<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pm2 dont start my scripts on startup]]></title><description><![CDATA[<p dir="auto">i install the pm2 to run the magicmirror on startup.<br />
If i manually run pm2 start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a>,the magicmirror start working,but it doesn´t do it on startup<br />
Im on a R pi3</p>
]]></description><link>https://forum.magicmirror.builders/topic/1973/pm2-dont-start-my-scripts-on-startup</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 05:38:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1973.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 Mar 2017 14:04:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pm2 dont start my scripts on startup on Mon, 06 Mar 2017 16:05:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> said in <a href="/post/16623">Pm2 dont start my scripts on startup</a>:</p>
<p dir="auto">pm2 logs mm --lines 50</p>
<p dir="auto">/home/pi/.pm2/logs/mm-error-0.log last 50 lines:<br />
0|mm       |     at Module.load (module.js:473:32)<br />
0|mm       |     at tryModuleLoad (module.js:432:12)<br />
0|mm       |     at Function.Module._load (module.js:424:3)<br />
0|mm       |     at Module.require (module.js:483:17)<br />
0|mm       |     at require (internal/module.js:20:19)<br />
0|mm       |     at Object. (/home/pi/MagicMirror/modules/magic-mirror-voice/node_modules/java/lib/nodeJavaBridge.js:21:16)<br />
0|mm       |     at Module._compile (module.js:556:32)<br />
0|mm       |     at Object.Module._extensions…js (module.js:565:10)<br />
0|mm       | ERROR! Could not find main module js file.<br />
0|mm       | Error: Module version mismatch. Expected 50, got 48.<br />
0|mm       |     at Error (native)<br />
0|mm       |     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)<br />
0|mm       |     at Object.Module._extensions…node (module.js:583:18)<br />
0|mm       |     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)<br />
0|mm       |     at Module.require (module.js:483:17)</p>
<p dir="auto">[STREAMING] Now streaming realtime logs for [mm] process</p>
]]></description><link>https://forum.magicmirror.builders/post/16625</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16625</guid><dc:creator><![CDATA[michael24h]]></dc:creator><pubDate>Mon, 06 Mar 2017 16:05:14 GMT</pubDate></item><item><title><![CDATA[Reply to Pm2 dont start my scripts on startup on Mon, 06 Mar 2017 15:41:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roramirez" aria-label="Profile: roramirez">@<bdi>roramirez</bdi></a> said in <a href="/post/16514">Pm2 dont start my scripts on startup</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/theusu5k" aria-label="Profile: theusu5k">@<bdi>theusu5k</bdi></a> What said when  you run ?</p>
<pre><code>pm2 list
<p dir="auto">nothing,if i manually run it,it appears</p>
]]></description><link>https://forum.magicmirror.builders/post/16624</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16624</guid><dc:creator><![CDATA[theusu5k]]></dc:creator><pubDate>Mon, 06 Mar 2017 15:41:41 GMT</pubDate></item><item><title><![CDATA[Reply to Pm2 dont start my scripts on startup on Mon, 06 Mar 2017 15:32:07 GMT]]></title><description><![CDATA[<p dir="auto">ok, please run <code>pm2 logs mm --lines 50</code><br />
MagicMirror found an error, maybe due to a broken module or missing dependencies.</p>
]]></description><link>https://forum.magicmirror.builders/post/16623</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16623</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Mon, 06 Mar 2017 15:32:07 GMT</pubDate></item><item><title><![CDATA[Reply to Pm2 dont start my scripts on startup on Mon, 06 Mar 2017 15:17:20 GMT]]></title><description><![CDATA[<p dir="auto">This is my log pm2</p>
<p dir="auto">2017-03-03 17:07:49: Starting execution sequence in -fork mode- for app name:mm id:0<br />
2017-03-03 17:07:49: App name:mm id:0 online<br />
2017-03-04 14:31:00: Stopping app:mm id:0<br />
2017-03-04 14:31:01: App [mm] with id [0] and pid [1239], exited with code [0] via signal [SIGINT]<br />
2017-03-04 14:31:01: pid=1239 msg=process killed<br />
2017-03-04 14:31:01: Starting execution sequence in -fork mode- for app name:mm id:0<br />
2017-03-04 14:31:01: App name:mm id:0 online<br />
2017-03-04 14:32:40: Stopping app:mm id:0<br />
2017-03-04 14:32:40: App [mm] with id [0] and pid [32472], exited with code [0] via signal [SIGINT]<br />
2017-03-04 14:32:40: pid=32472 msg=process killed<br />
2017-03-04 14:32:40: Starting execution sequence in -fork mode- for app name:mm id:0<br />
2017-03-04 14:32:40: App name:mm id:0 online<br />
2017-03-04 14:34:13: Stopping app:mm id:0<br />
