<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Pinfo Help]]></title><description><![CDATA[<p dir="auto">I am having an issue with the display being different from one Pi to another.<br />
<img src="/assets/uploads/files/1751745746336-myscreenpinfo.png" alt="MyScreenPinfo.png" class="img-markdown  img-fluid" width="391" height="234" /><br />
<img src="/assets/uploads/files/1751745746352-defaultt.png" alt="Defaultt.png" class="img-markdown  img-fluid" width="294" height="231" /><br />
Mine is having issues with the dual lines.<br />
both are running the same configurations…</p>
]]></description><link>https://forum.magicmirror.builders/topic/19766/mmm-pinfo-help</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 22:47:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19766.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 05 Jul 2025 20:12:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Pinfo Help on Wed, 09 Jul 2025 01:34:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a><br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Never mind I am stupid.<br />
I figured out that I had removed several sections of the config file that was in his readme.  Then went and re numbered the lines.<br />
Which really upset the apple cart.<br />
I did have to change the parts you said <a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a>.<br />
But the rest was my doing.  Compare the first Config i posted and this one and you will see what I did.</p>
<pre><code>                {
                        module: "MMM-Pinfo",
                        position: "middle_center",
                          debug: false,
                          refresh: 5000,
                          itemAlign: "left",
                          labelAlign: "left",
 valueAlign: "right",
labelSize: 400,
containerSize: 500,
                          DEVICE: {
                                labelModel: "Model",
                                displayModel: true,
                                orderModel: 1,
                                labelSerial: "Serial",
                                displaySerial: true,
                                orderSerial: 2
                          OS: {
                                labelOs: "OS",
                                displayOs: true,
                                orderOs: 3
                          NETWORK: {
                                labelType: "NET Type",
                                displayType: true,
                                orderType: 4,
                                labelIPv4: "IPv4",
                                displayIPv4: true,
                                orderIPv4: 5,
                                labelIPv6: "IPv6",
I deleted these 2 lines and then changed orderMac: 6  and so on down the
List..
DISPLAYIPV6: FALSE,
ORDERIPV6: 6,
                                labelMac: "MAC",
                                displayMac: true,
                                orderMac: 7
                          RAM: {
                                labelRam: "RAM",
                                displayRam: true,
                                orderRam: 8
                          STORAGE: {
                                labelStorage: "Storage",
                                displayStorage: true,
                                orderStorage: 9,
                          CPU: {
                                labelType: "CPU Type",
                                displayType: true,
                                orderType: 10,
                                labelUsage: "CPU Usage",
                                displayUsage: true,
                                orderUsage: 11,
                                labelTemp: "CPU Temp",
                                displayTemp: true,
                                orderTemp: 12
                          UPTIME: {
                                labelUptime: "Uptime",
                                displayUptime: true,
                                orderUptime: 13
                          WARNING: {
                                enable: true,
                                interval: 1000 * 60 * 5,
                                check: {
                                  CPU_TEMP: 65,
                                  CPU_USAGE: 75,
                                  RAM_USED: 80,
                                  STORAGE_USED: 80
]]></description><link>https://forum.magicmirror.builders/post/127309</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127309</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Wed, 09 Jul 2025 01:34:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Pinfo Help on Wed, 09 Jul 2025 00:20:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a>  <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Here is what I have in my config.js and custom.css</p>
<pre><code>                {
                          debug: false,
                          refresh: 10000,
                          itemAlign: "left",
                          labelAlign: "left",
                          labelSize: "60px", //null,
                          containerSize: "180px",
                         DEVICE: {
                                labelModel: "Model:",
                                displayModel: true,
                                orderModel: 1,
                         OS: {
                                labelOs: "OS:",
                                displayOs: true,
                                orderOs: 2
                         NETWORK: {
                                labelType: "NET Type:",
                                displayType: true,
                                orderType: 3,
                                labelIPv4: "IPv4:",
                                displayIPv4: true,
                                orderIPv4: 4,
                                labelMac: "MAC:",
                                displayMac: true,
                                orderMac: 5
                         RAM: {
                                labelRam: "RAM:",
                                displayRam: true,
                                orderRam: 6
                         STORAGE: {
                                labelStorage: "Storage:",
                                orderStorage: 7,
                         CPU: {
                                labelType: "CPU Type:",
                                displayType: true,
                                orderType: 8,
                                labelUsage: "CPU Usage:",
                                displayUsage: true,
                                orderUsage: 9,
                                labelTemp: "CPU Temp:",
                                displayTemp: true,
                                orderTemp: 10
                         UPTIME: {
                                  labelUptime: "Uptime:",
                                  orderUptime: 11
<p dir="auto">CUSTOM.CSS    ##########</p>
<pre><code>.Pinfo {
        font-size: 50px;
        line-height: 55px;
<p dir="auto">And this is what I get</p>
<p dir="auto"><img src="/assets/uploads/files/1752020057099-mmm-pinfoproblem1.png" alt="MMM-PinfoProblem1.png" class="img-markdown  img-fluid" width="666" height="632" /></p>
I tried changing the left to right and the size of the container from 80 to 1800 with absolutely no change.</p>
<p dir="auto">I made a test config.js so I could only have it on screen to test with.<br />
Doesn’t seem to matter what I change in the config.js It stays the same .<br />
I remove the lines from my custom.css and it is still the same only very small on my screen…  42" TV…  The really weird part is it looks fine on my pi w2</p>
]]></description><link>https://forum.magicmirror.builders/post/127304</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127304</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Wed, 09 Jul 2025 00:20:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Pinfo Help on Sun, 06 Jul 2025 09:47:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a><br />
This time actually not a CSS issue :-)</p>
<p dir="auto">If I‘m not going wrong and remember correctly, I had a similar problem with MMM-Pinfo.<br />
There is a configuration option in the module-declaration in config.js.<br />
I‘ve set containerSize to 180.<br />
And valueAlign to right.</p>
<p dir="auto">This solved the shown overlayed look …</p>
<p dir="auto">And your labels are aligned „center“ - this I would set to left (labelAlign is the parameter)</p>
<p dir="auto">HTH,<br />
Warm regards,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/127274</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127274</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Sun, 06 Jul 2025 09:47:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Pinfo Help on Sat, 05 Jul 2025 20:30:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> css?</p>
]]></description><link>https://forum.magicmirror.builders/post/127271</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127271</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 05 Jul 2025 20:30:40 GMT</pubDate></item></channel></rss>
