<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mirror Freezing]]></title><description><![CDATA[<p dir="auto">I have updated everything trying to get past this.<br />
I installed a real time clock.<br />
Fresh install of Debian 12<br />
Fresh install of MagicMirror and restore with Sam’s backup/restore script.<br />
So everything is fresh.  I am running this on a NVME ssd stick.<br />
very fast.<br />
Ok since i gave you all the background.<br />
Here is the problem I am having.<br />
MM will run fine for hours, then all the sudden MM freezes, the time stops and it stays on the page that the time freezes on.<br />
I have about 40 different modules running and they run great until the freeze up happens.<br />
Below is the errors I am getting in the pm2 logs.</p>
<pre><code>0|mm       | [2048:0303/182231.302189:ERROR:gles2_cmd_decoder_passthrough.cc(928)] ContextResult::kFatalFailure: fail_if_major_perf_caveat + swiftshader
0|mm       | [2048:0303/182231.339696:ERROR:gles2_cmd_decoder_passthrough.cc(928)] ContextResult::kFatalFailure: fail_if_major_perf_caveat + swiftshader
0|mm       | [2025-03-03 18:22:33.874] [ERROR] We expected a redirect to guce.yahoo.com, but got https://finance.yahoo.com/quote/AAPL/
0|mm       | [2025-03-03 18:22:33.875] [ERROR] We'll try to continue anyway - you can safely ignore this if the request succeeds
0|mm       | /home/pi/MagicMirror/node modules/electron/dist/electron exited with signal SIGINT
0|mm       | [3690:0304/064512.174017:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
0|mm       | [3690:0304/064512.174366:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
<p dir="auto">These repeat over and over for 20 or so times.  I didnt count them.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19498/mirror-freezing</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 14:25:37 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19498.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Mar 2025 00:30:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 23:13:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a>  i think most often is the parent dies but the child was still running…</p>
]]></description><link>https://forum.magicmirror.builders/post/124587</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124587</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 05 Mar 2025 23:13:07 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 23:33:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a><br />
Found It</p>
<pre><code>ps ux | awk '{if($8=="Z") print}'
pi          1170  0.0  0.0      0     0 ?        Z    16:36   0:00 [xsettingsd] &lt;defunct&gt;
<p dir="auto">What is xsettingsd?<br />
Should x11 be running with wayland ?<br />
Seems like a duplicated background app running or do they not do basically the same thing.?</p>
<p dir="auto">I did kill the 1166 which turned out to be the parent of the 1170 xsettingsd<br />
Mirror restarted I assume due to PM2 being involved.<br />
It restarted MUCH faster than normal.  The MMM-Snow is running smoother.<br />
I guess only time will tell.</p>
]]></description><link>https://forum.magicmirror.builders/post/124588</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124588</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Wed, 05 Mar 2025 23:33:40 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 23:13:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a>  i think most often is the parent dies but the child was still running…</p>
]]></description><link>https://forum.magicmirror.builders/post/124587</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124587</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 05 Mar 2025 23:13:07 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 23:11:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> <img src="/assets/uploads/files/1741216309124-img_0826.png" alt="IMG_0826.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/124586</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124586</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 05 Mar 2025 23:11:50 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 23:01:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a></p>
<p dir="auto">see e.g. <a href="https://www.baeldung.com/linux/clean-zombie-process" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.baeldung.com/linux/clean-zombie-process</a></p>
]]></description><link>https://forum.magicmirror.builders/post/124585</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124585</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Wed, 05 Mar 2025 23:01:18 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 22:56:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Not so sure that it was globe came home today and the same screen was stopped,<br />
MMM-Dogs and the time was the same 3:37 pm   but the real time was 4:30 pm.<br />
So re-enabled globe and disabled MMM-Dogs to see if it does it again tomorrow…<br />
I am almost wondering if it isn’t something to do with MMM-birthday-paged.<br />
It was the last module I remember adding since this started.<br />
I will slowly figure it out by disabling one module at a time that seems  to hog resources.</p>
<p dir="auto">By the  way what do it mean by zombie in top.?</p>
