<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Electron error?  js error? Javascrpt error?]]></title><description><![CDATA[<p dir="auto">Hi i’m training to run MM on a raspberry pi, this is my first trying something like this and seeing this much code, when i tried npm run start i get all of this errors, tried to update things and its giving me the same error, should I just tried a fresh install? thanks for the help guys.</p>
<p dir="auto">dayzwell@raspberrypi:~/MagicMirror $ npm run start</p>
<p dir="auto">magicmirror@2.31.0 start<br />
npm run start:x11</p>
<p dir="auto">magicmirror@2.31.0 start:x11<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
<p dir="auto">[2025-06-16 12:46:38.249] [ERROR] App threw an error during load<br />
[2025-06-16 12:46:38.259] [ERROR] ReferenceError: ReadableStream is not defined<br />
at Object. (/home/dayzwell/MagicMirror/node_modules/undici/lib/web/fetch/webidl.js:471:58)<br />
at Module._compile (node:internal/modules/cjs/loader:1141:14)<br />
at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)<br />
at Module.load (node:internal/modules/cjs/loader:1011:32)<br />
at Module._load (node:internal/modules/cjs/loader:846:12)<br />
at f._load (node:electron/js2c/asar_bundle:2:13377)<br />
at Module.require (node:internal/modules/cjs/loader:1035:19)<br />
at require (node:internal/modules/cjs/helpers:102:18)<br />
at Object. (/home/dayzwell/MagicMirror/node_modules/undici/lib/web/fetch/util.js:12:20)<br />
A JavaScript error occurred in the main process<br />
Uncaught Exception:<br />
MESA-LOADER: failed to retrieve device information<br />
os_same_file_description couldn’t determine if two DRM fds reference the same file description. (Function not implemented)<br />
Let’s just assume that file descriptors for the same file probablyshare the file description instead. This may cause problems whenthat isn’t the case.<br />
[4820:0616/114639.047070:ERROR:gbm_wrapper.cc(255)] Failed to export buffer to dma_buf: No such file or directory (2)</p>
]]></description><link>https://forum.magicmirror.builders/topic/19736/electron-error-js-error-javascrpt-error</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 08:53:37 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19736.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Jun 2025 18:19:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Electron error?  js error? Javascrpt error? on Tue, 17 Jun 2025 22:52:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dayzwell" aria-label="Profile: Dayzwell">@<bdi>Dayzwell</bdi></a> I see his instructions left out a step.<br />
I opened this issue <a href="https://github.com/xadamxk/MMM-LOLESPORTS-SCHEDULES/issues/8" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/xadamxk/MMM-LOLESPORTS-SCHEDULES/issues/8</a></p>
<p dir="auto">he has updated the instructions</p>
]]></description><link>https://forum.magicmirror.builders/post/127027</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127027</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 Jun 2025 22:52:54 GMT</pubDate></item><item><title><![CDATA[Reply to Electron error?  js error? Javascrpt error? on Wed, 18 Jun 2025 20:04:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dayzwell" aria-label="Profile: Dayzwell">@<bdi>Dayzwell</bdi></a> awesome!!</p>
]]></description><link>https://forum.magicmirror.builders/post/127032</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127032</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Jun 2025 20:04:01 GMT</pubDate></item><item><title><![CDATA[Reply to Electron error?  js error? Javascrpt error? on Wed, 18 Jun 2025 18:42:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thak you it works now :)</p>
]]></description><link>https://forum.magicmirror.builders/post/127031</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127031</guid><dc:creator><![CDATA[Dayzwell]]></dc:creator><pubDate>Wed, 18 Jun 2025 18:42:11 GMT</pubDate></item><item><title><![CDATA[Reply to Electron error?  js error? Javascrpt error? on Tue, 17 Jun 2025 22:52:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dayzwell" aria-label="Profile: Dayzwell">@<bdi>Dayzwell</bdi></a> I see his instructions left out a step.<br />
]]></description><link>https://forum.magicmirror.builders/post/127027</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127027</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 Jun 2025 22:52:54 GMT</pubDate></item><item><title><![CDATA[Reply to Electron error?  js error? Javascrpt error? on Tue, 17 Jun 2025 13:25:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dayzwell" aria-label="Profile: Dayzwell">@<bdi>Dayzwell</bdi></a>  ok, so lets start over a little</p>
<p dir="auto">for that module in config.js add</p>
<pre><code>disabled:true,
<p dir="auto">after its module: line</p>
<p dir="auto">and then do</p>
<pre><code>cd ~/MagicMirror
git checkout package.json
rm -rf node_modules
npm run install-mm
<p dir="auto">then try</p>
<pre><code>npm start
]]></description><link>https://forum.magicmirror.builders/post/127025</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127025</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 Jun 2025 13:25:33 GMT</pubDate></item><item><title><![CDATA[Reply to Electron error?  js error? Javascrpt error? on Tue, 17 Jun 2025 04:09:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Im using a raspberry 3 using Raspberry Pi OS, I install and update the MM and it work until i tried to install this module <a href="https://github.com/xadamxk/MMM-LOLESPORTS-SCHEDULES" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/xadamxk/MMM-LOLESPORTS-SCHEDULES</a> update electron and everething I could find and now its giving me those errors</p>
]]></description><link>https://forum.magicmirror.builders/post/127024</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127024</guid><dc:creator><![CDATA[Dayzwell]]></dc:creator><pubDate>Tue, 17 Jun 2025 04:09:28 GMT</pubDate></item><item><title><![CDATA[Reply to Electron error?  js error? Javascrpt error? on Mon, 16 Jun 2025 18:34:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dayzwell" aria-label="Profile: Dayzwell">@<bdi>Dayzwell</bdi></a> can you tell us what you  did to setup and install MagicMirror. what system and  OS  this is</p>
]]></description><link>https://forum.magicmirror.builders/post/127021</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127021</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 16 Jun 2025 18:34:44 GMT</pubDate></item></channel></rss>
