<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Tado - Tado API Login no longer working (403 error) — any fix?]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I hope it’s okay to write in English – it’s not my native language, so please excuse any mistakes 😊</p>
<p dir="auto">I’m currently having issues with the MMM-Tado module. It used to work fine, but now I’m constantly getting the following error:</p>
<p dir="auto">Error: Request failed with status code 403<br />
“error”: “forbidden”,<br />
“error_description”: “Please migrate: <a href="https://support.tado.com/en/articles/8565472-how-do-i-authenticate-to-access-the-rest-api" target="_blank" rel="noopener noreferrer nofollow ugc">https://support.tado.com/en/articles/8565472-how-do-i-authenticate-to-access-the-rest-api</a>”</p>
<p dir="auto">After testing my credentials directly via PowerShell and curl, I found out that Tado has disabled the old OAuth/password login flow, which the current MMM-Tado modules seem to rely on.</p>
<p dir="auto">I tried multiple forks, updated everything, checked my credentials, even tested the API manually – but the result is always the same: 403 Forbidden.</p>
<p dir="auto">MagicMirror logs show this over and over:</p>
<p dir="auto">MMM-Tado: Not all data present</p>
<p dir="auto">So I believe the module is no longer compatible with the latest Tado authentication system.</p>
<p dir="auto">❓Has anyone already fixed this issue or found a workaround?<br />
Maybe someone already updated the module or uses another approach (like a proxy, Home Assistant, or a newer fork)?</p>
<p dir="auto">Thanks a lot in advance 🙏<br />
And again – sorry for my English! 😅</p>
]]></description><link>https://forum.magicmirror.builders/topic/19557/mmm-tado-tado-api-login-no-longer-working-403-error-any-fix</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 21:54:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19557.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 22 Mar 2025 22:00:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Tue, 09 Sep 2025 20:01:18 GMT]]></title><description><![CDATA[<p dir="auto">This is my solution. Just install the <a href="https://github.com/daydy16/MMM-Tado" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/daydy16/MMM-Tado</a><br />
In the config file:</p>
<pre><code>{
		module: 'MMM-Tado',
		position: 'bottom_left', // This can be any of the regions.
		updateInterval: 900000 // miliseconds-15minutes-96times per day &lt; 100
<p dir="auto">After you launch your Mirror with “node --run start”, you receive in the terminal this:</p>
<pre><code>MMM-Tado: Device authentication required. Please visit the following URL:
https://login.tado.com/oauth2/device?user_code=XXXXXX
<p dir="auto">You put that URL in your browser and submit the code. That’s it.<br />
Hope it helps!</p>
]]></description><link>https://forum.magicmirror.builders/post/128189</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128189</guid><dc:creator><![CDATA[mishu28nmv]]></dc:creator><pubDate>Tue, 09 Sep 2025 20:01:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Sat, 05 Apr 2025 09:57:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/det" aria-label="Profile: det">@<bdi>det</bdi></a> I have the same problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/125615</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125615</guid><dc:creator><![CDATA[nero32]]></dc:creator><pubDate>Sat, 05 Apr 2025 09:57:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Mon, 31 Mar 2025 07:29:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chichi1887" aria-label="Profile: chichi1887">@<bdi>chichi1887</bdi></a> said in <a href="/post/125405">MMM-Tado - Tado API Login no longer working (403 error) — any fix?</a>:</p>
<p dir="auto">i Spend now 4 Nights with Chatgpt without Outcome. Only the handle Version change the Bearer works great.</p>
<p dir="auto">Did you find a solution?<br />
Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/125518</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125518</guid><dc:creator><![CDATA[det]]></dc:creator><pubDate>Mon, 31 Mar 2025 07:29:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Sat, 29 Mar 2025 11:11:58 GMT]]></title><description><![CDATA[<p dir="auto">i Spend now 4 Nights with Chatgpt without Outcome. Only the handle Version change the Bearer works great.</p>
]]></description><link>https://forum.magicmirror.builders/post/125405</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125405</guid><dc:creator><![CDATA[chichi1887]]></dc:creator><pubDate>Sat, 29 Mar 2025 11:11:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Wed, 26 Mar 2025 22:24:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hi i reinstall the hole MM Software and use the daydy16 Tado Version but from the beginning with alle the config i became this error <img src="/assets/uploads/files/1743027839503-8857d2f8-4886-4377-ba64-0f68710eaec6-image.png" alt="8857d2f8-4886-4377-ba64-0f68710eaec6-image.png" class=" img-fluid img-markdown" />  what i do wrong</p>
