with an lcd controller board, I though it should be an LCD/controller issue  so I tried also to connect it on my tv screen and nothing.<br />
Black screen with cursor, again.</p>
<p dir="auto">I’m becoming CRAZY… tha’t why my name is nowayto…make it work!</p>
<p dir="auto">The installation is so simple! It’s impossible it doesn’t work.<br />
I also read every forum on google to find a solution  for my issue but nothing.<br />
If this issue was appeared after a config.js modification, I will knew it was my fault but in that  case…<br />
I didn’t make any modification… I’m trying just a simple startup.</p>
<p dir="auto">If you can help me I’ll really thank you for your time guys.<br />
Thanks a lot</p>
]]></description><link>https://forum.magicmirror.builders/topic/19470/mm-always-black-screen-with-cursor</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Mar 2026 07:14:10 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19470.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 24 Feb 2025 13:26:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM always black screen with cursor on Tue, 25 Feb 2025 20:20:45 GMT]]></title><description><![CDATA[<p dir="auto">After 1 millions of tests and trying… now it works.<br />
It seems it start to work using “raspbian bookworm 32bit <strong>legacy</strong>”.<br />
I tried with the non-legacy too and it didn’t work.<br />
Is that possible?<br />
I’m asking that because I know my 3 model A+ is 64bit capable.<br />
Honestly, without your advice… I’ll never though it could be the OS.<br />
Thank you a lot, now I’ll start a new chapter: the configuration</p>
]]></description><link>https://forum.magicmirror.builders/post/124325</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124325</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Tue, 25 Feb 2025 20:20:45 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Wed, 26 Feb 2025 23:14:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> yes, the doc  mentions this, and if you had set</p>
<p dir="auto">showQR:true</p>
<p dir="auto">it would have displayed a message about localhost</p>
<p dir="auto"><img src="/assets/uploads/files/1740611667306-img_0800.png" alt="IMG_0800.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/124352</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124352</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 26 Feb 2025 23:14:35 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Wed, 26 Feb 2025 22:24:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
My fault.  In config.js the adress was set in “localhost”… Sorry.<br />
Now I set the IP and I granted the access</p>
]]></description><link>https://forum.magicmirror.builders/post/124350</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124350</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Wed, 26 Feb 2025 22:24:41 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Wed, 26 Feb 2025 21:49:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Exactly but I can’t access.<br />
Now I’m trying give a whitelist complete access.</p>
<p dir="auto">The only error I see is a GPU process error but I don’t think is connected to the web server.</p>
<p dir="auto">[2025-02-26 22:43:49.784] [LOG]   Launching application.<br />
<strong>[7194:0226/224359.949078:ERROR:gpu_process_host.cc(1007)] GPU process exited unexpectedly: exit_code=512<br />
[2025-02-26 22:44:42.117] [LOG]<br />
[7194:0226/224442.468308:ERROR:gpu_process_host.cc(1007)] GPU process exited unexpectedly: exit_code=512<br />
[7194:0226/224504.822973:ERROR:gpu_process_host.cc(1007)] GPU process exited unexpectedly: exit_code=512<br />
[2025-02-26 22:45:56.193]</strong> [INFO]  System information:</p>
<h3>SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model A Plus Rev 1.1; virtual: false</h3>
<h3>OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+</h3>
<h3>VERSIONS: electron: 32.3.1; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3</h3>
<h3>OTHER:    timeZone: Europe/Rome; ELECTRON_ENABLE_GPU: undefined</h3>
<p dir="auto">[2025-02-26 22:45:56.931] [LOG]   Create new calendarfetcher for url: <a href="https://ics.calendarlabs.com/76/****MYCAL" target="_blank" rel="noopener noreferrer nofollow ugc">https://ics.calendarlabs.com/76/****MYCAL</a>***** - Interval: 604800000<br />
[2025-02-26 22:45:57.049] [LOG]   Create new newsfetcher for url: <a href="http://www" target="_blank" rel="noopener noreferrer nofollow ugc">http://www</a>.<strong><strong>MYRSS</strong></strong>**- Interval: 300000<br />
[2025-02-26 22:45:57.118] [INFO]  updatenotification: Updater Class Loaded!<br />
[2025-02-26 22:45:57.123] [INFO]  updatenotification: Checking PM2 using…<br />
[2025-02-26 22:45:57.125] [INFO]  updatenotification: [PM2] You are not using pm2<br />
[2025-02-26 22:45:57.128] [INFO]  Checking git for module: MMM-Wallpaper<br />
[2025-02-26 22:45:57.591] [INFO]  Checking git for module: MMM-Config<br />
