<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issue with MMM-Config]]></title><description><![CDATA[<p dir="auto">I am getting the following issue with the module MMM-Config<br />
I have updated, reinstalled but it seems the issue persists<br />
[2025-04-08 16:00:14.166] [ERROR] (node:3805) UnhandledPromiseRejectionWarning: Error: An error occured: 404<br />
at buildFormData (/home/johanba/MagicMirror/modules/MMM-Config/module_installer/runserver.js:138:11)<br />
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)<br />
(Use <code>electron --trace-warnings ...</code> to show where the warning was created)<br />
[2025-04-08 16:00:14.167] [ERROR] (node:3805) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag <code>--unhandled-rejections=strict</code> (see <a href="https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode" target="_blank" rel="noopener noreferrer nofollow ugc">https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode</a>). (rejection id: 1)</p>
]]></description><link>https://forum.magicmirror.builders/topic/19597/issue-with-mmm-config</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 22:16:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19597.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 Apr 2025 14:03:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issue with MMM-Config on Fri, 18 Apr 2025 21:52:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johanba" aria-label="Profile: Johanba">@<bdi>Johanba</bdi></a> did you get this resolved?</p>
]]></description><link>https://forum.magicmirror.builders/post/125950</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125950</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 18 Apr 2025 21:52:18 GMT</pubDate></item><item><title><![CDATA[Reply to Issue with MMM-Config on Wed, 16 Apr 2025 11:35:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johanba" aria-label="Profile: Johanba">@<bdi>Johanba</bdi></a> just git clone. the improvements have all been incorporated</p>
]]></description><link>https://forum.magicmirror.builders/post/125894</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125894</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 16 Apr 2025 11:35:53 GMT</pubDate></item><item><title><![CDATA[Reply to Issue with MMM-Config on Wed, 16 Apr 2025 11:02:18 GMT]]></title><description><![CDATA[<p dir="auto">HI<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> getting the following message<br />
johanba@raspberrypi:~/MagicMirror/modules/MMM-Config $ git pull<br />
Your configuration specifies to merge with the ref ‘refs/heads/better_repo_url’<br />
from the remote, but no such ref was fetched.</p>
]]></description><link>https://forum.magicmirror.builders/post/125893</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125893</guid><dc:creator><![CDATA[Johanba]]></dc:creator><pubDate>Wed, 16 Apr 2025 11:02:18 GMT</pubDate></item><item><title><![CDATA[Reply to Issue with MMM-Config on Fri, 11 Apr 2025 01:05:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johanba" aria-label="Profile: Johanba">@<bdi>Johanba</bdi></a> did you get this resolved?</p>
]]></description><link>https://forum.magicmirror.builders/post/125736</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125736</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 11 Apr 2025 01:05:58 GMT</pubDate></item><item><title><![CDATA[Reply to Issue with MMM-Config on Tue, 08 Apr 2025 21:04:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johanba" aria-label="Profile: Johanba">@<bdi>Johanba</bdi></a> the url changed, can you go to the MMM-Config folder and do<br />
git pull<br />
to update</p>
<p dir="auto">then restart MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/125669</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125669</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 08 Apr 2025 21:04:00 GMT</pubDate></item><item><title><![CDATA[Reply to Issue with MMM-Config on Tue, 08 Apr 2025 15:23:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johanba" aria-label="Profile: Johanba">@<bdi>Johanba</bdi></a> on the road</p>
]]></description><link>https://forum.magicmirror.builders/post/125666</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125666</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 08 Apr 2025 15:23:16 GMT</pubDate></item></channel></rss>
