<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Modul SQL Problem mit Variable]]></title><description><![CDATA[<p dir="auto">Hallo.</p>
<p dir="auto">Folgendes Script zeigt keine Ausgabe.</p>
<pre><code>{
            module: 'MMM-MysqlQuery',
			      header: "Schulferien in den naechsten 14 Tagen",
            heute: "curdate(Y-m-d)",
                connection: {
                    host: "192.168.2.71",
                    port: "3306",
                    user: "pi",
                    password: "PW",
                    database: "ferien"
                query: "SELECT ferienart, startdatum, enddatum FROM schulferien WHERE startdatum &lt;= 'heute' AND enddatum &gt;= 'heute' AND ferienart LIKE '%nordrhein%'",
    			intervalSeconds: 1 * 3600,
                emptyMessage: "Keine Schulferien in den naechsten 14 Tagen",
                columns: [
                    { name: "ferienart",           title: "Ferienart",  cssClass: "left" },
                    { name: "startdatum",          title: "Start", cssClass: "left" },
                    { name: "enddatum",            title: "Ende",      cssClass: "left" }
Es müssten die Osterferien angezeigt werden.
Stattdessen erscheint die Empty Message.</code></pre>
]]></description><link>https://forum.magicmirror.builders/topic/19634/modul-sql-problem-mit-variable</link><generator>RSS for Node</generator><lastBuildDate>Sun, 13 Sep 2026 18:12:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19634.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 24 Apr 2025 16:25:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Modul SQL Problem mit Variable on Sun, 27 Apr 2025 15:06:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris47803" aria-label="Profile: chris47803">@<bdi>chris47803</bdi></a> :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/126057</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126057</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Sun, 27 Apr 2025 15:06:56 GMT</pubDate></item><item><title><![CDATA[Reply to Modul SQL Problem mit Variable on Sun, 27 Apr 2025 08:53:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a></p>
<p dir="auto">In meiner Datenbank steht nordrhein.<br />
Ich bin auch kein Programmierer.<br />
Den Code habe ich von ChatGPT :)</p>
]]></description><link>https://forum.magicmirror.builders/post/126056</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126056</guid><dc:creator><![CDATA[chris47803]]></dc:creator><pubDate>Sun, 27 Apr 2025 08:53:28 GMT</pubDate></item><item><title><![CDATA[Reply to Modul SQL Problem mit Variable on Fri, 25 Apr 2025 10:14:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris47803" aria-label="Profile: chris47803">@<bdi>chris47803</bdi></a> Ist es gelöst?</p>
<p dir="auto">Mein Tip wäre gewesen, dass der LIKE Oprator case-sensitiv ist, daher “%nordrhein%” nicht gefunden wird, da es “%Nordrhein” heißen müsste…</p>
<ul>
<li>Wie hast Du es tatsächlich gelöst?</li>
</ul>
<p dir="auto">Gruß,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/126021</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126021</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Fri, 25 Apr 2025 10:14:55 GMT</pubDate></item><item><title><![CDATA[Reply to Modul SQL Problem mit Variable on Fri, 25 Apr 2025 09:39:40 GMT]]></title><description><![CDATA[<p dir="auto">Hat sich erledigt.</p>
<pre><code>{
        connection: {
            port: "3306",
            user: "pi",
            password: "PW",
            database: "ferien"
        query: "SELECT ferienart, DATE_FORMAT(startdatum, '%d.%m.%Y') AS startdatum, DATE_FORMAT(enddatum, '%d.%m.%Y') AS enddatum FROM schulferien
            WHERE (
                  startdatum BETWEEN CURDATE() AND DATE_ADD(CURDATE(), INTERVAL 14 DAY)
                  OR CURDATE() BETWEEN startdatum AND enddatum
              AND YEAR(startdatum) = YEAR(CURDATE())
              AND YEAR(enddatum) = YEAR(CURDATE())
        intervalSeconds: 1 * 3600, // Aktualisierung jede Stunde
        columns: [
]]></description><link>https://forum.magicmirror.builders/post/126023</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126023</guid><dc:creator><![CDATA[chris47803]]></dc:creator><pubDate>Fri, 25 Apr 2025 09:39:40 GMT</pubDate></item></channel></rss>
