<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to display both Celsius and Fahrenheit]]></title><description><![CDATA[<p dir="auto">Hi community,</p>
<p dir="auto">New to playing with Magic Mirror platform and first Raspberry pi project.</p>
<p dir="auto">As the header eludes I am trying to figure out whether it is possible to display both Celsius <em>and</em> Fahrenheit together, the ideal would be to display 10°C / 50°F (In case wondering why the need for both, the context is that I am British and my partner is American).  I am familiar with how to set metric or imperial both globally and per module, and would rather not duplicate modules for the sake of having both standards.</p>
<p dir="auto">So far, searching on this forum and others only finds posts seeking to solve issues where imperial is displayed instead of metric and vice versa.  I had wondered whether there was a js solution, but I’m not familiar with the language so would need to read up on it.</p>
<p dir="auto">Not sure whether a config file is useful, but can share if needed.  Currently using openweathermap as weather provider, and have been able to display Celsius or Fahrenheit but not both together.  Any help or pointers to a solution welcome.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19538/how-to-display-both-celsius-and-fahrenheit</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 15:39:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19538.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Mar 2025 21:53:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to display both Celsius and Fahrenheit on Fri, 18 Apr 2025 21:54:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/digimunky" aria-label="Profile: digimunky">@<bdi>digimunky</bdi></a> awesome, i don’t think you had to make a duplicate copy, just set the language in config.js on each instance</p>
<p dir="auto">all of the default modules support multi instance</p>
]]></description><link>https://forum.magicmirror.builders/post/125839</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125839</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 18 Apr 2025 21:54:05 GMT</pubDate></item><item><title><![CDATA[Reply to How to display both Celsius and Fahrenheit on Mon, 14 Apr 2025 17:43:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you Sam, I was getting the impression that each module could only handle one unit type, but appreciated the confirmation.</p>
<p dir="auto">By way of an update, I did explore your suggestion of a second instance, there are a few posts describing how to duplicate the default modules.  I did pause this aspect of the project to work on other aspects until I worked out how to implement it (the thought of near exact duplicate modules at once was ghastly, and the idea of stripping the second to just imperial and merging it somehow with metric was headache inducing).</p>
<p dir="auto">I came back to this after finding <a href="https://github.com/edward-shen/MMM-pages" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Pages</a> and it cycled quite nicely every 15 seconds between the metric and imperial display.  Happy partner, happy me.</p>
<p dir="auto">Well, that was until I installed the <a href="https://github.com/jgauth/MMM-GoogleTasks" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-GoogleTasks</a> module which broke MMM-Pages.  But, your input on the <a target="_blank" rel="noopener noreferrer nofollow ugc">MMM-GoogleTasks not compatible with MMM-pages, MMM-Carousel, or MMM-ModuleScheduler</a> thread solved that!</p>
<p dir="auto">Anyway, thank you. Much appreciated on both counts.</p>
]]></description><link>https://forum.magicmirror.builders/post/125838</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125838</guid><dc:creator><![CDATA[digimunky]]></dc:creator><pubDate>Mon, 14 Apr 2025 17:43:18 GMT</pubDate></item><item><title><![CDATA[Reply to How to display both Celsius and Fahrenheit on Sat, 15 Mar 2025 22:18:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/digimunky" aria-label="Profile: digimunky">@<bdi>digimunky</bdi></a> but two instances  can display both</p>
<p dir="auto">the modules are designed for single temp range at a time</p>
]]></description><link>https://forum.magicmirror.builders/post/124922</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124922</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Mar 2025 22:18:04 GMT</pubDate></item></channel></rss>
