<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Tronity]]></title><description><![CDATA[<p dir="auto">Hi there, does anyone know if this is still working? tried to reinstall again however saying;</p>
<p dir="auto">bradley@raspberrypi:~/MagicMirror $ Run git clone <a href="https://github.com/robotfishe/MMM-Tronity.git" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/robotfishe/MMM-Tronity.git</a><br />
Run npm install<br />
bash: Run: command not found<br />
bash: Run: command not found</p>
<p dir="auto">all help greatly appreciated</p>
]]></description><link>https://forum.magicmirror.builders/topic/19837/mmm-tronity</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 03:43:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19837.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 17 Aug 2025 09:34:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Tronity on Sun, 17 Aug 2025 11:24:27 GMT]]></title><description><![CDATA[<p dir="auto">perfect thanks so much</p>
]]></description><link>https://forum.magicmirror.builders/post/127924</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127924</guid><dc:creator><![CDATA[bradley1982]]></dc:creator><pubDate>Sun, 17 Aug 2025 11:24:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tronity on Sun, 17 Aug 2025 10:02:48 GMT]]></title><description><![CDATA[<p dir="auto">Don‘t forget to go to the target module directory before installing!</p>
<pre><code>cd MMM-Tronity
<p dir="auto">Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/127921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127921</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Sun, 17 Aug 2025 10:02:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tronity on Sun, 17 Aug 2025 10:01:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bradley1982" aria-label="Profile: bradley1982">@<bdi>bradley1982</bdi></a> this is easy :-)<br />
Your terminal states the error.</p>
<p dir="auto">You have to issue:</p>
<pre><code>npm install
<p dir="auto">The „run“ produces the error .<br />
Good luck!</p>
<p dir="auto">Warm regards,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/127920</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127920</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Sun, 17 Aug 2025 10:01:10 GMT</pubDate></item></channel></rss>
