<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[default calendar fetching issues]]></title><description><![CDATA[<p dir="auto">I’m using default calendar with calendarExt3<br />
Actually I’m using 2 .ics, one for holidays and one for private, both are Google cals and sometimes module has fetching issues.<br />
I can’t figure what the problem is because behaviour is strange.</p>
<p dir="auto">These are the cases that happened to me, everytimes on startup:</p>
<ul>
<li>no default calendar events, no ext3 events</li>
<li>default and ext3 shows only holiday events</li>
<li>default shows nothing, ext3 shows some events</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/19546/default-calendar-fetching-issues</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 01:41:03 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19546.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 18 Mar 2025 16:03:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to default calendar fetching issues on Mon, 24 Mar 2025 22:05:13 GMT]]></title><description><![CDATA[<p dir="auto">I had considerable problems with running on a model A - but I found <code>dietPI</code> (<a href="https://dietpi.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://dietpi.com/</a>) to be a solid distro that works well even when using the default electron GUI front-end. (Previously OOM’d consistently)</p>
<p dir="auto">Note, also I frequently have trouble with the calendar events appears as there seems to be some problem in the websocket communication layer  (this bug: <a href="https://github.com/MagicMirrorOrg/MagicMirror/issues/3380" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MagicMirrorOrg/MagicMirror/issues/3380</a>)</p>
<p dir="auto">I basically use MMM-RemoteControl to force a refresh in a daily cron job (<code>curl http://localhost:8080/api/refresh</code>) and this works. Why? No One knows</p>
]]></description><link>https://forum.magicmirror.builders/post/125231</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125231</guid><dc:creator><![CDATA[emlowe]]></dc:creator><pubDate>Mon, 24 Mar 2025 22:05:13 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Sat, 29 Mar 2025 13:12:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> if pm2 is being used, its JOB  is to keep the app running</p>
<p dir="auto">so the pm2 restart  seems odd as if the app was ended , ctrl-q<br />
pm2 would do restart already</p>
]]></description><link>https://forum.magicmirror.builders/post/125408</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125408</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 29 Mar 2025 13:12:41 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Sat, 29 Mar 2025 12:46:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/emlowe" aria-label="Profile: emlowe">@<bdi>emlowe</bdi></a> I have a similar problem, I solved modifing <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> with</p>
<p dir="auto">sleep 30<br />
DISPLAY=:0 npm start<br />
sleep 60<br />
pm2 restart mm</p>
<p dir="auto">“pm2 restart mm” does a  refresh like you do with RemoteControl</p>
]]></description><link>https://forum.magicmirror.builders/post/125407</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125407</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Sat, 29 Mar 2025 12:46:07 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Mon, 24 Mar 2025 22:05:13 GMT]]></title><description><![CDATA[<p dir="auto">I had considerable problems with running on a model A - but I found <code>dietPI</code> (<a href="https://dietpi.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://dietpi.com/</a>) to be a solid distro that works well even when using the default electron GUI front-end. (Previously OOM’d consistently)</p>
]]></description><link>https://forum.magicmirror.builders/post/125231</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125231</guid><dc:creator><![CDATA[emlowe]]></dc:creator><pubDate>Mon, 24 Mar 2025 22:05:13 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Sat, 22 Mar 2025 13:31:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> there is no way to delay loading</p>
]]></description><link>https://forum.magicmirror.builders/post/125130</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125130</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 22 Mar 2025 13:31:04 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Sat, 22 Mar 2025 07:33:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Yes I agree, the memory is very limiting.<br />
Although mine is a Pi3 model A, but the memory is 512mb like the pi02w.<br />
