<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AfterUpdate to v2.3.2    Small Problem]]></title><description><![CDATA[<p dir="auto">The numbers used to be orange also.<br />
Now as you can see it is not getting any color in the numbers.<br />
I even moved the custom css from my <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> backup.  That I did just before the update.  Thank you Sam…</p>
<pre><code>.clock.clock-time-only .time {
        Margin-right: 15px;
        Margin-top: 0px;
        Color: orange;
        Font-size: 125px;
        Font-weight: 500;
<p dir="auto"><img src="/assets/uploads/files/1751565997574-screenshot-2025-07-03-130441.png" alt="Screenshot 2025-07-03 130441.png" class=" img-fluid img-markdown" width="178" height="99" /></p>
<p dir="auto">So far this is the only problem I have had…  That I could not figure out real quickly.   I will say I had to rename MagicMirror to MM and reinstall MagicMirror. Then move Config.js Custom.css and modules over to the new MagicMirror install all pretty quick.   I had a blank screen.  I figured it was the least amount of work for me… Again Thanks to <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> backup.  Saves the most important parts of MagicMirror…</p>
]]></description><link>https://forum.magicmirror.builders/topic/19761/afterupdate-to-v2.3.2-small-problem</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 05:36:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19761.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Jul 2025 18:14:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AfterUpdate to v2.3.2    Small Problem on Fri, 04 Jul 2025 23:29:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thank you Sam,<br />
That fixed my issue,  and let me use the default clock files…<br />
Cool thing is with the old setting in the Custom.css file I can change the colon : color between the numbers a different color.<br />
Fun Fun Fun.</p>
]]></description><link>https://forum.magicmirror.builders/post/127256</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127256</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Fri, 04 Jul 2025 23:29:03 GMT</pubDate></item><item><title><![CDATA[Reply to AfterUpdate to v2.3.2    Small Problem on Fri, 04 Jul 2025 02:56:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> yes, no need to get it from a variable, you know</p>
]]></description><link>https://forum.magicmirror.builders/post/127242</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127242</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 04 Jul 2025 02:56:12 GMT</pubDate></item><item><title><![CDATA[Reply to AfterUpdate to v2.3.2    Small Problem on Fri, 04 Jul 2025 02:34:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
So just replace  “var(–color-text-bright)”  with my preferred colors?</p>
]]></description><link>https://forum.magicmirror.builders/post/127241</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127241</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Fri, 04 Jul 2025 02:34:03 GMT</pubDate></item><item><title><![CDATA[Reply to AfterUpdate to v2.3.2    Small Problem on Thu, 03 Jul 2025 21:29:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> yes, we changed the style names from the sample I did</p>
<p dir="auto">Just change your custom.css to use those names</p>
]]></description><link>https://forum.magicmirror.builders/post/127237</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127237</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Jul 2025 21:29:13 GMT</pubDate></item><item><title><![CDATA[Reply to AfterUpdate to v2.3.2    Small Problem on Thu, 03 Jul 2025 20:49:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Sorry I already deleted that folder MM that I renamed MagicMirror to.</p>
<p dir="auto">Found the issue, the NEW default clock_styles.css has these extra lines compared to the older default clock_styles.css file.</p>
<pre><code>.module.clock .clock-hour-digital {
  color: var(--color-text-bright);
.module.clock .clock-minute-digital {
.module.clock .clock-second-digital {
  color: var(--color-text-dimmed);
<p dir="auto">If I remove those lines my time on screen looks right again…<br />
Which will mess up the next update probably…<br />
At least I know what to repair to do the update next round.</p>
]]></description><link>https://forum.magicmirror.builders/post/127235</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127235</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Thu, 03 Jul 2025 20:49:51 GMT</pubDate></item><item><title><![CDATA[Reply to AfterUpdate to v2.3.2    Small Problem on Thu, 03 Jul 2025 20:37:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> send me the MagicMirror/installers/upgrade.log</p>
<p dir="auto">Same userid as here, at gmail</p>
]]></description><link>https://forum.magicmirror.builders/post/127234</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127234</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Jul 2025 20:37:29 GMT</pubDate></item><item><title><![CDATA[Reply to AfterUpdate to v2.3.2    Small Problem on Thu, 03 Jul 2025 18:44:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
1st I used your backup script.<br />
Then I tried using your upgrade script and it stopped at the updating of the node version. Just set there for like an hour.  I went outside and did some yard work.<br />
I then rebooted the pi and did pm2 stop all<br />
Then tried your upgrade script again and it froze again on the node update.<br />
Waited about 30 minutes to see if it was a internet problem.<br />
Then I did ctrl+c<br />
Then I tried your script with “force” then it ran all the way through.<br />
BUT it came up a black screen.<br />
I did not feel like trying to figure out why it was a blank screen.<br />
So I just renamed the MagicMirror to MM and then used your install script.<br />
That fully installed without any input from me, I went out and finished the yard work I was doing.  NO user input.<br />
I cam back in and it was working with the sample config.js<br />
Then I just moved the config.js and custom.css over from the backup and the modules from the MM (previous did not work) and rebooted now all is woking.<br />
Not sure why it had so much of a stumble going from node v 20 to v22.14<br />
I will say I updated from MM v2.3.0 to MM v2.3.2  maybe that was the problem…<br />
I should have took some screen shots for you, so you could see the issues…<br />
Weird part is the update script worked perfect on the other to MM I have running 1 is on a LePotato  1 is a pi 4 2gb<br />
I will say the time thing did the same thing on the other pi 4,  I am using the same time date seperation in both pi.  So i figure it is something that was updated in the default clock code and does not get updated with my old custom.css code.</p>
]]></description><link>https://forum.magicmirror.builders/post/127233</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127233</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Thu, 03 Jul 2025 18:44:44 GMT</pubDate></item><item><title><![CDATA[Reply to AfterUpdate to v2.3.2    Small Problem on Thu, 03 Jul 2025 18:20:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> how did you upgrade?</p>
]]></description><link>https://forum.magicmirror.builders/post/127232</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127232</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Jul 2025 18:20:08 GMT</pubDate></item></channel></rss>
