<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unable to import 3rd modules party in config.js]]></title><description><![CDATA[<p dir="auto">Good morning guys,<br />
Nice to meet you!</p>
<p dir="auto">I have got a problem with 3rd modules party.<br />
I clone the github link, i “npm install”, i try to insert in the config.js the strings belong to the module, but when i try to “npm start” the system respond “no config files”…probably there is an error in the config.js</p>
<p dir="auto">I would like to understand how to insert these strings in config.js</p>
<p dir="auto">Thank you in advance,<br />
Giuliano</p>
]]></description><link>https://forum.magicmirror.builders/topic/1982/unable-to-import-3rd-modules-party-in-config-js</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 02:32:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1982.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 Mar 2017 21:28:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unable to import 3rd modules party in config.js on Sun, 05 Mar 2017 22:16:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/giulianomondin" aria-label="Profile: giulianomondin">@<bdi>giulianomondin</bdi></a> comma missing after updateinterval</p>
]]></description><link>https://forum.magicmirror.builders/post/16554</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16554</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sun, 05 Mar 2017 22:16:32 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to import 3rd modules party in config.js on Mon, 06 Mar 2017 08:15:36 GMT]]></title><description><![CDATA[<pre><code class="language-javascript">/* Magic Mirror Config Sample
 * MIT Licensed.
var config = {
	port: 8080,
	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
	language: 'en',
	timeFormat: 24,
	units: 'metric',
			module: 'alert',
			module: "updatenotification",
			position: "top_bar"
			module: 'clock',
			position: 'top_left'
			module: 'calendar',
			header: 'Festività nazionali',
			position: 'top_left',
						symbol: 'calendar-check-o ',
						url: 'https://calendar.google.com/calendar/ical/it.italian%23holiday%40group.v.calendar.google.com/public/basic.ics'
			module: 'compliments',
			position: 'lower_third'
			module: 'currentweather',
			position: 'top_right',
				locationID: '3164924',  //ID from http://www.openweathermap.org
				appid: 'XXXXXXXXXX'
			module: 'weatherforecast',
			header: 'Weather Forecast',
				appid: 'XXXXXXXXXXXXXXXXXXXX'
			module: 'newsfeed',
			position: 'bottom_bar',
				feeds: [
						title: "Il corriere della sera",
						url: "http://xml.corriereobjects.it/rss/homepage.xml"
				showSourceTitle: true,
				showPublishDate: true
    			module: 'MMM-Flickr',
    			position: 'bottom_right',
        		animationSpeed: 2500,
        		updateInterval: 10000
        		size: 'm' // Default is m, can be o=original, t=thumbnail, s= 75x75, b=1024
                 	 // 'z' medium 640, 640 on longest side. 'c' medium 800, 800 on longest side
<p dir="auto">MY PROBLEM IS THE MMM-Flickr module that i added At the end of config.js</p>
]]></description><link>https://forum.magicmirror.builders/post/16551</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16551</guid><dc:creator><![CDATA[giulianomondin]]></dc:creator><pubDate>Mon, 06 Mar 2017 08:15:36 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to import 3rd modules party in config.js on Sun, 05 Mar 2017 21:52:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/giulianomondin" aria-label="Profile: giulianomondin">@<bdi>giulianomondin</bdi></a> said in <a href="/post/16547">Unable to import 3rd modules party in config.js</a>:</p>
<p dir="auto">If you paste a copy of your config here someone will help you.</p>
<p dir="auto">In the meantime, here is what some entries look like. You can scroll through the code. It’s easier if you add them one at a time. Don’t forget to make a backup of your config once you get it working. This way if something happens you can go back to a previous working config</p>
<pre><code>var config = {
	port: 8080,
	ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3",
			"::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
	language: 'en',
	timeFormat: 12,
	units: 'imperial',
			module: 'helloworld',
			position: 'top_bar',	// This can be any of the regions.
			classes: 'small bright',
			text: 'Bottle Pop welcomes you to his very own Magic Mirror! You could have one if you were brilliant and talented and cool like him!'
    			module: 'MMM-Remote-Control',
			module: 'planetrise',
			position: 'lower_third',	// This can be any of the regions.
			// header: 'Join pop in looking at the heavens through his telescope',
            		latitude: 20.574776,  // Place the latitude and longitude of your mirror
            		longitude: -20.112443,  // Place the latitude and longitude of your mirror
            		bodies: {'Sun': '☉',
                    	'Moon': '☽',
                    	'Mercury': '☿',
                    	'Venus': '♀',
                    	'Mars': '♂',
                    	'Jupiter': '♃',
                    	'Saturn': '♄',
			module: 'alert',
			timer: 3500,
			effect: 'jelly', // Possible values: scale slide genie jelly flip exploader bouncyflip
			alert_effect: 'flip', // Same as above
			position: 'middle_center',
			module: 'MMM-SimpleLogo',
			position: 'bottom_left',	// This can be any of the regions.
			fileUrl: "modules/MMM-SimpleLogo/public/yes.jpg",
			width: "260px",
			position: 'bottom_right',	// This can be any of the regions.
			width: "260px",
			fileUrl: "modules/MMM-SimpleLogo/public/starship.jpg",
			module: 'MMM-Globe',
			position: 'bottom_center',
			style: 'natColor', // natColor, geoColor, airMass, fullBand, europeDiscNat, europeDiscSnow, centralAmericaDiscNat
			imageSize: 175,
			updateInterval: 10*60*1000
			module: 'clock',
			position: 'top_center'
]]></description><link>https://forum.magicmirror.builders/post/16549</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16549</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 05 Mar 2017 21:52:59 GMT</pubDate></item></channel></rss>