When I started the project I had something different in my mind and now I’m pushing it to the limit.</p>
<p dir="auto">But as I said I checked everytime the CPU temperature, memory and generally resources usage from “htop” command.</p>
<p dir="auto">This morning  MM started with calendar error, I did a “pm2 restart mm” and goes OK.</p>
<p dir="auto">Now I put “sleep 120” inside <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> <strong>as first line</strong><br />
I restarted it now</p>
<p dir="auto">Memory BEFORE restart was this<br />
total        used        free      shared  buff/cache   available<br />
Mem:             427         156          90          70            179                 147<br />
Swap:           1023         231         792</p>
<p dir="auto">Not so good but not so bad, same time.</p>
<p dir="auto">I’ll check if this delay could help.<br />
Is there a way to put a little delay between the loading of every module ? Maybe 5/10 seconds, I though it could be very helpful on a limited machine like mine :)</p>
]]></description><link>https://forum.magicmirror.builders/post/125129</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125129</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Sat, 22 Mar 2025 07:33:53 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Fri, 21 Mar 2025 13:06:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> i do not know on pm2</p>
<p dir="auto">you could put a sleep 120<br />
in the <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> to wait a while</p>
<p dir="auto">how is swap space?</p>
<p dir="auto">free -m</p>
<p dir="auto">pi02w only has 512mb</p>
]]></description><link>https://forum.magicmirror.builders/post/125098</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125098</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 21 Mar 2025 13:06:47 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Thu, 20 Mar 2025 07:35:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
behaviour seems the same.  I suspect this, could this issues be related to the  raspberry pi 3 computing capacity? could it be not enough?</p>
<p dir="auto">Is there a way to delay the pm2 automatic startup.<br />
For example I though to try a delay of 1-2 minutes so:<br />
1- raspbian startup<br />
2- delay of 1-2 minutes to make sure all the services are up and the cpu is idle<br />
3- mm startup<br />
4- if it’s possible, I will add a delay to the modules startup also, maybe 20 seconds between every module loading</p>
<p dir="auto">Honestly I checked his capacity a lot of times using the htop, free and cpu temperature command.<br />
With my amazement I see everytime an amount of free memory,  low cpu load and good cpu temp (like 40 to 50 degrees)</p>
<p dir="auto">But if there is a way to delay everything, I’ll just check if with a “calmly” startup It will go better</p>
]]></description><link>https://forum.magicmirror.builders/post/125042</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125042</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Thu, 20 Mar 2025 07:35:25 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Wed, 19 Mar 2025 23:19:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> no. just some users dont know what i mean</p>
]]></description><link>https://forum.magicmirror.builders/post/125041</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125041</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 19 Mar 2025 23:19:32 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Wed, 19 Mar 2025 23:07:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I did it.<br />
I usually put the “disabled: true” before the module name line, instead of after<br />
Is it different?</p>
]]></description><link>https://forum.magicmirror.builders/post/125040</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125040</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Wed, 19 Mar 2025 23:07:31 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Wed, 19 Mar 2025 22:24:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> ok, disable the updatenotification module in config.js</p>
<p dir="auto">add</p>
<p dir="auto">disabled:true,<br />
after the<br />
module:line</p>
]]></description><link>https://forum.magicmirror.builders/post/125039</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125039</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 19 Mar 2025 22:24:46 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Wed, 19 Mar 2025 22:14:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Recreated 2 times.</p>
