<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Outlook.com calendar]]></title><description><![CDATA[<p dir="auto">Hello all,</p>
<p dir="auto">I’m having trouble with my calendar.  It was working beautifully for a very long time.  But suddenly about a month ago it started randomly posting “no upcoming events” even when there were some.</p>
<p dir="auto">Sometimes a reboot would solve the issue.  Other times it wouldn’t.  As time has gone by it’s been harder and harder to get my calendar events to display.  It’s almost like it’s looking at a wrong calendar, though I’m not sure how that’s possible.</p>
<p dir="auto">I saw somewhere else on the forums that switching to webcal seems to help with <a href="http://outlook.com" target="_blank" rel="noopener noreferrer nofollow ugc">outlook.com</a> calendars, but that hasn’t seem to have helped.</p>
<p dir="auto">Any help?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/1964/outlook-com-calendar</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 00:38:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1964.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Mar 2017 18:50:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Outlook.com calendar on Sun, 22 Nov 2020 12:17:48 GMT]]></title><description><![CDATA[<p dir="auto">hello, I am using an outlook addon which is gsyncit to synchronize my outlook calendar to gmail calendar. no problem with the mirror which contains the gmail calendar.</p>
]]></description><link>https://forum.magicmirror.builders/post/84913</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84913</guid><dc:creator><![CDATA[bigjojo]]></dc:creator><pubDate>Sun, 22 Nov 2020 12:17:48 GMT</pubDate></item><item><title><![CDATA[Reply to Outlook.com calendar on Sat, 21 Nov 2020 06:30:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/killing-joke" aria-label="Profile: killing-joke">@<bdi>killing-joke</bdi></a> <em>How</em> does it work? Are you using the “Export to Gmail” method mentioned above or some other method?</p>
]]></description><link>https://forum.magicmirror.builders/post/84893</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84893</guid><dc:creator><![CDATA[EveningStarNM]]></dc:creator><pubDate>Sat, 21 Nov 2020 06:30:08 GMT</pubDate></item><item><title><![CDATA[Reply to Outlook.com calendar on Sun, 14 Jun 2020 18:48:23 GMT]]></title><description><![CDATA[<p dir="auto">Just in case someone is looking for the ability to use the <a href="http://outlook.com" target="_blank" rel="noopener noreferrer nofollow ugc">outlook.com</a> calender.<br />
It works but unfortunately without any birthdays (if the birthdays are part of the contacts).</p>
]]></description><link>https://forum.magicmirror.builders/post/77067</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77067</guid><dc:creator><![CDATA[killing joke]]></dc:creator><pubDate>Sun, 14 Jun 2020 18:48:23 GMT</pubDate></item><item><title><![CDATA[Reply to Outlook.com calendar on Thu, 09 Mar 2017 21:49:33 GMT]]></title><description><![CDATA[<p dir="auto">Ah yeah, unfortunately <a href="http://outlook.com" target="_blank" rel="noopener noreferrer nofollow ugc">outlook.com</a> has removed the ability to export calendar for some dumb reason.  Seems to have happened after the server changes, and their helpfiles have not been updated.</p>
<p dir="auto">I fired up Outlook 2016 (the program), loaded up the account and used that to export the calendar.</p>
]]></description><link>https://forum.magicmirror.builders/post/16949</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16949</guid><dc:creator><![CDATA[Canterrain]]></dc:creator><pubDate>Thu, 09 Mar 2017 21:49:33 GMT</pubDate></item><item><title><![CDATA[Reply to Outlook.com calendar on Thu, 09 Mar 2017 21:45:20 GMT]]></title><description><![CDATA[<p dir="auto">Nevermind, I ended up adding (not importing the calendar to my google calendar) and then got the share .ics link from there</p>
]]></description><link>https://forum.magicmirror.builders/post/16947</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16947</guid><dc:creator><![CDATA[spacevolt]]></dc:creator><pubDate>Thu, 09 Mar 2017 21:45:20 GMT</pubDate></item><item><title><![CDATA[Reply to Outlook.com calendar on Thu, 09 Mar 2017 21:36:25 GMT]]></title><description><![CDATA[<p dir="auto">I just tried hooking up my outlook calendar as well to end up having the same issue. Can you share how you exported to gmail? thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/16943</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16943</guid><dc:creator><![CDATA[spacevolt]]></dc:creator><pubDate>Thu, 09 Mar 2017 21:36:25 GMT</pubDate></item><item><title><![CDATA[Reply to Outlook.com calendar on Sat, 04 Mar 2017 23:16:08 GMT]]></title><description><![CDATA[<p dir="auto">Closing this.  I ended up exporting to a gmail calendar, which instantly worked.  My best guess is that <a href="http://Outlook.com" target="_blank" rel="noopener noreferrer nofollow ugc">Outlook.com</a> is doing something different that the magic mirror code doesn’t account for.  A bit of a pain to make the switch, but now it works.</p>
]]></description><link>https://forum.magicmirror.builders/post/16471</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16471</guid><dc:creator><![CDATA[Canterrain]]></dc:creator><pubDate>Sat, 04 Mar 2017 23:16:08 GMT</pubDate></item></channel></rss>