[2025-02-26 22:45:57.893] [INFO]  Checking git for module: MagicMirror<br />
[2025-02-26 22:45:58.426] [INFO]  Calendar-Fetcher: Broadcasting 10 events from <a href="https://ics.calendarlabs.com" target="_blank" rel="noopener noreferrer nofollow ugc">https://ics.calendarlabs.com</a>*****MYCAL****.<br />
[2025-02-26 22:45:58.443] [INFO]  Newsfeed-Fetcher: Broadcasting 10 items.</p>
]]></description><link>https://forum.magicmirror.builders/post/124349</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124349</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Wed, 26 Feb 2025 21:49:38 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Wed, 26 Feb 2025 20:51:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> then you should be able to access the mmm-config urls</p>
]]></description><link>https://forum.magicmirror.builders/post/124348</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124348</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 26 Feb 2025 20:51:43 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Wed, 26 Feb 2025 19:47:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">npm run start</p>
<p dir="auto">magicmirror@2.30.0 start<br />
npm run start:x11</p>
<p dir="auto">magicmirror@2.30.0 start:x11<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
<p dir="auto">[2025-02-26 15:00:59.702] [LOG]   Starting MagicMirror: v2.30.0<br />
[2025-02-26 15:01:01.515] [LOG]   Loading config …<br />
[2025-02-26 15:01:01.525] [LOG]   config template file not exists, no envsubst<br />
[2025-02-26 15:01:10.865] [INFO]  Checking config file /home/MYRASPBNAME/MagicM        irror/config/config.js …<br />
[2025-02-26 15:01:11.018] [INFO]  Your configuration file doesn’t contain syntax        errors :)<br />
[2025-02-26 15:01:11.020] [INFO]  Checking modules structure configuration …<br />
[2025-02-26 15:01:11.253] [INFO]  Your modules structure configuration doesn’t c        ontain errors :)<br />
[2025-02-26 15:01:12.473] [LOG]   Loading module helpers …<br />
[2025-02-26 15:01:12.480] [LOG]   No helper found for module: alert.<br />
[2025-02-26 15:01:12.519] [LOG]   Initializing new module helper …<br />
[2025-02-26 15:01:12.522] [LOG]   Module helper loaded: updatenotification<br />
[2025-02-26 15:01:12.525] [LOG]   No helper found for module: clock.<br />
[2025-02-26 15:01:13.000] [LOG]   Initializing new module helper …<br />
[2025-02-26 15:01:13.001] [LOG]   Module helper loaded: calendar<br />
[2025-02-26 15:01:13.005] [LOG]   No helper found for module: compliments.<br />
[2025-02-26 15:01:13.007] [LOG]   No helper found for module: weather.<br />
[2025-02-26 15:01:42.730] [LOG]   Initializing new module helper …<br />
[2025-02-26 15:01:42.732] [LOG]   Module helper loaded: MMM-Wallpaper<br />
[2025-02-26 15:01:43.127] [LOG]   Initializing new module helper …<br />
[2025-02-26 15:01:43.128] [LOG]   Module helper loaded: MMM-Config<br />
[2025-02-26 15:01:43.437] [LOG]   Initializing new module helper …<br />
[2025-02-26 15:01:43.438] [LOG]   Module helper loaded: newsfeed<br />
[2025-02-26 15:01:43.439] [LOG]   All module helpers loaded.<br />
[2025-02-26 15:01:43.455] [LOG]   Starting server on port **** …<br />
[2025-02-26 15:02:26.268] [LOG]   Server started …<br />
[2025-02-26 15:02:26.271] [LOG]   Connecting socket for: updatenotification<br />
[2025-02-26 15:02:26.288] [LOG]   Starting module helper: updatenotification<br />
[2025-02-26 15:02:26.290] [LOG]   Connecting socket for: calendar<br />
[2025-02-26 15:02:26.291] [LOG]   Starting node helper for: calendar<br />
[2025-02-26 15:02:26.293] [LOG]   Connecting socket for: MMM-Wallpaper<br />
[2025-02-26 15:02:26.295] [LOG]   Starting node helper for: MMM-Wallpaper<br />
[2025-02-26 15:02:26.306] [LOG]   Connecting socket for: MMM-Config<br />
[2025-02-26 15:02:27.236] [LOG]   Connecting socket for: newsfeed<br />
[2025-02-26 15:02:27.237] [LOG]   Starting node helper for: newsfeed<br />
[2025-02-26 15:02:27.258] [LOG]   Sockets connected &amp; modules started …<br />
[2025-02-26 15:02:44.884] [LOG]   Launching application.</p>
]]></description><link>https://forum.magicmirror.builders/post/124347</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124347</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Wed, 26 Feb 2025 19:47:29 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Wed, 26 Feb 2025 19:31:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> more log info, i dont see info for mmm-config</p>
]]></description><link>https://forum.magicmirror.builders/post/124345</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124345</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 26 Feb 2025 19:31:27 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Wed, 26 Feb 2025 19:16:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
free -m<br />
total        used        free      shared  buff/cache   available<br />
Mem:               426         180          91          81         155         112<br />
