<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-SmartWebDisplay is not running under 2.31.0]]></title><description><![CDATA[<p dir="auto">After the update to MM 2.31.0 MMM-SmartWebDisplay is gone. All the other modules don´t make any problems.<br />
Any Idea??</p>
]]></description><link>https://forum.magicmirror.builders/topic/19657/mmm-smartwebdisplay-is-not-running-under-2.31.0</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 12:02:23 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19657.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 May 2025 13:42:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-SmartWebDisplay is not running under 2.31.0 on Fri, 16 May 2025 21:02:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/volkae" aria-label="Profile: Volkae">@<bdi>Volkae</bdi></a> Odd… What is the output if you run <code>git tag</code> in the directory <code>~/MagicMirror/modules/MMM-PublicTransportHafas</code>? Did you run <code>git checkout v3.1.8</code> in <code>~/MagicMirror/modules/MMM-PublicTransportHafas</code>?</p>
]]></description><link>https://forum.magicmirror.builders/post/126526</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126526</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Fri, 16 May 2025 21:02:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SmartWebDisplay is not running under 2.31.0 on Fri, 16 May 2025 13:24:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a><br />
not able to do this:</p>
<p dir="auto">&lt;error: Pfadspezifikation ‘v3.1.8’ stimmt mit keinen git-bekannten Dateien überein&gt;</p>
]]></description><link>https://forum.magicmirror.builders/post/126520</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126520</guid><dc:creator><![CDATA[Volkae]]></dc:creator><pubDate>Fri, 16 May 2025 13:24:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SmartWebDisplay is not running under 2.31.0 on Wed, 14 May 2025 22:12:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/volkae" aria-label="Profile: Volkae">@<bdi>Volkae</bdi></a><br />
<a href="https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas/issues/207#issuecomment-2855504360" target="_blank" rel="noopener noreferrer nofollow ugc">Here</a> you can find a quick and dirty approach to get an older version of MMM-PublicTransportHafas to run. I would prefer a cleaner solution, but I currently lack the capacity to dive deeper into this problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/126498</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126498</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Wed, 14 May 2025 22:12:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SmartWebDisplay is not running under 2.31.0 on Mon, 12 May 2025 04:45:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a><br />
Oh, I see.<br />
RTSP-Stream is running under 2.27.0.</p>
<p dir="auto">Now MMM-SmartWebdisplay is only running under 2.27.0 and MMM-PublicTransportHafas is only running under 2.31.0 ☹️</p>
]]></description><link>https://forum.magicmirror.builders/post/126459</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126459</guid><dc:creator><![CDATA[Volkae]]></dc:creator><pubDate>Mon, 12 May 2025 04:45:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SmartWebDisplay is not running under 2.31.0 on Sun, 11 May 2025 09:16:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/volkae" aria-label="Profile: Volkae">@<bdi>Volkae</bdi></a> I can’t get an rtsp stream work with MMM-SmartWebDisplay neither with MM 2.30.0 nor with 2.31.0. With <a href="https://github.com/evroom/MMM-MPlayer" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-MPlayer</a> it works, but that module doesn’t have the same features as MMM-SmartWebDisplay.</p>
]]></description><link>https://forum.magicmirror.builders/post/126438</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126438</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Sun, 11 May 2025 09:16:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SmartWebDisplay is not running under 2.31.0 on Sat, 10 May 2025 09:26:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a><br />
I made a complete MM-new install on a new SD-Card. With your url it works. With my url it does not work. On my other MM with 2.30.0 my url works fine.</p>
]]></description><link>https://forum.magicmirror.builders/post/126421</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126421</guid><dc:creator><![CDATA[Volkae]]></dc:creator><pubDate>Sat, 10 May 2025 09:26:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SmartWebDisplay is not running under 2.31.0 on Wed, 07 May 2025 20:22:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
okay, sorry, I will do my very best next time</p>
]]></description><link>https://forum.magicmirror.builders/post/126333</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126333</guid><dc:creator><![CDATA[Volkae]]></dc:creator><pubDate>Wed, 07 May 2025 20:22:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SmartWebDisplay is not running under 2.31.0 on Wed, 07 May 2025 20:19:45 GMT]]></title><description><![CDATA[<p dir="auto">With a <code>https</code> address the module works on my system with MM v2.30.0 and v2.31.0. Does it work if you use a <code>https</code> address instead a <code>rtsp</code> one?</p>
<p dir="auto">Like this:</p>
<pre><code class="language-js">url: ["https://www.openstreetmap.org/export/embed.html?bbox=-151.34765625000003%2C-39.77476948529546%2C142.20703125000003%2C75.00494000767517&amp;amp;layer=mapnik"],
]]></description><link>https://forum.magicmirror.builders/post/126332</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126332</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Wed, 07 May 2025 20:19:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SmartWebDisplay is not running under 2.31.0 on Wed, 07 May 2025 19:59:46 GMT]]></title><description><![CDATA[<p dir="auto">@Volkaeplease always use code block for config and log info</p>
<p dir="auto">paste text into message editor, blank line above and below<br />
select text just paste<br />
hit button &lt;/&gt;<br />
to wrap selection in code block</p>
]]></description><link>https://forum.magicmirror.builders/post/126327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126327</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 07 May 2025 19:59:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SmartWebDisplay is not running under 2.31.0 on Wed, 07 May 2025 19:57:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code class="language-js">{
                module: 'MMM-SmartWebDisplay',
                position: 'middle_center',      // This can be any of the regions.
                        logDebug: false, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
                        height:"600px", //hauteur du cadre en pixel ou %
                        width:"400px", //largeur
                        updateInterval: 0, //in min. Set it to 0 for no refresh (for videos)
                        NextURLInterval: 0, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                        displayLastUpdate: false, //to display the last update of the URL
                                        displayLastUpdateFormat: 'ddd - HH:mm:ss', //format of the date and time to display
                        url: ["rtsp://XXXXXXXXXXXXXXXXXXX/h264Preview_01_sub"], //source of the URL to be displayed
                                        scrolling: "no", // allow scrolling or not. html 4 only
                                        shutoffDelay: 10000 //delay in miliseconds to video shut-off while using together with MMM-PIR-Sensor
]]></description><link>https://forum.magicmirror.builders/post/126326</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126326</guid><dc:creator><![CDATA[Volkae]]></dc:creator><pubDate>Wed, 07 May 2025 19:57:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SmartWebDisplay is not running under 2.31.0 on Wed, 07 May 2025 13:59:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/volkae" aria-label="Profile: Volkae">@<bdi>Volkae</bdi></a> can you show the config of the module?</p>
<p dir="auto">if you look at the developer window (ctrl-shift-i) console tab<br />
can you see any errors , add smart to the filter field</p>
]]></description><link>https://forum.magicmirror.builders/post/126301</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126301</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 07 May 2025 13:59:15 GMT</pubDate></item></channel></rss>
