<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Which solution for touching screen?]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
<p dir="auto">Could someone advise me which hardware to use to make a touch  Magic Mirror? Not too small, idealy 21 to 23 inches.</p>
<p dir="auto">E.g infrared frame  overlay, or an idea of a monitor brand which provides touch screens compatible with a Raspberry 4 and the Magic Mirror solution?</p>
<p dir="auto">I bought a iiyama ProLite T2252MSC-B2 touch screen, but as I tried it, the touch function was finally not compatible with Raspberry and it was  only working in the landscape mode… I did not realise it before buying it…</p>
<p dir="auto">Thank you for your advise and sharing you experience about this topic.</p>
<p dir="auto">Looking forward to reading you,</p>
<p dir="auto">Kind regards,</p>
<p dir="auto">Cedric</p>
]]></description><link>https://forum.magicmirror.builders/topic/19486/which-solution-for-touching-screen</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 20:47:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19486.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 02 Mar 2025 16:28:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Which solution for touching screen? on Mon, 17 Mar 2025 15:01:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/com1cedric" aria-label="Profile: com1cedric">@<bdi>com1cedric</bdi></a> this was started as a conversation, not an issue…</p>
]]></description><link>https://forum.magicmirror.builders/post/124979</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124979</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Mar 2025 15:01:48 GMT</pubDate></item><item><title><![CDATA[Reply to Which solution for touching screen? on Mon, 17 Mar 2025 15:00:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> yes, this one can be closed. But I do not see the button to close it</p>
]]></description><link>https://forum.magicmirror.builders/post/124978</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124978</guid><dc:creator><![CDATA[com1cedric]]></dc:creator><pubDate>Mon, 17 Mar 2025 15:00:09 GMT</pubDate></item><item><title><![CDATA[Reply to Which solution for touching screen? on Mon, 17 Mar 2025 13:32:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/com1cedric" aria-label="Profile: com1cedric">@<bdi>com1cedric</bdi></a> , yes, that’s what I would have suggested as well - use</p>
<pre><code>Option "TransformationMatrix" "0 -1 1 1 0 0 0 0 1"
<p dir="auto">or similar in /usr/share/X11/xorg.conf.d/40-libinput.conf …</p>
<p dir="auto">Regards,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/124975</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124975</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Mon, 17 Mar 2025 13:32:54 GMT</pubDate></item><item><title><![CDATA[Reply to Which solution for touching screen? on Mon, 17 Mar 2025 12:58:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/com1cedric" aria-label="Profile: com1cedric">@<bdi>com1cedric</bdi></a> didn’t you just.post solving this<br />
<a href="https://forum.magicmirror.builders/post/124971">https://forum.magicmirror.builders/post/124971</a></p>
]]></description><link>https://forum.magicmirror.builders/post/124973</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124973</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Mar 2025 12:58:47 GMT</pubDate></item><item><title><![CDATA[Reply to Which solution for touching screen? on Mon, 17 Mar 2025 06:10:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a><br />
hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a>, wenn you tested your  Hannspree Touch monitor, did you have to change any parameter on the raspberry,  so that the “touching points” work?<br />
On mine, it is working fine in landscape mode, but in the portrait mode, the points are “mirrored”, so that it is impossible to use it without parametring that. Thank you in advance, Cédric</p>
]]></description><link>https://forum.magicmirror.builders/post/124968</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124968</guid><dc:creator><![CDATA[com1cedric]]></dc:creator><pubDate>Mon, 17 Mar 2025 06:10:53 GMT</pubDate></item><item><title><![CDATA[Reply to Which solution for touching screen? on Thu, 06 Mar 2025 20:07:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/com1cedric" aria-label="Profile: com1cedric">@<bdi>com1cedric</bdi></a> O.K. to me :-)<br />
Good luck!</p>
