<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror wakes TV from HDMI-CEC sleep even when set to idle]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">I am running MagicMirror on a Raspberry Pi connected to a TV via HDMI; using HDMI-CEC so the screen can turn off when idle. It works  but the moment MagicMirror updates a module (like weather or calendar), the TV wakes up unexpectedly; even though no user interaction happens &amp; the Pi itself is idle.</p>
<p dir="auto">I have already disabled mouse movement; set the screensaver &amp; tested various xset &amp; vcgencmd commands but the HDMI signal still seems to “ping” the TV during certain background activities.</p>
<p dir="auto">I want the TV to stay off unless there’s real user input  ideally keeping background updates silent. Checked <a href="https://forum.magicmirror.builders/topic/15153/wake-up-hibernate-display">https://forum.magicmirror.builders/topic/15153/wake-up-hibernate-display-</a> <a href="https://www.igmguru.com/big-data/splunk-training" target="_blank" rel="noopener noreferrer nofollow ugc">Splunk online training</a> guide related to this and found helpful.</p>
<p dir="auto">Has anyone managed to prevent MagicMirror from waking the HDMI display due to CEC/HDMI activity alone? Would love advice on whether it’s a module issue; electron/browser behavior, or if there’s a Pi/CEC flag to block this sort of unintended wake-up.</p>
<p dir="auto">Thak you !!</p>
]]></description><link>https://forum.magicmirror.builders/topic/19741/magicmirror-wakes-tv-from-hdmi-cec-sleep-even-when-set-to-idle</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 19:23:17 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19741.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 23 Jun 2025 11:26:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror wakes TV from HDMI-CEC sleep even when set to idle on Mon, 23 Jun 2025 12:53:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schlomm" aria-label="Profile: schlomm">@<bdi>schlomm</bdi></a> he is using the cec-client command which sends a command to the monitor firmware</p>
]]></description><link>https://forum.magicmirror.builders/post/127057</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127057</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 23 Jun 2025 12:53:35 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror wakes TV from HDMI-CEC sleep even when set to idle on Mon, 23 Jun 2025 12:25:44 GMT]]></title><description><![CDATA[<p dir="auto">Which comand to you use to turn of the monitor? Which OS do you use?<br />
For controlling the monitor I use <code>wlr-randr --output HDMI-A-1 --off</code> on Raspberry Pi OS Bookworm…</p>
<p dir="auto">Actually I’ve set up two mirrors last week. One turns the monitor off without any issues, the other one turns off the monitor, and wakes the monitor a few seconds later. Basically the same issue which you’ve observed.<br />
I have no clue what makes the difference; maybe I’ve performed a <code>apt-get full-upgrade</code> on the second host, so any changes are applied here…</p>
]]></description><link>https://forum.magicmirror.builders/post/127056</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127056</guid><dc:creator><![CDATA[schlomm]]></dc:creator><pubDate>Mon, 23 Jun 2025 12:25:44 GMT</pubDate></item></channel></rss>
