<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Version 2.31.0 Error With Upgrade Scripts]]></title><description><![CDATA[<p dir="auto">I used the upgrade script to update my MagicMirror to 2.31.0 from 2.30.0.  It ran into an error and now MagicMirror won’t start.</p>
<p dir="auto">The upgrade log file shows</p>
<p dir="auto">Ver 2.30.0 and Ext3 modules loaded, install fix</p>
<ul>
<li>_fix_clipping<br />
master<br />
updating MagicMirror runtime, please wait<br />
npm error code EACCES<br />
npm error syscall rename<br />
npm error path /home/twist/MagicMirror/node_modules/.ast-types-VPJXcxdi/node_modules/tslib/CopyrightNotice.txt</li>
</ul>
<p dir="auto">and it continues with npm error.</p>
<p dir="auto">Any ideas how to fix this?</p>
]]></description><link>https://forum.magicmirror.builders/topic/19591/version-2.31.0-error-with-upgrade-scripts</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 09:07:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19591.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Apr 2025 14:51:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Version 2.31.0 Error With Upgrade Scripts on Thu, 03 Apr 2025 15:43:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/atwist" aria-label="Profile: atwist">@<bdi>atwist</bdi></a> eaccess denied sounds like you might have run<br />
one of the npm commands w sudo. (never do that)</p>
<p dir="auto">so to fix this you have to do it again to clean up</p>
<pre><code>cd ~/MagicMirror
sudo rm -rf node_modules
cd fonts
sudo rm - rf node_modules
cd ../vendor
<p dir="auto">then run the upgrade script again with</p>
<pre><code>force
<p dir="auto">instead of</p>
<pre><code>apply
<p dir="auto">at the end</p>
]]></description><link>https://forum.magicmirror.builders/post/125578</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125578</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Apr 2025 15:43:08 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.31.0 Error With Upgrade Scripts on Fri, 04 Apr 2025 00:29:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/atwist" aria-label="Profile: atwist">@<bdi>atwist</bdi></a> awesome!</p>
]]></description><link>https://forum.magicmirror.builders/post/125584</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125584</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 04 Apr 2025 00:29:55 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.31.0 Error With Upgrade Scripts on Thu, 03 Apr 2025 23:45:34 GMT]]></title><description><![CDATA[<p dir="auto">I didn’t think i ran it with sudo but apparently i did.  Thank you for your help!!</p>
<p dir="auto">I did try the test first and it didn’t show errors.  But, you got it working!</p>
]]></description><link>https://forum.magicmirror.builders/post/125583</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125583</guid><dc:creator><![CDATA[atwist]]></dc:creator><pubDate>Thu, 03 Apr 2025 23:45:34 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.31.0 Error With Upgrade Scripts on Thu, 03 Apr 2025 15:43:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/atwist" aria-label="Profile: atwist">@<bdi>atwist</bdi></a> eaccess denied sounds like you might have run<br />
cd fonts
cd ../vendor
<pre><code>force
<pre><code>apply
]]></description><link>https://forum.magicmirror.builders/post/125578</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125578</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Apr 2025 15:43:08 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.31.0 Error With Upgrade Scripts on Thu, 03 Apr 2025 14:53:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/atwist" aria-label="Profile: atwist">@<bdi>atwist</bdi></a> can you tell me what you did?</p>
<p dir="auto">note that upgrade is a 2 step process</p>
<p dir="auto">test<br />
do</p>
<p dir="auto">show me the output of ~/MagicMirror/installers/upgrade.log</p>
]]></description><link>https://forum.magicmirror.builders/post/125576</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125576</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Apr 2025 14:53:15 GMT</pubDate></item></channel></rss>
