<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[v2.31.0]]></title><description><![CDATA[<h2>[2.31.0] - 2025-04-01</h2>
<p dir="auto">Thanks to: @Developer-Incoming, @eltociear, @geraki, @khassel, <a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a>, @MagMar94, @mixasgr, <a class="plugin-mentions-user plugin-mentions-a" href="/user/n8many" aria-label="Profile: n8many">@<bdi>n8many</bdi></a>, @OWL4C, <a class="plugin-mentions-user plugin-mentions-a" href="/user/rejas" aria-label="Profile: rejas">@<bdi>rejas</bdi></a>, @savvadam, <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>.</p>
<p dir="auto">⚠️ This release needs nodejs version <code>v22.14.0 or higher</code></p>
<h3>Added</h3>
<ul>
<li>Add CSS support to the digital clock hour/minute/second through the use of the classes <code>clock-hour-digital</code>, <code>clock-minute-digital</code>, and <code>clock-second-digital</code>.</li>
<li>Add Arabic (#3719) and Esperanto translation.</li>
<li>Mark option <code>secondsColor</code> as deprecated in clock module.</li>
<li>Add Greek translation to Alerts module.</li>
<li>[newsfeed] Add specific ignoreOlderThan value (override) per feed (#3360)</li>
<li>[weather] Added option Humidity to hourly View</li>
<li>[weather] Added option to hide hourly entries that are Zero, hiding the entire column if empty.</li>
<li>[updatenotification] Added option to iterate over modules directory instead using modules defined in <code>config.js</code> (#3739)</li>
</ul>
<h3>Changed</h3>
<ul>
<li>[core] starting clientonly now checks for needed env var <code>WAYLAND_DISPLAY</code> or <code>DISPLAY</code> and starts electron with needed parameters (if both are set wayland is used) (#3677)</li>
<li>[core] Optimize systeminformation calls and output (#3689)</li>
<li>[core] Add issue templates for feature requests and bug reports (#3695)</li>
<li>[core] Adapt <code>start:x11:dev</code> script</li>
<li>[weather/yr] The Yr weather provider now enforces a minimum <code>updateInterval</code> of 600 000 ms (10 minutes) to comply with the terms of service. If a lower value is set, it will be automatically increased to this minimum.</li>
<li>[weather/weatherflow] Fixed icons and added hourly support as well as UV, precipitation, and location name support.</li>
<li>[workflow] Run <code>sudo apt-get update</code> before installing packages to avoid install errors</li>
<li>[workflow] Exclude issues with label <code>ready (coming with next release)</code> from stale job</li>
</ul>
<h3>Removed</h3>
<h3>Updated</h3>
<ul>
<li>[core] Update requirements and dependencies including electron to v35 and formatting (#3593, #3693, #3717)</li>
<li>[core] Update prettier, ESLint and simplify config</li>
<li>Update Greek translation</li>
</ul>
<h3>Fixed</h3>
<ul>
<li>[calendar] Fix clipping events being broadcast (#3678)</li>
<li>[tests] Fix Electron tests by running them under new github image ubuntu-24.04, replace xserver with labwc, running under xserver and labwc depending on env variable WAYLAND_DISPLAY is set (#3676)</li>
<li>[calendar] Fix arrayed symbols, #3267, again, add testcase, add testcase for #3678</li>
<li>[weather] Fix wrong weatherCondition name in openmeteo provider which lead to n/a icon (#3691)</li>
<li>[core] Fix wrong port in log message when starting server only (#3696)</li>
<li>[calendar] Fix NewYork event processed on system in Central timezone shows wrong time #3701</li>
<li>[weather/yr] The Yr weather provider is now able to recover from bad API responses instead of freezing (#3296)</li>
<li>[compliments] Fix evening events being shown during the day (#3727)</li>
<li>[weather] Fixed minor spacing issues when using UV Index in Hourly</li>
<li>[workflow] Fix command to run spellcheck</li>
</ul>
<p dir="auto"><a href="https://github.com/MagicMirrorOrg/MagicMirror/releases/tag/v2.31.0" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MagicMirrorOrg/MagicMirror/releases/tag/v2.31.0</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/19590/v2.31.0</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 07:46:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19590.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Apr 2025 19:56:44 GMT</pubDate><ttl>60</ttl></channel></rss>
