<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Weather module to show Metric and Imperial at same time]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
<p dir="auto">I tried to search the forum without success…</p>
<p dir="auto">I am currently using 2 different instance of the basic Weather Module to display the current weather.  I am looking for a way to trim that down a little bit removing duplicate informations and icons.</p>
<p dir="auto">In ideal world, I would like to display the current and feel’s like temp, in a form of 23.2 / 73.8 or similar. As long as the sides informations and icons are not duplicated.</p>
<p dir="auto">If anyone is aware of a way to do it or a module that can display in a similar manner, I would be happy to know.</p>
<p dir="auto">Again, sorry if I am asking an already answered question!<br />
Cheers!<br />
<img src="/assets/uploads/files/1752685630064-screenshot-2025-07-16-124828.jpg" alt="Screenshot 2025-07-16 124828.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/19776/weather-module-to-show-metric-and-imperial-at-same-time</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 12:53:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19776.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Jul 2025 17:10:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Weather module to show Metric and Imperial at same time on Wed, 16 Jul 2025 17:16:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ray_mtl" aria-label="Profile: ray_mtl">@<bdi>ray_mtl</bdi></a> there are quite a number of config options to show (or not) different weather components</p>
<p dir="auto">see <a href="https://docs.magicmirror.builders/modules/weather.html#general-options" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/modules/weather.html#general-options</a></p>
<p dir="auto">if you need more control, you can use css to select those elements to hide and set display:none;</p>
<p dir="auto">you can use the developer window, elements tab to discover and test settings to determine what needs to go into css/custom.css</p>
<p dir="auto">see the second link in my signature before for a starter on using the elements tab</p>
]]></description><link>https://forum.magicmirror.builders/post/127378</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127378</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 16 Jul 2025 17:16:11 GMT</pubDate></item></channel></rss>
