<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Weather Module showing wrong current temperature]]></title><description><![CDATA[<p dir="auto">MM V2.24.0, Pi Zero2W, Raspbian 10 (Buster)</p>
<p dir="auto">I haven’t made any changes to my magic mirror since the beginning of February. I’m using the default Weather module and haven’t changed any related settings for that in over a year.  The location is showing the correct city. The forecast for the next few days seems correct. The current temperature and today’s high and low are incorrect by about 20F degrees. I’ve tried rebooting and complete shutdown/unplug. Any suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/topic/19552/weather-module-showing-wrong-current-temperature</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 16:31:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19552.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Mar 2025 00:33:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Weather Module showing wrong current temperature on Fri, 21 Mar 2025 16:06:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wyovino" aria-label="Profile: wyovino">@<bdi>wyovino</bdi></a>  The current temperature displaying is now correct. I’m guessing this was an issue at the source.</p>
]]></description><link>https://forum.magicmirror.builders/post/125116</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125116</guid><dc:creator><![CDATA[wyovino]]></dc:creator><pubDate>Fri, 21 Mar 2025 16:06:49 GMT</pubDate></item><item><title><![CDATA[Reply to Weather Module showing wrong current temperature on Fri, 21 Mar 2025 04:02:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">The default value is 10 minutes, so it should never go above the free limit.</p>
]]></description><link>https://forum.magicmirror.builders/post/125086</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125086</guid><dc:creator><![CDATA[wyovino]]></dc:creator><pubDate>Fri, 21 Mar 2025 04:02:46 GMT</pubDate></item><item><title><![CDATA[Reply to Weather Module showing wrong current temperature on Fri, 21 Mar 2025 03:20:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wyovino" aria-label="Profile: wyovino">@<bdi>wyovino</bdi></a> see that in the doc, updateInterval i think</p>
<p dir="auto"><a href="https://docs.magicmirror.builders/modules/weather.html#general-options" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/modules/weather.html#general-options</a></p>
]]></description><link>https://forum.magicmirror.builders/post/125085</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125085</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 21 Mar 2025 03:20:30 GMT</pubDate></item><item><title><![CDATA[Reply to Weather Module showing wrong current temperature on Fri, 21 Mar 2025 02:50:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Do you know how frequently MM reaches out to pull down the weather data? I’d rather not exceed the daily free limit.</p>
]]></description><link>https://forum.magicmirror.builders/post/125084</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125084</guid><dc:creator><![CDATA[wyovino]]></dc:creator><pubDate>Fri, 21 Mar 2025 02:50:14 GMT</pubDate></item><item><title><![CDATA[Reply to Weather Module showing wrong current temperature on Fri, 21 Mar 2025 02:38:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wyovino" aria-label="Profile: wyovino">@<bdi>wyovino</bdi></a> and  that age code you will need need to change code.</p>
<p dir="auto">the api requires v 3, and a different endpoint .</p>
<p dir="auto">i dont know if it will work</p>
]]></description><link>https://forum.magicmirror.builders/post/125083</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125083</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 21 Mar 2025 02:38:24 GMT</pubDate></item><item><title><![CDATA[Reply to Weather Module showing wrong current temperature on Fri, 21 Mar 2025 02:22:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I appreciate your efforts. The reason I’m using a Zero2W is that my mirror is in a tiny bathroom and when I used a Pi4 I could hear the hum of the fan. The Zero2W worked well except for the stock ticker which became very jerky.  For the weather module, maybe I need a new API key. I’ll give that a try.</p>
]]></description><link>https://forum.magicmirror.builders/post/125082</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125082</guid><dc:creator><![CDATA[wyovino]]></dc:creator><pubDate>Fri, 21 Mar 2025 02:22:25 GMT</pubDate></item><item><title><![CDATA[Reply to Weather Module showing wrong current temperature on Fri, 21 Mar 2025 02:00:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wyovino" aria-label="Profile: wyovino">@<bdi>wyovino</bdi></a> i do not know. calendar is my thing</p>
]]></description><link>https://forum.magicmirror.builders/post/125080</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125080</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 21 Mar 2025 02:00:00 GMT</pubDate></item><item><title><![CDATA[Reply to Weather Module showing wrong current temperature on Fri, 21 Mar 2025 01:52:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">The MMM-Jast module doesn’t work properly on a Zero2W with more recent versions which is why I did a fallback to this version. Is this related to the Weather API change I saw in the pinned post?  Here’s my config. The “current” doesn’t work properly but the “forecast” does.</p>
<p dir="auto">{<br />
module: “weather”,<br />
position: “top_right”,<br />
config: {<br />
weatherProvider: “openweathermap”,<br />
type: “current”,<br />
locationID: “5134203”,<br />
apiKey: “{myAPIKey}”<br />
}<br />
},<br />
{<br />
header: “Weather Forecast”,<br />
config: {<br />
type: “forecast”,<br />
apiKey: “{apikey}”,<br />
fade: false<br />
}<br />
},</p>
]]></description><link>https://forum.magicmirror.builders/post/125078</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125078</guid><dc:creator><![CDATA[wyovino]]></dc:creator><pubDate>Fri, 21 Mar 2025 01:52:38 GMT</pubDate></item><item><title><![CDATA[Reply to Weather Module showing wrong current temperature on Fri, 21 Mar 2025 01:24:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wyovino" aria-label="Profile: wyovino">@<bdi>wyovino</bdi></a> 6 releases back, 18 months, who knows.</p>
<p dir="auto">setup a new version and check it out</p>
<p dir="auto">use my backup/restore to help move to new release</p>
<p dir="auto">new nodejs doesnt run on buster</p>
]]></description><link>https://forum.magicmirror.builders/post/125075</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125075</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 21 Mar 2025 01:24:47 GMT</pubDate></item></channel></rss>