2017-03-04 14:34:14: App [mm] with id [0] and pid [32720], exited with code [0] via signal [SIGINT]<br />
2017-03-04 14:34:14: pid=32720 msg=process killed<br />
2017-03-04 14:34:14: Starting execution sequence in -fork mode- for app name:mm id:0<br />
2017-03-04 14:34:14: App name:mm id:0 online<br />
2017-03-06 14:49:55: ===============================================================================<br />
2017-03-06 14:49:55: — New PM2 Daemon started ----------------------------------------------------<br />
2017-03-06 14:49:55: Time                 : Mon Mar 06 2017 14:49:55 GMT+0000 (UTC)<br />
2017-03-06 14:49:55: PM2 version          : 2.4.2<br />
2017-03-06 14:49:55: Node.js version      : 6.10.0<br />
2017-03-06 14:49:55: Current arch         : arm<br />
2017-03-06 14:49:55: PM2 home             : /home/pi/.pm2<br />
2017-03-06 14:49:55: PM2 PID file         : /home/pi/.pm2/pm2.pid<br />
2017-03-06 14:49:55: RPC socket file      : /home/pi/.pm2/rpc.sock<br />
2017-03-06 14:49:55: BUS socket file      : /home/pi/.pm2/pub.sock<br />
2017-03-06 14:49:55: Application log path : /home/pi/.pm2/logs<br />
2017-03-06 14:49:55: Process dump file    : /home/pi/.pm2/dump.pm2<br />
2017-03-06 14:49:55: Concurrent actions   : 2<br />
2017-03-06 14:49:55: SIGTERM timeout      : 1600<br />
2017-03-06 14:49:56: Starting execution sequence in -fork mode- for app name:mm id:0<br />
2017-03-06 14:49:56: App name:mm id:0 online<br />
2017-03-06 15:07:51: Stopping app:mm id:0<br />
2017-03-06 15:07:51: App [mm] with id [0] and pid [1137], exited with code [0] via signal [SIGINT]<br />
2017-03-06 15:07:51: pid=1137 msg=process killed<br />
2017-03-06 15:07:51: Starting execution sequence in -fork mode- for app name:mm id:0<br />
2017-03-06 15:07:51: App name:mm id:0 online</p>
]]></description><link>https://forum.magicmirror.builders/post/16622</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16622</guid><dc:creator><![CDATA[michael24h]]></dc:creator><pubDate>Mon, 06 Mar 2017 15:17:20 GMT</pubDate></item><item><title><![CDATA[Reply to Pm2 dont start my scripts on startup on Mon, 06 Mar 2017 15:07:30 GMT]]></title><description><![CDATA[<p dir="auto">pm2 logs mm</p>
<p dir="auto"><img src="/assets/uploads/files/1488812843756-screen-shot-2017-03-06-at-15.06.31.png" alt="0_1488812842768_Screen Shot 2017-03-06 at 15.06.31.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/16620</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16620</guid><dc:creator><![CDATA[michael24h]]></dc:creator><pubDate>Mon, 06 Mar 2017 15:07:30 GMT</pubDate></item><item><title><![CDATA[Reply to Pm2 dont start my scripts on startup on Mon, 06 Mar 2017 15:01:22 GMT]]></title><description><![CDATA[<p dir="auto">That all, after pm2 show mm</p>
<p dir="auto"><img src="/assets/uploads/files/1488812320681-screen-shot-2017-03-06-at-14.57.44.png" alt="0_1488812320040_Screen Shot 2017-03-06 at 14.57.44.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/16618</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16618</guid><dc:creator><![CDATA[michael24h]]></dc:creator><pubDate>Mon, 06 Mar 2017 15:01:22 GMT</pubDate></item><item><title><![CDATA[Reply to Pm2 dont start my scripts on startup on Mon, 06 Mar 2017 14:56:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael24h" aria-label="Profile: michael24h">@<bdi>michael24h</bdi></a><br />
and what is <code>pm2 logs mm</code> saying?</p>
]]></description><link>https://forum.magicmirror.builders/post/16617</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16617</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Mon, 06 Mar 2017 14:56:51 GMT</pubDate></item><item><title><![CDATA[Reply to Pm2 dont start my scripts on startup on Mon, 06 Mar 2017 14:54:52 GMT]]></title><description><![CDATA[<p dir="auto">same problem I have<br />
<img src="/assets/uploads/files/1488812086151-screen-shot-2017-03-06-at-14.53.20.png" alt="0_1488812086004_Screen Shot 2017-03-06 at 14.53.20.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/16615</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16615</guid><dc:creator><![CDATA[michael24h]]></dc:creator><pubDate>Mon, 06 Mar 2017 14:54:52 GMT</pubDate></item><item><title><![CDATA[Reply to Pm2 dont start my scripts on startup on Sun, 05 Mar 2017 15:39:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/theusu5k" aria-label="Profile: theusu5k">@<bdi>theusu5k</bdi></a> What said when  you run ?</p>
<pre><code>pm2 list
]]></description><link>https://forum.magicmirror.builders/post/16514</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16514</guid><dc:creator><![CDATA[roramirez]]></dc:creator><pubDate>Sun, 05 Mar 2017 15:39:02 GMT</pubDate></item></channel></rss>