<p dir="auto">First time calendar loaded Holidays calendar only</p>
<p dir="auto">[2025-03-19 22:23:55.917] [LOG]   Create new calendarfetcher for url: <a href="https://calendar.google.com/calendar/ical/**MYCAL" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/**MYCAL</a>**&gt;<br />
[2025-03-19 22:23:56.467] [LOG]   Create new calendarfetcher for url: <a href="https://calendar.google.com/calendar/ical/**HOLIDAYPUBLICCAL**/publ" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/**HOLIDAYPUBLICCAL**/publ</a>&gt;<br />
[2025-03-19 22:23:56.675] [LOG]   Create new newsfetcher for url: <a href="https://www.ansa.it/sito/ansait_rss.xml" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.ansa.it/sito/ansait_rss.xml</a> - Interval: 300000<br />
[2025-03-19 22:23:56.698] [LOG]   MMM-Growatt: GROWATT_GET_DATA<br />
[2025-03-19 22:23:56.836] [LOG]   MMM-Formula1 received a notification: CONFIG<br />
[2025-03-19 22:23:56.838] [LOG]   MMM-Formula1 is requesting the SCHEDULE on url <a href="https://api.jolpi.ca/ergast/f1/2025.json" target="_blank" rel="noopener noreferrer nofollow ugc">https://api.jolpi.ca/ergast/f1/2025.json</a><br />
[2025-03-19 22:24:02.687] [INFO]  updatenotification: Updater Class Loaded!<br />
[2025-03-19 22:24:02.733] [INFO]  updatenotification: Checking PM2 using…<br />
[2025-03-19 22:24:02.735] [INFO]  updatenotification: [PM2] You are not using pm2<br />
[2025-03-19 22:24:02.740] [INFO]  Checking git for module: MMM-CalendarExt3<br />
[2025-03-19 22:24:03.525] [INFO]  Checking git for module: MMM-Growatt<br />
[2025-03-19 22:24:03.850] [INFO]  Checking git for module: MMM-Formula1<br />
[2025-03-19 22:24:04.283] [INFO]  Checking git for module: MMM-RAIN-MAP<br />
[2025-03-19 22:24:07.693] [INFO]  Checking git for module: MagicMirror<br />
[2025-03-19 22:24:08.072] [LOG]   MMM-Formula1 is returning the SCHEDULE for the season<br />
[2025-03-19 22:24:40.393] [INFO]  Newsfeed-Fetcher: Broadcasting 28 items.<br />
[2025-03-19 22:24:45.457] [INFO]  Calendar-Fetcher: Broadcasting 61 events from <a href="https://calendar.google.com/calendar/**MYPRIVCAL" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/**MYPRIVCAL</a>**&gt;<br />
[2025-03-19 22:24:46.745] [INFO]  Calendar-Fetcher: Broadcasting 36 events from <a href="https://calendar.google.com/calendar/**PUBLICHOLIDAYCAL/" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/**PUBLICHOLIDAYCAL/</a>&gt;<br />
[2025-03-19 22:24:57.986] [LOG]   Publishing GROWATT data<br />
[2025-03-19 22:25:51.745] [LOG]   MMM-Growatt: GROWATT_GET_DATA<br />
[2025-03-19 22:25:54.191] [LOG]   Publishing GROWATT data<br />
[2025-03-19 22:27:51.368] [LOG]   MMM-Growatt: GROWATT_GET_DATA<br />
[2025-03-19 22:27:53.447] [LOG]   Publishing GROWATT data</p>
<hr />
<p dir="auto">2nd time I got the error and no calendar loaded:</p>
<p dir="auto">[2025-03-19 22:32:06.388] [LOG]   Create new calendarfetcher for url: <a href="https://calendar.google.com/calendar/**PUBLICHOLIDAYCAL" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/**PUBLICHOLIDAYCAL</a>**&gt;<br />
[2025-03-19 22:32:07.767] [LOG]   Create new calendarfetcher for url: <a href="https://calendar.google.com/calendar/**MYPRIVCAL" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/**MYPRIVCAL</a>**&gt;<br />
[2025-03-19 22:32:07.881] [LOG]   Create new newsfetcher for url: <a href="https://www.ansa.it/sito/ansait_rss.xml" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.ansa.it/sito/ansait_rss.xml</a> - Interval: 300000<br />
[2025-03-19 22:32:07.903] [LOG]   MMM-Growatt: GROWATT_GET_DATA<br />
[2025-03-19 22:32:08.057] [INFO]  updatenotification: Updater Class Loaded!<br />
[2025-03-19 22:32:08.059] [INFO]  updatenotification: Checking PM2 using…<br />
[2025-03-19 22:32:08.063] [INFO]  updatenotification: [PM2] You are not using pm2<br />
[2025-03-19 22:32:08.066] [INFO]  Checking git for module: MMM-CalendarExt3<br />
[2025-03-19 22:32:08.132] [LOG]   MMM-Formula1 received a notification: CONFIG<br />
[2025-03-19 22:32:08.134] [LOG]   MMM-Formula1 is requesting the SCHEDULE on url <a href="https://api.jolpi.ca/ergast/f1/2025.json" target="_blank" rel="noopener noreferrer nofollow ugc">https://api.jolpi.ca/ergast/f1/2025.json</a><br />
[2025-03-19 22:32:08.516] [INFO]  Checking git for module: MMM-Growatt<br />
[2025-03-19 22:32:10.043] [INFO]  Checking git for module: MMM-Formula1<br />
[2025-03-19 22:32:11.007] [INFO]  Checking git for module: MMM-RAIN-MAP<br />
[2025-03-19 22:32:14.346] [INFO]  Newsfeed-Fetcher: Broadcasting 28 items.<br />
