<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Homeassistant-sensors doesn&#x27;t work anymore, recommended alternative.]]></title><description><![CDATA[<p dir="auto">I use <a href="https://github.com/Snille/MMM-homeassistant-sensors" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Snille/MMM-homeassistant-sensors</a> but after the last update of Home assistant it doesn’t work anymore (the program crashes after some seconds with an error about javascript being out of memory. So i was wondering if anyone had any suggested alternatives? There is another module named the same, I don’t know if that causes issues when it gets installed? Will it overwrite files? <a href="https://github.com/ledsi/MMM-homeassistant-sensors" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/ledsi/MMM-homeassistant-sensors</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/19618/mmm-homeassistant-sensors-doesn-t-work-anymore-recommended-alternative.</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 10:28:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19618.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Apr 2025 16:36:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Homeassistant-sensors doesn&#x27;t work anymore, recommended alternative. on Wed, 16 Apr 2025 09:35:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/flac_rules" aria-label="Profile: flac_rules">@<bdi>flac_rules</bdi></a><br />
If you git-pull the second one - which seems to have the exact same name - the git-clone (&lt;- edited!)  will fail.<br />
But if you rename the „original“ directory with e.g.</p>
<pre><code>mv MMM-homeassistant-sensors MMM-homeassistant-sensors_original
<p dir="auto">you should be able to issue a git clone (&lt;- edited)  for the second variant, install this and give it a try.<br />
If t his doesn‘t work, either - delete the newly created directory and re-rename the original one …</p>
<p dir="auto">Regards,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/125860</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125860</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Wed, 16 Apr 2025 09:35:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Homeassistant-sensors doesn&#x27;t work anymore, recommended alternative. on Sun, 20 Apr 2025 10:41:34 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. Renaming the folders worked fine.</p>
]]></description><link>https://forum.magicmirror.builders/post/125982</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125982</guid><dc:creator><![CDATA[flac_rules]]></dc:creator><pubDate>Sun, 20 Apr 2025 10:41:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Homeassistant-sensors doesn&#x27;t work anymore, recommended alternative. on Wed, 16 Apr 2025 09:36:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/125861">MMM-Homeassistant-sensors doesn't work anymore, recommended alternative.</a>:</p>
<p dir="auto">git clone</p>
<p dir="auto">Dear Sam, you are SO right!<br />
Sorry - typo …<br />
Have edited above in my first post.<br />
Thanks for paying attention!</p>
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/125886</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125886</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Wed, 16 Apr 2025 09:36:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Homeassistant-sensors doesn&#x27;t work anymore, recommended alternative. on Wed, 16 Apr 2025 11:33:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> not git pull after rename, git clone to get the first copy</p>
<p dir="auto">two different source repos, cant merge them</p>
]]></description><link>https://forum.magicmirror.builders/post/125861</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125861</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 16 Apr 2025 11:33:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Homeassistant-sensors doesn&#x27;t work anymore, recommended alternative. on Wed, 16 Apr 2025 09:35:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/flac_rules" aria-label="Profile: flac_rules">@<bdi>flac_rules</bdi></a><br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/125860</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125860</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Wed, 16 Apr 2025 09:35:41 GMT</pubDate></item></channel></rss>