]]></description><link>https://forum.magicmirror.builders/post/125347</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125347</guid><dc:creator><![CDATA[chichi1887]]></dc:creator><pubDate>Wed, 26 Mar 2025 22:24:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Sun, 23 Mar 2025 19:50:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/125153">MMM-Tado - Tado API Login no longer working (403 error) — any fix?</a>:</p>
<p dir="auto">pm2 logs MagicMirror --lines=100</p>
<p dir="auto">OK, the URL is now displayed :-)<br />
I’ll try it out, thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/125163</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125163</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Sun, 23 Mar 2025 19:50:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Sun, 23 Mar 2025 19:12:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> probably need more lines</p>
]]></description><link>https://forum.magicmirror.builders/post/125153</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125153</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 23 Mar 2025 19:12:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Sun, 23 Mar 2025 19:05:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> pm2 logs MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/125151</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125151</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Sun, 23 Mar 2025 19:05:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Sun, 23 Mar 2025 19:00:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> how are you displaying the logs?</p>
]]></description><link>https://forum.magicmirror.builders/post/125150</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125150</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 23 Mar 2025 19:00:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Sun, 23 Mar 2025 17:51:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I’ve now reinstalled it from this site. I can’t find the URL in the logs.</p>
]]></description><link>https://forum.magicmirror.builders/post/125147</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125147</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Sun, 23 Mar 2025 17:51:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Sun, 23 Mar 2025 17:34:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> oh, i see</p>
<p dir="auto">are you sure this new module is installed instead of the one you were trying?</p>
]]></description><link>https://forum.magicmirror.builders/post/125145</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125145</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 23 Mar 2025 17:34:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Sun, 23 Mar 2025 17:19:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I read it, but I can’t find the URL in the logs… :-(</p>
]]></description><link>https://forum.magicmirror.builders/post/125144</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125144</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Sun, 23 Mar 2025 17:19:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Sun, 23 Mar 2025 17:11:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joefranz" aria-label="Profile: JoeFranz">@<bdi>JoeFranz</bdi></a> did you look at the fork</p>
<p dir="auto"><a href="https://github.com/daydy16/MMM-Tado" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/daydy16/MMM-Tado</a></p>
]]></description><link>https://forum.magicmirror.builders/post/125143</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125143</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 23 Mar 2025 17:11:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Sun, 23 Mar 2025 17:07:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mishu28nmv" aria-label="Profile: mishu28nmv">@<bdi>mishu28nmv</bdi></a><br />
What exactly do I need to do to get MMM-Tado working again? I searched the logs for the URL that should be generated, but couldn’t find anything.</p>
]]></description><link>https://forum.magicmirror.builders/post/125142</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125142</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Sun, 23 Mar 2025 17:07:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Sun, 23 Mar 2025 14:04:29 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/WouterEekhout/MMM-Tado/issues/18" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/WouterEekhout/MMM-Tado/issues/18</a><br />
There is a fix from an user. Maybe give it a try 😁</p>
]]></description><link>https://forum.magicmirror.builders/post/125138</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125138</guid><dc:creator><![CDATA[mishu28nmv]]></dc:creator><pubDate>Sun, 23 Mar 2025 14:04:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado - Tado API Login no longer working (403 error) — any fix? on Sun, 23 Mar 2025 11:42:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chichi1887" aria-label="Profile: chichi1887">@<bdi>chichi1887</bdi></a> I have seen that the node-tado-client npmjs package has been updated to v1.0.0 to cater for the new OAuth2 flow. I would suggest opening an issue on the module Github page for the module developer to fix.</p>
]]></description><link>https://forum.magicmirror.builders/post/125134</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125134</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Sun, 23 Mar 2025 11:42:17 GMT</pubDate></item></channel></rss>
