<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-ImagesPhotos]]></title><description><![CDATA[<p dir="auto">Hey everyone! I’m having a bit of trouble with the MMM-ImagesPhotos module. I keep getting this error:</p>
<p dir="auto">No MagicMirror/modules/MMM-ImagesPhotos/MMM-ImagesPhotos.js found for module: MMM-ImagesPhotos.</p>
<p dir="auto">and then</p>
<p dir="auto">No helper found for module: MMM-ImagesPhotos.</p>
<p dir="auto">However, I’ve made sure that the js file is inside that module and even installed and uninstalled it a few times. It’s still not working - the rest of my modules are loading but this one isn’t :(</p>
<p dir="auto">I just started working on my first MagicMirror yesterday so would really appreciate some help.</p>
<p dir="auto">Thanks everyone!</p>
]]></description><link>https://forum.magicmirror.builders/topic/19795/mmm-imagesphotos</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 23:45:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19795.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Jul 2025 19:48:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-ImagesPhotos on Sat, 26 Jul 2025 17:10:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/starz22" aria-label="Profile: starz22">@<bdi>starz22</bdi></a> weird i use imagesPhotos myself</p>
]]></description><link>https://forum.magicmirror.builders/post/127564</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127564</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 26 Jul 2025 17:10:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos on Sat, 26 Jul 2025 17:01:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Alright so after 2 days of trying to debug this, I just used a different slideshow module (MMM-ImageSlideshow) and somehow that worked for me. Thank you for all of your help <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>!!</p>
]]></description><link>https://forum.magicmirror.builders/post/127562</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127562</guid><dc:creator><![CDATA[starz22]]></dc:creator><pubDate>Sat, 26 Jul 2025 17:01:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos on Sat, 26 Jul 2025 18:38:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Here’s the output for the ls -laF inside the module:</p>
<pre><code class="language-text">total 268
drwxr-xr-x  6 starz starz   4096 Jul 26 01:17 ./
drwxr-xr-x 10 starz starz   4096 Jul 26 01:01 ../
-rw-r--r--  1 starz starz    596 Jul 25 19:41 CHANGELOG.md
-rw-r--r--  1 starz starz   1160 Jul 25 19:41 .eslintrc.json
drwxr-xr-x  8 starz starz   4096 Jul 26 08:56 .git/
drwxr-xr-x  2 starz starz   4096 Jul 25 19:41 .github/
-rw-r--r--  1 starz starz     53 Jul 25 19:41 .gitignore
-rw-r--r--  1 starz starz   1094 Jul 25 19:41 LICENSE
-rw-r--r--  1 starz starz     54 Jul 25 19:41 .markdownlint.json
-rw-r--r--  1 starz starz    398 Jul 25 19:41 MMM-ImagesPhotos.css
-rw-r--r--  1 starz starz  10214 Jul 26 01:17 MMM-ImagesPhotos.js
-rw-r--r--  1 starz starz   4629 Jul 25 19:41 node_helper.js
-rw-r--r--  1 starz starz   1185 Jul 25 19:41 package.json
-rw-r--r--  1 starz starz 189128 Jul 25 19:41 package-lock.json
-rw-r--r--  1 starz starz   2833 Jul 25 19:41 README.md
-rw-r--r--  1 starz starz    176 Jul 25 19:41 .stylelintrc.json
drwxr-xr-x  2 starz starz   4096 Jul 25 19:41 translations/
drwxr-xr-x  2 starz starz   4096 Jul 26 00:41 uploads/
<p dir="auto">Same person is logged in now - I’m the only person using this raspberry pi. And I never used sudo - I followed the instructions in the readme.</p>
]]></description><link>https://forum.magicmirror.builders/post/127563</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127563</guid><dc:creator><![CDATA[starz22]]></dc:creator><pubDate>Sat, 26 Jul 2025 18:38:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos on Sat, 26 Jul 2025 13:33:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/starz22" aria-label="Profile: starz22">@<bdi>starz22</bdi></a> yeh, confusing</p>
<p dir="auto">ls -laF</p>
<p dir="auto">inside the MMM-ImagesPhotos folder<br />
who is logged on now, vs when you did the git clone?</p>
<p dir="auto">never use sudo right?</p>
