<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-CalendarExt3Agenda doesn&#x27;t work on fresh restored install]]></title><description><![CDATA[<p dir="auto">Good morning,</p>
<p dir="auto">just restored my mirror with restore scripts from Sam (<a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ).<br />
Unfortunately MMM-CalendarExt3Agenda doesn’t show up.<br />
I’ve just installed  the <a href="https://forum.magicmirror.builders/topic/19282/version-2.30.0-calendar-fix-for-clipping-broadcast-events">calendar fix</a> but this doesn’t help:</p>
<pre><code>pi@MagicMirrorPi5:~/MagicMirror $ git switch _fix_clipping
error: Your local changes to the following files would be overwritten by checkout:
	package-lock.json
	package.json
Please commit your changes or stash them before you switch branches.
Aborting
pi@MagicMirrorPi5:~/MagicMirror $ rm package-lock.json
	package.json
Aborting
pi@MagicMirrorPi5:~/MagicMirror $ mv package.json package.json.old
Switched to branch '_fix_clipping'
pi@MagicMirrorPi5:~/MagicMirror $ npm run install-mm
&gt; magicmirror@2.31.0-develop install-mm
&gt; npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
&gt; magicmirror@2.31.0-develop postinstall
&gt; npm run install-vendor &amp;&amp; npm run install-fonts &amp;&amp; echo "MagicMirror² installation finished successfully!
&gt; "
&gt; magicmirror@2.31.0-develop install-vendor
&gt; echo "Installing vendor files ...
&gt; " &amp;&amp; cd vendor &amp;&amp; npm install --loglevel=error --no-audit --no-fund --no-update-notifier
up to date in 369ms
&gt; magicmirror@2.31.0-develop install-fonts
&gt; echo "Installing fonts ...
&gt; " &amp;&amp; cd fonts &amp;&amp; npm install --loglevel=error --no-audit --no-fund --no-update-notifier
up to date in 400ms
&gt; magicmirror@2.31.0-develop prepare
&gt; [ -f node_modules/.bin/husky ] &amp;&amp; husky || echo no husky installed.
no husky installed.
added 1 package, removed 99 packages, and changed 186 packages in 19s
<p dir="auto">I’ve searched logs and found an error:</p>
<pre><code>Cannot GET /modules/MMM-CalendarExt3Agenda/CX3_Shared/CX3_shared.mjs
<p dir="auto">which is true - this directory “CX3_Shared” is empty on my restored version.<br />
on  <a href="modules/MMM-CalendarExt3Agend">github</a> the CX3_Shared directory is linked elsewhere - this is might the reason for not re-installing it correctly…</p>
<p dir="auto">Git pull in $HOME/MagicMirror/modules/MMM-CalendarExt3Agenda doesn’t help either.<br />
What can I do to get it up and running?</p>
<p dir="auto">Thanks for any hint!<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/topic/19571/mmm-calendarext3agenda-doesn-t-work-on-fresh-restored-install</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 19:54:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19571.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Mar 2025 10:45:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda doesn&#x27;t work on fresh restored install on Wed, 26 Mar 2025 12:43:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> can you look at the restore.log for the processing on cx3agenda</p>
<p dir="auto">go to that module folder and do<br />
npm install</p>
<p dir="auto">trying to decide if an npm install is required<br />
this module has no dependencies<br />
but it does have a submodule  which needs to be installed</p>
<p dir="auto">i will fix the tests in restore</p>
]]></description><link>https://forum.magicmirror.builders/post/125313</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125313</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 26 Mar 2025 12:43:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda doesn&#x27;t work on fresh restored install on Fri, 28 Mar 2025 14:11:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> yes, he ran some setup/installer code that isn’t saved locally</p>
]]></description><link>https://forum.magicmirror.builders/post/125387</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125387</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 28 Mar 2025 14:11:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda doesn&#x27;t work on fresh restored install on Wed, 26 Mar 2025 13:40:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> despite getting it “run” it doesn’t work properly :-(<br />
I’m looking around but seems to be hard …</p>
]]></description><link>https://forum.magicmirror.builders/post/125327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125327</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Wed, 26 Mar 2025 13:40:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda doesn&#x27;t work on fresh restored install on Wed, 26 Mar 2025 13:28:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> said in <a href="/post/125325">MMM-CalendarExt3Agenda doesn't work on fresh restored install</a>:</p>
<p dir="auto">I’ve “solved” it with my tar.gz archive.</p>
<p dir="auto">yeh, what about the other 200+ users??   SO much fun</p>