[2025-03-19 22:32:14.404] [LOG]   MMM-Formula1 is returning the SCHEDULE for the season<br />
[2025-03-19 22:32:14.414] [INFO]  Checking git for module: MagicMirror<br />
[2025-03-19 22:32:48.815] [INFO]  Calendar-Fetcher: Broadcasting 61 events from <a href="https://calendar.google.com/calendar/**MYPRIVCAL" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/**MYPRIVCAL</a>**&gt;<br />
[2025-03-19 22:32:50.508] [INFO]  Calendar-Fetcher: Broadcasting 36 events from <a href="https://calendar.google.com/calendar/**PUBLICHOLIDAYCAL" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/**PUBLICHOLIDAYCAL</a>**&gt;<br />
[2025-03-19 22:32:51.949] [LOG]   Publishing GROWATT data<br />
[2025-03-19 22:34:08.485] [LOG]   MMM-Growatt: GROWATT_GET_DATA<br />
[2025-03-19 22:34:14.955] [LOG]   Publishing GROWATT data<br />
[2025-03-19 22:36:06.721] [LOG]   MMM-Growatt: GROWATT_GET_DATA<br />
[2025-03-19 22:36:09.906] [LOG]   Publishing GROWATT data<br />
[2025-03-19 22:37:16.339] [INFO]  Newsfeed-Fetcher: Broadcasting 28 items.<br />
[2025-03-19 22:38:07.502] [LOG]   MMM-Growatt: GROWATT_GET_DATA<br />
[2025-03-19 22:38:10.302] [LOG]   Publishing GROWATT data<br />
[2025-03-19 22:40:09.496] [LOG]   MMM-Growatt: GROWATT_GET_DATA<br />
[2025-03-19 22:40:12.087] [LOG]   Publishing GROWATT data<br />
[2025-03-19 22:42:11.495] [LOG]   MMM-Growatt: GROWATT_GET_DATA<br />
[2025-03-19 22:42:13.869] [LOG]   Publishing GROWATT data<br />
[2025-03-19 22:42:16.743] [INFO]  Newsfeed-Fetcher: Broadcasting 28 items.<br />
[2025-03-19 22:44:13.525] [LOG]   MMM-Growatt: GROWATT_GET_DATA<br />
[2025-03-19 22:44:15.562] [LOG]   Publishing GROWATT data<br />
[2025-03-19 22:46:15.496] [LOG]   MMM-Growatt: GROWATT_GET_DATA<br />
[2025-03-19 22:46:17.289] [LOG]   Publishing GROWATT data<br />
[2025-03-19 22:47:17.588] [INFO]  Newsfeed-Fetcher: Broadcasting 28 items.<br />
[2025-03-19 22:47:20.690] [LOG]   Shutting down server…<br />
[2025-03-19 22:47:20.696] [LOG]   Stopping module helper: calendar</p>
<p dir="auto">Honestly… I don’t see nothing strange.<br />
But when this error appear, if I left MM on for a day, it wont load calendar entries.</p>
<p dir="auto">I have to restart it one or more time till it show entries</p>
]]></description><link>https://forum.magicmirror.builders/post/125038</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125038</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Wed, 19 Mar 2025 22:14:56 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Wed, 19 Mar 2025 14:13:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> said in <a href="/post/125032">default calendar fetching issues</a>:</p>
<p dir="auto">Do I have to search something in particular?</p>
<p dir="auto">I do not know</p>
<p dir="auto">can you recreate this if un restart MagicMirror?  does it always fail in the morning?</p>
<p dir="auto">pm2 is really for production use,</p>
<p dir="auto">if you can repeat it</p>
<pre><code>pm2 stop all
cd ~/MagicMirror
npm start &amp;&gt;somefile.txt
<p dir="auto">wait til failure<br />
ctrl-q on MagicMirror screen<br />
then examine the somefile.txt</p>
]]></description><link>https://forum.magicmirror.builders/post/125033</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125033</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 19 Mar 2025 14:13:22 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Wed, 19 Mar 2025 14:08:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">It’s very long.</p>
<p dir="auto">I checked the end paragraph ad I saw just errors from growatt module.<br />
]]></description><link>https://forum.magicmirror.builders/post/125032</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125032</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Wed, 19 Mar 2025 14:08:43 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Wed, 19 Mar 2025 13:45:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a></p>
<p dir="auto">ok, on the right branch</p>
<p dir="auto">yes, when run with pm2, then pm2 logs is the way…</p>
<p dir="auto">there are two sections of the output</p>
<p dir="auto">the .error(stderr)  and .out(stdout)</p>
<p dir="auto">can you look in the .out?</p>
<p dir="auto">the folder for the pm2 logs is</p>
<pre><code>~/.pm2/logs
<p dir="auto">note the leading dot on .pm2</p>
]]></description><link>https://forum.magicmirror.builders/post/125031</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125031</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 19 Mar 2025 13:45:41 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Wed, 19 Mar 2025 13:14:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">git branch</p>