]]></description><link>https://forum.magicmirror.builders/post/127561</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127561</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 26 Jul 2025 13:33:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos on Sat, 26 Jul 2025 13:01:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I used the sample config from the readme, and then when that didn’t work, just various different ones that changed like the opacity and fill. However, I think the problem might be coming from here since I’m getting this error every time I run it with npm -</p>
<p dir="auto">[2025-07-26 08:56:04.585] [WARN]  No /home/starz/MagicMirror/modules/MMM‑ImagesPhotos/MMM‑ImagesPhotos.js found for module: MMM‑ImagesPhotos.</p>
<p dir="auto">But of course, there is a JS file inside the module - it just seems like its not being read. It’s pretty confounding because all of my other modules work perfectly fine.</p>
]]></description><link>https://forum.magicmirror.builders/post/127560</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127560</guid><dc:creator><![CDATA[starz22]]></dc:creator><pubDate>Sat, 26 Jul 2025 13:01:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos on Sat, 26 Jul 2025 11:30:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/starz22" aria-label="Profile: starz22">@<bdi>starz22</bdi></a> weird</p>
<p dir="auto">can you post the config for this module</p>
]]></description><link>https://forum.magicmirror.builders/post/127555</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127555</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 26 Jul 2025 11:30:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos on Sat, 26 Jul 2025 04:31:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yep!</p>
<p dir="auto">total 36<br />
drwxr-xr-x  9 starz starz 4096 Jul 25 19:41 ./<br />
drwxr-xr-x 14 starz starz 4096 Jul 25 10:20 …/<br />
drwxr-xr-x 10 starz starz 4096 Jul 24 13:37 default/<br />
drwxr-xr-x  6 starz starz 4096 Jul 25 19:41 MMM-ImagesPhotos/<br />
drwxr-xr-x  6 starz starz 4096 Jul 24 23:05 MMM-ModuleScheduler/<br />
drwxr-xr-x  5 starz starz 4096 Jul 24 21:19 MMM-nyc-transit/<br />
drwxr-xr-x 11 starz starz 4096 Jul 24 20:20 MMM-OnSpotify/<br />
drwxr-xr-x 10 starz starz 4096 Jul 24 22:00 MMM-Remote-Control/<br />
drwxr-xr-x  4 starz starz 4096 Jul 24 23:13 MMM-WeatherEffects/</p>
]]></description><link>https://forum.magicmirror.builders/post/127554</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127554</guid><dc:creator><![CDATA[starz22]]></dc:creator><pubDate>Sat, 26 Jul 2025 04:31:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos on Sat, 26 Jul 2025 00:25:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/starz22" aria-label="Profile: starz22">@<bdi>starz22</bdi></a> can you go to the MagicMirror/modules folder<br />
and do</p>
<p dir="auto">and show the results</p>
]]></description><link>https://forum.magicmirror.builders/post/127549</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127549</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 26 Jul 2025 00:25:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos on Fri, 25 Jul 2025 23:28:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yep! I’m sure I did the git clone correctly, and I just removed and redid everything to make sure. It’s still not working and showing the same error.</p>
]]></description><link>https://forum.magicmirror.builders/post/127546</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127546</guid><dc:creator><![CDATA[starz22]]></dc:creator><pubDate>Fri, 25 Jul 2025 23:28:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos on Fri, 25 Jul 2025 20:20:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/starz22" aria-label="Profile: starz22">@<bdi>starz22</bdi></a> you did the git clone<br />
while the current directory was<br />
~/MagicMirror/modules<br />
right?</p>
<p dir="auto">the module folder name  MUST MATCH  the module name exactly, case matters</p>
]]></description><link>https://forum.magicmirror.builders/post/127542</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127542</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 25 Jul 2025 20:20:15 GMT</pubDate></item></channel></rss>