<p dir="auto">Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/124602</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124602</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Thu, 06 Mar 2025 20:07:10 GMT</pubDate></item><item><title><![CDATA[Reply to Which solution for touching screen? on Tue, 04 Mar 2025 14:36:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> thank you very much for your proposal, but I just ordered it (I am in Switzerland).</p>
<p dir="auto">I will then test it and send it back if it does not work.</p>
<p dir="auto">I will inform you in any case whether if was successful or not.</p>
<p dir="auto">Cédric</p>
]]></description><link>https://forum.magicmirror.builders/post/124526</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124526</guid><dc:creator><![CDATA[com1cedric]]></dc:creator><pubDate>Tue, 04 Mar 2025 14:36:15 GMT</pubDate></item><item><title><![CDATA[Reply to Which solution for touching screen? on Tue, 04 Mar 2025 14:24:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/com1cedric" aria-label="Profile: com1cedric">@<bdi>com1cedric</bdi></a> where are you located?<br />
Bckground: If in feasible distance I could send you my Hannspree Display for testing purposes …</p>
<p dir="auto">Warm regards,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/124525</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124525</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Tue, 04 Mar 2025 14:24:44 GMT</pubDate></item><item><title><![CDATA[Reply to Which solution for touching screen? on Tue, 04 Mar 2025 06:42:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> hello Sam, great, thanks a lot!</p>
]]></description><link>https://forum.magicmirror.builders/post/124517</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124517</guid><dc:creator><![CDATA[com1cedric]]></dc:creator><pubDate>Tue, 04 Mar 2025 06:42:31 GMT</pubDate></item><item><title><![CDATA[Reply to Which solution for touching screen? on Mon, 03 Mar 2025 23:37:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/com1cedric" aria-label="Profile: com1cedric">@<bdi>com1cedric</bdi></a> touch monitor/ir-frame is a mouse from the apps perspective, touch invokes click, movement is mouse movements</p>
<p dir="auto">pageindicator circles are buttons/links , you can change the image thru css<br />
see <a href="https://forum.magicmirror.builders/post/118877">https://forum.magicmirror.builders/post/118877</a></p>
<p dir="auto">so, if the display sends touch events, the browser will react<br />
i do not know the hardware</p>
]]></description><link>https://forum.magicmirror.builders/post/124505</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124505</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 03 Mar 2025 23:37:03 GMT</pubDate></item><item><title><![CDATA[Reply to Which solution for touching screen? on Mon, 03 Mar 2025 09:39:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> said in <a href="/post/124446">Which solution for touching screen?</a>:</p>
<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> , and thank you for your advise!</p>
<p dir="auto">My mirror should be just a monitor without any reflecting surface, using MMM-Pages and MMM-page-indicator.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/edward-shen" aria-label="Profile: edward-shen">@<bdi>edward-shen</bdi></a> : do you think your modules MMM-Pages and MMM-page-indicator should work with a kind of “Hannspree Touch monitor” or IR-Frame, without using a mouse? Can you please advise me?</p>
<p dir="auto">Thank you in advance and best regards.</p>
]]></description><link>https://forum.magicmirror.builders/post/124501</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124501</guid><dc:creator><![CDATA[com1cedric]]></dc:creator><pubDate>Mon, 03 Mar 2025 09:39:49 GMT</pubDate></item><item><title><![CDATA[Reply to Which solution for touching screen? on Sun, 02 Mar 2025 20:03:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/com1cedric" aria-label="Profile: com1cedric">@<bdi>com1cedric</bdi></a></p>
<p dir="auto">I had tried a Hannspree Touch monitor which worked out of the box with Raspian OS - without any driver installation.<br />
So it should work with MagicMirror as well.<br />
Video is connected via HDMI and touch is realized via USB.</p>
<p dir="auto">I do not use it for my MagigMirror - it‘s to small for my use-case.</p>
<p dir="auto">If you really want to realize a MIRROR keep in mind that every capacitative touch functionality will NOT work behind a reflecting surface.<br />
For this use case you have to consider IR-Frames around your mirror.<br />
If you just want to use the monitor - fine …</p>
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/124446</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124446</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Sun, 02 Mar 2025 20:03:43 GMT</pubDate></item></channel></rss>
