<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[npm start fails at electron.js]]></title><description><![CDATA[<p dir="auto">I’ved tried reinstalling MagicMirror several times. I also tried the suggestions in this post:<br />
<a href="https://forum.magicmirror.builders/topic/1017/help-npm-start-error-failed-at-the-start-script-electron-js-electron-js">https://forum.magicmirror.builders/topic/1017/help-npm-start-error-failed-at-the-start-script-electron-js-electron-js</a></p>
<p dir="auto">But nothing has yet worked. Any suggestions are appreciated.</p>
<p dir="auto"><strong>Error Code:</strong></p>
<p dir="auto">pi@LARISM:~/MagicMirror $ npm start</p>
<p dir="auto">magicmirror@2.1.0 start /home/pi/MagicMirror<br />
electron js/electron.js</p>
<p dir="auto">npm ERR! Linux 4.4.38-v7+<br />
npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”<br />
npm ERR! node v7.7.1<br />
npm ERR! npm  v4.3.0<br />
npm ERR! code ELIFECYCLE<br />
npm ERR! errno 1<br />
npm ERR! magicmirror@2.1.0 start: <code>electron js/electron.js</code><br />
npm ERR! Exit status 1<br />
npm ERR!<br />
npm ERR! Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.<br />
npm ERR! Make sure you have the latest version of node.js and npm installed.<br />
npm ERR! If you do, this is most likely a problem with the magicmirror package,<br />
npm ERR! not with npm itself.<br />
npm ERR! Tell the author that this fails on your system:<br />
npm ERR!     electron js/electron.js<br />
npm ERR! You can get information on how to open an issue for this project with:<br />
npm ERR!     npm bugs magicmirror<br />
npm ERR! Or if that isn’t available, you can get their info via:<br />
npm ERR!     npm owner ls magicmirror<br />
npm ERR! There is likely additional logging output above.</p>
<p dir="auto">npm ERR! Please include the following file with any support request:<br />
npm ERR!     /home/pi/.npm/_logs/2017-03-06T05_29_18_677Z-debug.log</p>
]]></description><link>https://forum.magicmirror.builders/topic/1984/npm-start-fails-at-electron-js</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 17:16:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1984.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Mar 2017 05:39:46 GMT</pubDate><ttl>60</ttl></channel></rss>
