<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-OpenWeatherForecast... CSS]]></title><description><![CDATA[<p dir="auto">I wanna move the wind icon to the right of it’s cell…  How to do this?</p>
<p dir="auto"><img src="/assets/uploads/files/1741997466686-1b0c3d86-fdff-4ef4-9900-66a26b084d2b-image.png" alt="1b0c3d86-fdff-4ef4-9900-66a26b084d2b-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Custom CSS at present:</p>
<pre><code>/* Weather Alerts */
.MMM-OpenWeatherForecast .weather-alert {
  display: none;
.MMM-OpenWeatherForecast .weather-alert .weather-alert-title {
  display: none;
.MMM-OpenWeatherForecast .weather-alert .weather-alert-description {
  display: none;
.MMM-OpenWeatherForecast .weather-alert .weather-alert-source {
  display: none;
.MMM-OpenWeatherForecast .module-content {
  width: 620px;
.MMM-OpenWeatherForecast .wrapper.tiled .forecast-container .forecast-item .time,
.MMM-OpenWeatherForecast .wrapper.tiled .forecast-container .forecast-item .day-name {
  font-size: unset;
.MMM-OpenWeatherForecast .wrapper.tiled .forecast-container .forecast-item &gt; *,
.MMM-OpenWeatherForecast .wrapper.tiled .forecast-container .forecast-item &gt; * {
  font-size: unset;
.MMM-OpenWeatherForecast .wrapper.tiled .forecast-container .forecast-item .temperature,
.MMM-OpenWeatherForecast .wrapper.tiled .forecast-container .forecast-item .temperature-container {
  font-size: unset;
.MMM-OpenWeatherForecast .wrapper.table .forecast-container {
  font-size: unset;
.MMM-OpenWeatherForecast .wrapper.table .forecast-container .forecast-item &gt; span,
.MMM-OpenWeatherForecast .wrapper.table .forecast-container .header-row &gt; span {
  font-size: unset;
  font-size: unset;
]]></description><link>https://forum.magicmirror.builders/topic/19534/mmm-openweatherforecast...-css</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 00:42:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19534.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Mar 2025 00:14:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-OpenWeatherForecast... CSS on Sat, 15 Mar 2025 12:57:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> not me. I just tried what Google search results suggested</p>
<p dir="auto">Key item the style was on the span, not the img</p>
]]></description><link>https://forum.magicmirror.builders/post/124904</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124904</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Mar 2025 12:57:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast... CSS on Sat, 15 Mar 2025 07:35:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> odd - I tried that before and it didn’t work. Now it does.</p>
<p dir="auto">CSS man.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/124901</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124901</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sat, 15 Mar 2025 07:35:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast... CSS on Sat, 15 Mar 2025 13:33:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a><br />
using the default everything config</p>
<p dir="auto">google search result<br />
<a href="https://stackoverflow.com/questions/56289240/how-to-move-the-icon-to-the-right-end" target="_blank" rel="noopener noreferrer nofollow ugc">https://stackoverflow.com/questions/56289240/how-to-move-the-icon-to-the-right-end</a></p>
<p dir="auto">and with</p>
<pre><code class="language-css">.MMM-OpenWeatherForecast .wind-header {
   float;right;
<p dir="auto"><img src="/assets/uploads/files/1742013185181-snip20250314_12.png" alt="Snip20250314_12.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/124898</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124898</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Mar 2025 13:33:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast... CSS on Sat, 15 Mar 2025 03:05:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> care to share config without api key</p>
]]></description><link>https://forum.magicmirror.builders/post/124896</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124896</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Mar 2025 03:05:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast... CSS on Sat, 15 Mar 2025 03:01:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> if you can do it in the dev window just copy paste and add the module name prefix.</p>
<p dir="auto">I don’t use that module</p>
<p dir="auto">Use the dev window , select the element, maybe element parent right-justify</p>
]]></description><link>https://forum.magicmirror.builders/post/124895</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124895</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Mar 2025 03:01:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast... CSS on Sat, 15 Mar 2025 02:40:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I’ve tried everything I could think of, and can’t get it to translate to custom CSS.</p>
]]></description><link>https://forum.magicmirror.builders/post/124894</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124894</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sat, 15 Mar 2025 02:40:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherForecast... CSS on Sat, 15 Mar 2025 02:21:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> see the second link in my signature below<br />
And google search<br />
Move icon to the right on web page</p>
<p dir="auto">The second will give you styles to try<br />
The first will give you the tool to test with</p>
]]></description><link>https://forum.magicmirror.builders/post/124891</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124891</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Mar 2025 02:21:56 GMT</pubDate></item></channel></rss>