Swap:           1023         225         798</p>
]]></description><link>https://forum.magicmirror.builders/post/124343</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124343</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Wed, 26 Feb 2025 19:16:53 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Wed, 26 Feb 2025 19:10:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Yes i did and the config checker gave me the OK</p>
<p dir="auto">this is the startup<br />
npm run start</p>
[2025-02-26 15:01:10.865] [INFO]  Checking config file /home/MYRASPBERRYNAME/MagicM        irror/config/config.js …<br />
[2025-02-26 15:01:12.480] [LOG]   No helper found for module: alert.</p>
]]></description><link>https://forum.magicmirror.builders/post/124344</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124344</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Wed, 26 Feb 2025 19:10:57 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Wed, 26 Feb 2025 14:36:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a></p>
<p dir="auto">on the startup, can you show the output of<br />
npm run start</p>
<p dir="auto">also show output of<br />
free -m</p>
]]></description><link>https://forum.magicmirror.builders/post/124331</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124331</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 26 Feb 2025 14:36:00 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Wed, 26 Feb 2025 14:34:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> did you add my module to config.js</p>
<pre><code>{
        module:"MMM-Config",
        position:"....one_of the positions",
         config:{
]]></description><link>https://forum.magicmirror.builders/post/124330</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124330</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 26 Feb 2025 14:34:14 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Wed, 26 Feb 2025 14:21:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
very interesting. I’ve installed it, but I can’t access to webpanel.<br />
Tried with:<br />
<a href="http://IP" target="_blank" rel="noopener noreferrer nofollow ugc">http://IP</a>:PORT/configure<br />
<a href="http://LOCALHOST" target="_blank" rel="noopener noreferrer nofollow ugc">http://LOCALHOST</a>:PORT/configure<br />
no access.<br />
tried with standard 8080 and another port chosen by me.<br />
computer IP is whitelisted, and clearly on same network.<br />
config check is OK</p>
<p dir="auto">~/MagicMirror/config $ npm run config:check</p>
<p dir="auto">magicmirror@2.30.0 config:check<br />
node js/check_config.js<br />
[2025-02-26 15:19:04.776] [INFO]  Checking config file /home/PINAME/MagicM        irror/config/config.js …<br />
[2025-02-26 15:19:04.960] [INFO]  Your configuration file doesn’t contain syntax        errors :)<br />
[2025-02-26 15:19:04.962] [INFO]  Checking modules structure configuration …<br />
[2025-02-26 15:19:05.229] [INFO]  Your modules structure configuration doesn’t c        ontain errors :)</p>
<p dir="auto">Another little issues: sometimes I got black screen with cursor after “npm run start”<br />
I have to restart it in order to making it work</p>
]]></description><link>https://forum.magicmirror.builders/post/124329</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124329</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Wed, 26 Feb 2025 14:21:29 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Tue, 25 Feb 2025 20:34:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a>  configuration, try my  MMM-Config module. also supports installing modules</p>
<p dir="auto"><a href="https://github.com/sdetweil/MMM-Config" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MMM-Config</a></p>
]]></description><link>https://forum.magicmirror.builders/post/124327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124327</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 25 Feb 2025 20:34:20 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Tue, 25 Feb 2025 20:28:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> i think 64 bit is ok, IF you have the physical memory<br />
3A doesnt</p>
]]></description><link>https://forum.magicmirror.builders/post/124326</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124326</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 25 Feb 2025 20:28:15 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Tue, 25 Feb 2025 20:20:45 GMT]]></title><description><![CDATA[<p dir="auto">After 1 millions of tests and trying… now it works.<br />
]]></description><link>https://forum.magicmirror.builders/post/124325</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124325</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Tue, 25 Feb 2025 20:20:45 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Mon, 24 Feb 2025 21:47:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> i would wait a little longer, web app not open yet</p>
