<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[troubleshooting]]></title><description><![CDATA[<p dir="auto">I have a few MagicMirror installs going and I just love them.   I notice that some config.js file edits will be applied with a MagicMirror reload(ctrl-r), some wont take without a complete program close and restart.   What edits require a restart and what requires a reload and how can you check?  How can I troubleshoot those things?</p>
<p dir="auto">I have  a latest install that I am configuring a calendar for my dad, and I can not get the clock to take edits.  No change that I make will be applied.  Not even with a whole restart.  I am not sure how to troubleshoot this.</p>
<p dir="auto">Rob</p>
]]></description><link>https://forum.magicmirror.builders/topic/19612/troubleshooting</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 00:40:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19612.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Apr 2025 04:14:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to troubleshooting on Sun, 13 Apr 2025 22:51:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  those wake up in the night thoughts may be some of my best work… lol…</p>
<p dir="auto">Thanks again!</p>
]]></description><link>https://forum.magicmirror.builders/post/125820</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125820</guid><dc:creator><![CDATA[rob73]]></dc:creator><pubDate>Sun, 13 Apr 2025 22:51:51 GMT</pubDate></item><item><title><![CDATA[Reply to troubleshooting on Sun, 13 Apr 2025 21:08:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rob73" aria-label="Profile: rob73">@<bdi>rob73</bdi></a> cool was thinking missing config section</p>
<p dir="auto">hate those wake up in the night thoughts</p>
]]></description><link>https://forum.magicmirror.builders/post/125818</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125818</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Apr 2025 21:08:22 GMT</pubDate></item><item><title><![CDATA[Reply to troubleshooting on Sun, 13 Apr 2025 21:00:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>   That makes sense to me about reloading the page and not restarting the modules and things.</p>
<p dir="auto">I figured out the calendar config.   I was leaving out the config {} section and just adding the options right under the module: “clock” &amp; position:“top_left”.</p>
<p dir="auto">I looked at that over and over and compared to examples and I couldnt figure it out to save my life.   I woke up in the middle of the night and took a look at it again and it jumped out at me.</p>
<p dir="auto">Thanks for the responses.</p>
]]></description><link>https://forum.magicmirror.builders/post/125817</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125817</guid><dc:creator><![CDATA[rob73]]></dc:creator><pubDate>Sun, 13 Apr 2025 21:00:49 GMT</pubDate></item><item><title><![CDATA[Reply to troubleshooting on Sun, 13 Apr 2025 14:12:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rob73" aria-label="Profile: rob73">@<bdi>rob73</bdi></a> oh, some ctrl-r</p>
<p dir="auto">ctrl-r only reloads the web page, its does not restart any of the node_helpers some modules use</p>
<p dir="auto">node_helpers only get loaded at startup</p>
<p dir="auto">example. weather is all in browser, calendar uses a node_helper to get data<br />
so ctrl-r will reload weather completely<br />
if you changed the calendar config to add/remove a calendar, then ctrl-r will NOT do that<br />
so, you have to look a the module implementation to see how you need to restart</p>
]]></description><link>https://forum.magicmirror.builders/post/125797</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125797</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Apr 2025 14:12:32 GMT</pubDate></item><item><title><![CDATA[Reply to troubleshooting on Sun, 13 Apr 2025 12:23:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rob73" aria-label="Profile: rob73">@<bdi>rob73</bdi></a> show the module structure for clock in config. js please</p>
]]></description><link>https://forum.magicmirror.builders/post/125796</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125796</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Apr 2025 12:23:58 GMT</pubDate></item><item><title><![CDATA[Reply to troubleshooting on Sun, 13 Apr 2025 11:36:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rob73" aria-label="Profile: rob73">@<bdi>rob73</bdi></a> the pm2 app can restart on config change, and my installer sets it up that way.</p>
<p dir="auto">however it doesn’t work reliably on any platform.<br />
i made changes last year to solve this, and its works sometimes</p>
]]></description><link>https://forum.magicmirror.builders/post/125792</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125792</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Apr 2025 11:36:40 GMT</pubDate></item></channel></rss>
