<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Wallpaper - wrong path]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I git clones in modules director and np install in MMM-Wallpaper director. When I run MM, it seems to look into a wrong path to give this error:</p>
<p dir="auto">[WARN]  No /home/sankum/MagicMirror/modules/MMM-WallPaper/MMM-WallPaper.js found for module: MMM-WallPaper.</p>
<p dir="auto">The path should be modules/MMM-WallPaper and not modules/MMM-WallPaper/MMM-WallPaper.<br />
What is the issue here and how to fix this? Tried uninstalling and installing again, but same result.  Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19719/mmm-wallpaper-wrong-path</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 14:34:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19719.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Jun 2025 20:42:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Wallpaper - wrong path on Tue, 03 Jun 2025 23:48:53 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the replies. I did make a spelling error in config.js;, MMM-WallPaper where it should have been MMM-Wallpaper. Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/126864</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126864</guid><dc:creator><![CDATA[sankum]]></dc:creator><pubDate>Tue, 03 Jun 2025 23:48:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wallpaper - wrong path on Tue, 03 Jun 2025 22:14:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sankum" aria-label="Profile: sankum">@<bdi>sankum</bdi></a> said in <a href="/post/126860">MMM-Wallpaper - wrong path</a>:</p>
<p dir="auto">There is no module “MMM-WallPaper” (with a <code>P</code> instead of a <code>p</code>) on the module list. Please show what <code>git remote -v</code> outputs when you are in the module’s directory. Did you spell it right in your config file?</p>
]]></description><link>https://forum.magicmirror.builders/post/126863</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126863</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Tue, 03 Jun 2025 22:14:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wallpaper - wrong path on Tue, 03 Jun 2025 22:12:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sankum" aria-label="Profile: sankum">@<bdi>sankum</bdi></a> said in <a href="/post/126860">MMM-Wallpaper - wrong path</a>:</p>
<p dir="auto">MMM-WallPaper</p>
<p dir="auto">Is there a MMM-Wallpaper.js in the cd MagicMirror/modules/MMM-Wallpaper folder if so<br />
try<br />
sudo reboot<br />
If not fixed, in the MagicMirror/modules folder use “rm -rf MMM-Wallpaper”<br />
and try the<br />
“git clone <a href="https://github.com/kolbyjack/MMM-Wallpaper.git" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/kolbyjack/MMM-Wallpaper.git</a>”<br />
again in the MagicMirror/modules folder.<br />
do not forget to do the<br />
cd MMM-Wallpaper<br />
npm install<br />
When it is finished loading.<br />
if that fails you may have a faulty card.<br />
I have had many fail me through out the years.<br />
I went to a small external usb drive to get around that problem.<br />
If none of this works let us know and maybe someone smarter than me will step in.</p>
<p dir="auto">If this does work for you mark it solved please.</p>
]]></description><link>https://forum.magicmirror.builders/post/126862</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126862</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Tue, 03 Jun 2025 22:12:57 GMT</pubDate></item></channel></rss>