]]></description><link>https://forum.magicmirror.builders/post/125326</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125326</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 26 Mar 2025 13:28:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda doesn&#x27;t work on fresh restored install on Wed, 26 Mar 2025 13:23:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/125321">MMM-CalendarExt3Agenda doesn't work on fresh restored install</a>:</p>
<p dir="auto">you can’t binary back it up either, as there are OS level dependencies</p>
<p dir="auto">I’ve “solved” it with my tar.gz archive.<br />
put all of the working copy in it, extract im MagicMirror/modules and ran npm install in MMM-Pir …</p>
<p dir="auto">Now I’m looking around how to get xandr fixed, because now MMM-Pir increase the screen resolution to maximum which is not desired …</p>
]]></description><link>https://forum.magicmirror.builders/post/125325</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125325</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Wed, 26 Mar 2025 13:23:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda doesn&#x27;t work on fresh restored install on Wed, 26 Mar 2025 13:03:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> said in <a href="/post/125319">MMM-CalendarExt3Agenda doesn't work on fresh restored install</a>:</p>
<p dir="auto">Just frickling around but cannot get this git-cloned from backup-repository …<br />
yes, I only save the LINK to the module repo, which doesn’t exist anymore</p>
<p dir="auto">I produce a warning in the output (and log file) that the url is not available<br />
in both backup and restore…</p>
]]></description><link>https://forum.magicmirror.builders/post/125321</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125321</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 26 Mar 2025 13:03:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda doesn&#x27;t work on fresh restored install on Wed, 26 Mar 2025 13:01:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> pushed fix for restore script to check for postinstall task as well as dependencies</p>
<p dir="auto">the new 3rd party list uses package.json as a documentation vehicle…<br />
but that doesn’t mean npm install is required… try not to do work that isn’t required and not consume disk space for no reason…</p>
]]></description><link>https://forum.magicmirror.builders/post/125320</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125320</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 26 Mar 2025 13:01:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda doesn&#x27;t work on fresh restored install on Wed, 26 Mar 2025 12:55:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> :-)</p>
<p dir="auto">nmp install DOES the trick!</p>
<p dir="auto">(should have come to my mind !!!)</p>
<pre><code>pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CalendarExt3Agenda $ npm install
&gt; mmm-calendarext3agenda@1.4.6 postinstall
&gt; git submodule update --init --recursive
Submodule 'CX3_Shared' (https://github.com/MMRIZE/CX3_Shared) registered for path 'CX3_Shared'
Cloning into '/home/pi/MagicMirror/modules/MMM-CalendarExt3Agenda/CX3_Shared'...
Submodule path 'CX3_Shared': checked out '0b390e2770866533464c81e5b26ff366e9695344'
up to date, audited 1 package in 1s
found 0 vulnerabilities
<p dir="auto">Thanks!<br />
Calendar is present, again!<br />
Nice!</p>
<p dir="auto">Now all I’m missing is MMM-Pir :-)<br />
Just frickling around but cannot get this git-cloned from backup-repository …</p>
<p dir="auto">thanks a LOT!<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/125319</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125319</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Wed, 26 Mar 2025 12:55:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda doesn&#x27;t work on fresh restored install on Wed, 26 Mar 2025 12:51:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> ~/MagicMirror/installers/restore.log</p>
]]></description><link>https://forum.magicmirror.builders/post/125318</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125318</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 26 Mar 2025 12:51:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda doesn&#x27;t work on fresh restored install on Wed, 26 Mar 2025 12:50:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Did not find a restore.log file …<br />
But in <a href="https://forum.magicmirror.builders/post/125308">this post</a> I listed a copy of screen output during restore.</p>
<p dir="auto">it stated “restoring MMM-CalendarExt3Agenda” without engaging npm install …</p>
<p dir="auto">Will give npm install a try…</p>
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/125317</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125317</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Wed, 26 Mar 2025 12:50:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda doesn&#x27;t work on fresh restored install on Wed, 26 Mar 2025 12:43:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> can you look at the restore.log for the processing on cx3agenda</p>
npm install</p>
]]></description><link>https://forum.magicmirror.builders/post/125313</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125313</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 26 Mar 2025 12:43:19 GMT</pubDate></item></channel></rss>
