<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fresh install on bookworm only works with X11 - which disables VNC...]]></title><description><![CDATA[<p dir="auto">Hi Team,<br />
may somebody has a hint for me.<br />
I’ve just installed with Sam’s script a complete fresh instance of MagicMirror.<br />
Installation went without any error.<br />
Starting up the mirror gave an error - the startup is called with x11! - for whatever reason.<br />
So I changed with raspi-config wayland to X11 (which I do not want) - mirror starts, all is OK.<br />
The connected HDMI TV is really dark (!) (Webrowser is correctly white on black, shiny) AND: after several minutes screen turns OFF.<br />
(BASE config file, only adapted whitelist and localization, standard template modules displayed)</p>
<p dir="auto">Second issue - with X11 Windows manager enabled I’m not able to connect to the mirror via VNC which I really like and am used to do because it is much faster that the browser and the mouse pointer doesn’t disappear.</p>
<p dir="auto">Any hints for me?</p>
<p dir="auto">Thanks a lot!<br />
Regards,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/topic/19568/fresh-install-on-bookworm-only-works-with-x11-which-disables-vnc...</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 14:16:23 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19568.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Mar 2025 18:51:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fresh install on bookworm only works with X11 - which disables VNC... on Tue, 25 Mar 2025 19:11:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> What i figured out as well is:<br />
VNC viewer in this combination cannot work…</p>
<p dir="auto">So the right way to handle this is:<br />
DISable VNC service in raspi-config (this is the wayland VNC) and ENable the X11 Real VNC server manually with</p>
<pre><code>sudo systemctl enable --now vncserver-x11-serviced
<p dir="auto">Reboot Pi and VNC works again.</p>
<p dir="auto">So I now stick with the dark display …</p>
<p dir="auto">Thanks &amp; warm regards,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/125273</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125273</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Tue, 25 Mar 2025 19:11:34 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install on bookworm only works with X11 - which disables VNC... on Tue, 25 Mar 2025 21:05:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> i think it is ON by default ,  but will retest when i can</p>
]]></description><link>https://forum.magicmirror.builders/post/125288</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125288</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 25 Mar 2025 21:05:21 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install on bookworm only works with X11 - which disables VNC... on Tue, 25 Mar 2025 20:52:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> cool - but had switched to X11 after installation.<br />
But screensaver IS switched off (it seems to me that screensaver is switched off per default - never seen a screenserver on my pis …</p>
]]></description><link>https://forum.magicmirror.builders/post/125287</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125287</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Tue, 25 Mar 2025 20:52:17 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install on bookworm only works with X11 - which disables VNC... on Tue, 25 Mar 2025 20:44:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> if you switched to x11 my screensaveroff script will work</p>
]]></description><link>https://forum.magicmirror.builders/post/125283</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125283</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 25 Mar 2025 20:44:11 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install on bookworm only works with X11 - which disables VNC... on Tue, 25 Mar 2025 20:23:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> :-)<br />
For me it’s currently fine!<br />
All is working and wayland is not needed THAT much :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/125282</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125282</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Tue, 25 Mar 2025 20:23:12 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install on bookworm only works with X11 - which disables VNC... on Tue, 25 Mar 2025 20:15:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> i will fix installer now that new start commands available</p>
]]></description><link>https://forum.magicmirror.builders/post/125280</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125280</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 25 Mar 2025 20:15:33 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install on bookworm only works with X11 - which disables VNC... on Tue, 25 Mar 2025 20:14:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> i do not know how you disable screen blanking via script w labwc</p>
]]></description><link>https://forum.magicmirror.builders/post/125278</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125278</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 25 Mar 2025 20:14:41 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install on bookworm only works with X11 - which disables VNC... on Tue, 25 Mar 2025 19:44:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> Screen switching Off is now disappeared without any reason - did not change anything…</p>
<p dir="auto">Screen darkness still there but may an issue with the modules I never used and this greyish is “normal” …</p>
]]></description><link>https://forum.magicmirror.builders/post/125275</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125275</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Tue, 25 Mar 2025 19:44:48 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install on bookworm only works with X11 - which disables VNC... on Tue, 25 Mar 2025 19:11:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> What i figured out as well is:<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/125273</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125273</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Tue, 25 Mar 2025 19:11:34 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install on bookworm only works with X11 - which disables VNC... on Tue, 25 Mar 2025 19:07:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> :-)<br />
OK good move…<br />
But the startup-command is generated by your install-script, so this is the result of the “auto-start”…<br />
In the meantime I’ve figured out that may X11 is - in priciple - may the better choice for me because I might remember that MMM-Pir ( :-) ) had issues with wayland in context of screen-off …</p>
]]></description><link>https://forum.magicmirror.builders/post/125271</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125271</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Tue, 25 Mar 2025 19:07:46 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install on bookworm only works with X11 - which disables VNC... on Tue, 25 Mar 2025 19:00:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> use the other start commands,</p>
<p dir="auto">message posted and pinned in january in general section</p>
]]></description><link>https://forum.magicmirror.builders/post/125270</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125270</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 25 Mar 2025 19:00:42 GMT</pubDate></item></channel></rss>