<pre><code>top - 16:53:44 up 17 min,  3 users,  load average: 5.34, 5.15, 3.71
Tasks: 222 total,   3 running, 218 sleeping,   0 stopped,   1 zombie
%Cpu(s): 77.3 us, 12.1 sy,  0.0 ni, 10.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   7820.9 total,   4021.5 free,   1923.3 used,   2830.4 buff/cache
MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5897.6 avail Mem
]]></description><link>https://forum.magicmirror.builders/post/124584</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124584</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Wed, 05 Mar 2025 22:56:02 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 20:50:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a>  this is the best Answer</p>
]]></description><link>https://forum.magicmirror.builders/post/124581</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124581</guid><dc:creator><![CDATA[freelancerakash]]></dc:creator><pubDate>Wed, 05 Mar 2025 20:50:11 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 01:37:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> i think page switching while globe is drawing<br />
is probably the cause</p>
]]></description><link>https://forum.magicmirror.builders/post/124558</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124558</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 05 Mar 2025 01:37:36 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 01:28:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Just did a kill 1998 and it is now not showing up but the mirror is still working,<br />
I guess I will wait until one of the modules doesn’t work anymore.<br />
Then i will know which one to remove, right?<br />
Turns out that was the wireless connection I think.<br />
MM stopped and I can not access it through ssh time to POPO.<br />
I will keep after this but I will also stop globe in the config.js. just to see if that helps.<br />
Thanks for your help I have learned alot tonight about the way debian and MM run.</p>
]]></description><link>https://forum.magicmirror.builders/post/124557</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124557</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Wed, 05 Mar 2025 01:28:54 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 01:21:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> you can</p>
<p dir="auto">sudo kill -9 pid</p>
<p dir="auto">but i dont know what functions are in what process, electron decides that. one is the page/tab</p>
]]></description><link>https://forum.magicmirror.builders/post/124556</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124556</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 05 Mar 2025 01:21:32 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 01:06:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
you are correct electron is hoarding resources.<br />
Is there a way to kill a PID in debian to see what module may be causing this.<br />
1998<br />
1988<br />
and 1949 are top three cpu hogs…</p>
]]></description><link>https://forum.magicmirror.builders/post/124555</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124555</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Wed, 05 Mar 2025 01:06:21 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 01:02:22 GMT]]></title><description><![CDATA[<p dir="auto">@also to stackoverflow</p>
<p dir="auto"><a href="https://stackoverflow.com/questions/72876389/how-does-chromium-implement-failifmajorperformancecaveat" target="_blank" rel="noopener noreferrer nofollow ugc">https://stackoverflow.com/questions/72876389/how-does-chromium-implement-failifmajorperformancecaveat</a></p>
<p dir="auto">which points to a  graphical module, globe, something doing heavy charts.</p>
]]></description><link>https://forum.magicmirror.builders/post/124554</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124554</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 05 Mar 2025 01:02:22 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 00:55:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> start in server mode and connect chrome or some other browser, sounds like an electron problem</p>
<p dir="auto">maybe change  the pages rate a little (10%)</p>
]]></description><link>https://forum.magicmirror.builders/post/124553</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124553</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 05 Mar 2025 00:55:28 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Freezing on Wed, 05 Mar 2025 00:35:20 GMT]]></title><description><![CDATA[<p dir="auto">Oh and I can ssh in and run date and the time is correct.<br />
If I run MM in a separate browser on my laptop I pops up and runs fine and very clean.  Time is correct.  ect.  which then causes the MM on the wall to start working again…<br />
I did run your update script with force tonight when I came home and it had been frozen for approx. 3.5 hrs.<br />
I am currently watching to see if it freezes again.    so frustrating.</p>
]]></description><link>https://forum.magicmirror.builders/post/124552</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124552</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Wed, 05 Mar 2025 00:35:20 GMT</pubDate></item></channel></rss>
