<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Google Assistant]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">Anyone have an alternative to Google assistant<br />
Not working anymore, I believe</p>
]]></description><link>https://forum.magicmirror.builders/topic/19544/google-assistant</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 15:55:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19544.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Mar 2025 18:56:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Google Assistant on Mon, 17 Mar 2025 20:15:26 GMT]]></title><description><![CDATA[<p dir="auto">there is currently no replacement</p>
]]></description><link>https://forum.magicmirror.builders/post/124990</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124990</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Mar 2025 20:15:26 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Tue, 15 Apr 2025 13:10:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> oh now I see OK thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/125856</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125856</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Tue, 15 Apr 2025 13:10:38 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Tue, 15 Apr 2025 13:09:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: Cr4z33">@<bdi>Cr4z33</bdi></a> I understand… he was saying you can’t install in again, and we don’t KNOW if/when it will fail</p>
]]></description><link>https://forum.magicmirror.builders/post/125855</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125855</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 15 Apr 2025 13:09:52 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Tue, 15 Apr 2025 13:00:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> what I meant was referring to the OP saying Google Assistant module doesn’t work anymore while I am actually running it fine.</p>
]]></description><link>https://forum.magicmirror.builders/post/125854</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125854</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Tue, 15 Apr 2025 13:00:41 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Tue, 15 Apr 2025 12:26:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: Cr4z33">@<bdi>Cr4z33</bdi></a> just be careful<br />
<a href="https://forum.magicmirror.builders/topic/19362/googleassistant-and-related-modules">https://forum.magicmirror.builders/topic/19362/googleassistant-and-related-modules</a></p>
]]></description><link>https://forum.magicmirror.builders/post/125853</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125853</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 15 Apr 2025 12:26:48 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Tue, 15 Apr 2025 12:19:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johanba" aria-label="Profile: Johanba">@<bdi>Johanba</bdi></a> what do you mean?</p>
<p dir="auto">I use it everyday to voice control my bathroom smart mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/125852</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125852</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Tue, 15 Apr 2025 12:19:07 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Fri, 21 Mar 2025 21:54:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alexandre-venditti69" aria-label="Profile: Alexandre-Venditti69">@<bdi>Alexandre-Venditti69</bdi></a> comme je l’ai dit, il y a beaucoup de travail pour que le fork fonctionne et soit installable et maintenable.</p>
]]></description><link>https://forum.magicmirror.builders/post/125126</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125126</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 21 Mar 2025 21:54:30 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Fri, 21 Mar 2025 20:35:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> j’imagine que c’est un travail considérable. J’ai tjs Jarvis sur mon miroir et fonctionne parfaitement, j’ai du faire quelques modif concernant mes routines personnelle en passant par un nouveau récipe qui redirige mes requêtes. Je ne pensais pas qu’avec cette base et une équipe motivée cela n’était pas envisageable. Cependant merci.</p>
]]></description><link>https://forum.magicmirror.builders/post/125124</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125124</guid><dc:creator><![CDATA[Alexandre-Venditti69]]></dc:creator><pubDate>Fri, 21 Mar 2025 20:35:15 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Fri, 21 Mar 2025 12:56:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alexandre-venditti69" aria-label="Profile: Alexandre-Venditti69">@<bdi>Alexandre-Venditti69</bdi></a> good luck</p>
]]></description><link>https://forum.magicmirror.builders/post/125096</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125096</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 21 Mar 2025 12:56:24 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Fri, 21 Mar 2025 11:56:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> je pensais de copier un fork de son travail, pour avoir une base de quoi faire tourner un nouveau module, sachant que son propriétaire l’a lui même supprimé.</p>
]]></description><link>https://forum.magicmirror.builders/post/125094</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125094</guid><dc:creator><![CDATA[Alexandre-Venditti69]]></dc:creator><pubDate>Fri, 21 Mar 2025 11:56:37 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Fri, 21 Mar 2025 02:03:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alexandre-venditti69" aria-label="Profile: Alexandre-Venditti69">@<bdi>Alexandre-Venditti69</bdi></a> &gt;Je ne suis toujours pas sûr que ces pratiques soient considérées comme de bonnes pratiques dans la communauté.</p>
<p dir="auto">Quelles pratiques ?</p>
]]></description><link>https://forum.magicmirror.builders/post/125081</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125081</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 21 Mar 2025 02:03:07 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Fri, 21 Mar 2025 01:54:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> PS: je ne suis pas informaticien du tout mais ce projet m’a énormément appris en codage, j’ai eut l’honneur de travailler avec <a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> sur le module ext selfies. La tenue de tt ces modules étaient un travail monstre. Mais a plusieurs, vu le nombre de fan du projet , peut être est il possible de le faire .<br />
Ayant appris l’utilité de GitHub  Grace à cette collaboration, je ne sais tout fois pas si ces pratiques sont de bonnes moeurs dans la communauté ?</p>
]]></description><link>https://forum.magicmirror.builders/post/125079</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125079</guid><dc:creator><![CDATA[Alexandre-Venditti69]]></dc:creator><pubDate>Fri, 21 Mar 2025 01:54:56 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Fri, 21 Mar 2025 01:53:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alexandre-venditti69" aria-label="Profile: Alexandre-Venditti69">@<bdi>Alexandre-Venditti69</bdi></a></p>
<p dir="auto">je ne sais pas. son travail est assez incroyable. mais il a également ajouté quelques vérifications pour que les forks bruts ne fonctionnent pas, et a minimisé son code, il sera donc plus difficile à apprendre. au-delà de mes capacités compte tenu de mon temps disponible.</p>
]]></description><link>https://forum.magicmirror.builders/post/125077</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125077</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 21 Mar 2025 01:53:48 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Fri, 21 Mar 2025 01:47:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> bonjour, est il possible par un fork peut être, de repartir de l’excellent job de <a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a>  pour un recréer un a niveau sur ces mêmes bases?<br />
Je ne connais pas les Motifs de son départ ou de son banne, mais il a tout de même révolutionné l’utilisation du Magic Mirror pour tout les membre de ce formidable projet.</p>
]]></description><link>https://forum.magicmirror.builders/post/125076</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125076</guid><dc:creator><![CDATA[Alexandre-Venditti69]]></dc:creator><pubDate>Fri, 21 Mar 2025 01:47:01 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Mon, 17 Mar 2025 20:15:26 GMT]]></title><description><![CDATA[<p dir="auto">there is currently no replacement</p>
]]></description><link>https://forum.magicmirror.builders/post/124990</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124990</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Mar 2025 20:15:26 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Mon, 17 Mar 2025 20:02:46 GMT]]></title><description><![CDATA[<p dir="auto">I would love to know this also</p>
]]></description><link>https://forum.magicmirror.builders/post/124989</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124989</guid><dc:creator><![CDATA[bmue]]></dc:creator><pubDate>Mon, 17 Mar 2025 20:02:46 GMT</pubDate></item></channel></rss>