<ul>
<li>_fix_clipping<br />
master</li>
</ul>
<p dir="auto">Error appeared now:<br />
" Error in the calendar module. Check logs for more detail."</p>
<p dir="auto">I don’t know where to find calendar logs but with “pm2 logs”<br />
I don’t see any errors information about calendar issue, just something about another module.</p>
<p dir="auto">/home/<strong>MYUSER</strong>/.pm2/logs/mm-error.log last 15 lines:<br />
0|mm       |     socket: {<br />
0|mm       |       localAddress: 'MMIPADDRESS,<br />
0|mm       |       localPort: MMPORT,<br />
0|mm       |       remoteAddress: undefined,<br />
0|mm       |       remotePort: undefined,<br />
0|mm       |       remoteFamily: undefined,<br />
0|mm       |       timeout: undefined,<br />
0|mm       |       bytesWritten: 322,<br />
0|mm       |       bytesRead: 0<br />
0|mm       |     }<br />
0|mm       |   }<br />
0|mm       | }<br />
0|mm       | [2025-03-19 13:30:59.574] [ERROR] Failed to retrieve repo info for MMM-Growatt: Error: Command failed: cd /home/<strong>MYUSER</strong>/MagicMirror/modules/MMM-Growatt &amp;&amp; git fetch -n --dry-run<br />
0|mm       | fatal: unable to access ‘<a href="https://github.com/dekinet/MMM-Growatt.git/" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/dekinet/MMM-Growatt.git/</a>’: Empty reply from server<br />
0|mm       |</p>
<p dir="auto">I don’t think this could be related to calendar issue</p>
]]></description><link>https://forum.magicmirror.builders/post/125030</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125030</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Wed, 19 Mar 2025 13:14:22 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Tue, 18 Mar 2025 20:48:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> to check on the fix</p>
<p dir="auto">in the MagicMirror folder</p>
]]></description><link>https://forum.magicmirror.builders/post/125020</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125020</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Mar 2025 20:48:03 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Tue, 18 Mar 2025 20:35:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I though I applied the fix in the past, although I’m not 100% sure.<br />
But I don’t think the issue is ext3 related.</p>
<p dir="auto">In my opinion sometimes default calendar don’t fetch the calendars, especially at the morning.<br />
When it happen I don’t see any lines and a error message appear.<br />
I don’t remember the message and now it’s working.<br />
In the last one hour I tried to restart MM some times but now seems working, everything ok, no error message.<br />
If it will appear, I’ll write it here</p>
]]></description><link>https://forum.magicmirror.builders/post/125019</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125019</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Tue, 18 Mar 2025 20:35:33 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Tue, 18 Mar 2025 17:31:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> other thing is how ext3 processes  broadcasts</p>
<p dir="auto">it doesn’t want to flash the screen on every update<br />
calendar module procceses each calendar independently, do events arrive at different times</p>
<p dir="auto">there are two settings<br />
waitFetch   how long to wait for All events (5 seconds)<br />
update cycle???  how often to redraw. (30 mjns)</p>
]]></description><link>https://forum.magicmirror.builders/post/125011</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125011</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Mar 2025 17:31:26 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Tue, 18 Mar 2025 16:51:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> default calendar NEVER  displays past events</p>
]]></description><link>https://forum.magicmirror.builders/post/125010</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125010</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Mar 2025 16:51:22 GMT</pubDate></item><item><title><![CDATA[Reply to default calendar fetching issues on Tue, 18 Mar 2025 16:50:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> have you installed the broadcast fix?</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events">https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events</a></p>
]]></description><link>https://forum.magicmirror.builders/post/125009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125009</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Mar 2025 16:50:33 GMT</pubDate></item></channel></rss>