<p dir="auto">or npm start dev, in the dev window select the console tab</p>
<p dir="auto">see if there is an error displayed</p>
]]></description><link>https://forum.magicmirror.builders/post/124309</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124309</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 24 Feb 2025 21:47:49 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Mon, 24 Feb 2025 20:07:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">This is the result inside the *.txt</p>
<p dir="auto">[2025-02-24 20:55:20.171] [LOG]   Starting MagicMirror: v2.30.0<br />
[2025-02-24 20:55:22.568] [LOG]   Loading config …<br />
[2025-02-24 20:55:22.695] [LOG]   config template file not exists, no envsubst<br />
[2025-02-24 20:55:31.157] [INFO]  Checking config file /home/berrymirror/MagicMirror/config/config.js …<br />
[2025-02-24 20:55:31.368] [INFO]  Your configuration file doesn’t contain syntax errors :)<br />
[2025-02-24 20:55:31.371] [INFO]  Checking modules structure configuration …<br />
[2025-02-24 20:55:33.349] [INFO]  Your modules structure configuration doesn’t contain errors :)<br />
[2025-02-24 20:55:33.364] [LOG]   Loading module helpers …<br />
[2025-02-24 20:55:33.371] [LOG]   No helper found for module: alert.<br />
[2025-02-24 20:55:33.399] [LOG]   Initializing new module helper …<br />
[2025-02-24 20:55:33.401] [LOG]   Module helper loaded: updatenotification<br />
[2025-02-24 20:55:33.404] [LOG]   No helper found for module: clock.<br />
[2025-02-24 20:55:34.525] [LOG]   Initializing new module helper …<br />
[2025-02-24 20:55:34.526] [LOG]   Module helper loaded: calendar<br />
[2025-02-24 20:55:34.532] [LOG]   No helper found for module: compliments.<br />
[2025-02-24 20:55:34.538] [LOG]   No helper found for module: weather.<br />
[2025-02-24 20:55:35.571] [LOG]   Initializing new module helper …<br />
[2025-02-24 20:55:35.572] [LOG]   Module helper loaded: newsfeed<br />
[2025-02-24 20:55:35.573] [LOG]   All module helpers loaded.<br />
[2025-02-24 20:55:35.711] [LOG]   Starting server on port 8080 …<br />
[2025-02-24 20:56:47.381] [LOG]   Server started …<br />
[2025-02-24 20:56:49.306] [LOG]   Connecting socket for: updatenotification<br />
[2025-02-24 20:56:50.754] [LOG]   Starting module helper: updatenotification<br />
[2025-02-24 20:56:50.897] [LOG]   Connecting socket for: calendar<br />
[2025-02-24 20:56:51.135] [LOG]   Starting node helper for: calendar<br />
[2025-02-24 20:56:51.155] [LOG]   Connecting socket for: newsfeed<br />
[2025-02-24 20:56:51.159] [LOG]   Starting node helper for: newsfeed<br />
[2025-02-24 20:56:51.421] [LOG]   Sockets connected &amp; modules started …<br />
[2025-02-24 20:58:33.277] [LOG]   Launching application.</p>
]]></description><link>https://forum.magicmirror.builders/post/124308</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124308</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Mon, 24 Feb 2025 20:07:25 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Mon, 24 Feb 2025 16:09:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> show</p>
<p dir="auto">cd ~/MagicMirror<br />
npm start &gt;somefile.txt</p>
<p dir="auto">then when screen up, ctrl-q</p>
<p dir="auto">and look at somefile.txt</p>
]]></description><link>https://forum.magicmirror.builders/post/124299</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124299</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 24 Feb 2025 16:09:22 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Mon, 24 Feb 2025 14:40:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you for the answer.<br />
Ok, this evening I’ll show the ~/install.log and I’ll try to install MM  with 32bit image.<br />
I have another micro SD to test.<br />
“show the messages for npm start” do you mean to copy the log screen I see from SSH?<br />
To start MM I tried 3 ways:<br />
1- from ssh “npm run start” “npm start”<br />
2- from ssh the “DISPLAY=:0…(etc etc)” command<br />
3- from terminal, directly on raspberry, “npm run start” and “npm start”</p>
]]></description><link>https://forum.magicmirror.builders/post/124297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124297</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Mon, 24 Feb 2025 14:40:52 GMT</pubDate></item><item><title><![CDATA[Reply to MM always black screen with cursor on Mon, 24 Feb 2025 13:37:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a>  show some of the config.js</p>
<p dir="auto">show the messages for npm start</p>
<p dir="auto">3a probably would be better w the 32 bit os image, legacy</p>
<p dir="auto">if you used the scripted install show the ~/install.log</p>
]]></description><link>https://forum.magicmirror.builders/post/124293</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124293</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 24 Feb 2025 13:37:20 GMT</pubDate></item></channel></rss>
