<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-HAEV: Electric vehicle charge info via Home Assistant]]></title><description><![CDATA[<p dir="auto">I’ve created a new module that displays EV charge state and location info pulled from Home Assistant: <a href="https://github.com/robotfishe/MMM-HAEV" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/robotfishe/MMM-HAEV</a></p>
<p dir="auto">I’ve been using my older MMM-Tronity module (<a href="https://github.com/robotfishe/MMM-Tronity" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/robotfishe/MMM-Tronity</a>) for years to fetch this data via Tronity’s API. I’ve recently traded in my Vauxhall for a Hyundai, and I’ve found Tronity doesn’t work as well with my new car, but thankfully there’s a very functional Home Assistant integration for getting data directly from Hyundai’s platform - hence this module. The style and layout are the same as MMM-Tronity.</p>
<p dir="auto">The HA entities the module reads are configurable, so it should work with any vehicle/integration as long as the data exists somewhere on your Home Assistant instance.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19883/mmm-haev-electric-vehicle-charge-info-via-home-assistant</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Jul 2026 08:16:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19883.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Sep 2025 22:13:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-HAEV: Electric vehicle charge info via Home Assistant on Wed, 07 Jan 2026 21:20:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Sorry for the late reply; it turns out you install it via HACS and then install the integration (or something like that).  I thought I only needed to do the first part.</p>
<p dir="auto">Thanks for your continuous patience and assistance!</p>
]]></description><link>https://forum.magicmirror.builders/post/129460</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129460</guid><dc:creator><![CDATA[UncleRoger]]></dc:creator><pubDate>Wed, 07 Jan 2026 21:20:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HAEV: Electric vehicle charge info via Home Assistant on Tue, 09 Dec 2025 23:34:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uncleroger" aria-label="Profile: UncleRoger">@<bdi>UncleRoger</bdi></a> did you see the HACS integration<br />
<a href="https://github.com/Hyundai-Kia-Connect/kia_uvo" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Hyundai-Kia-Connect/kia_uvo</a></p>
<p dir="auto">And then his module instead of bluelinky</p>
]]></description><link>https://forum.magicmirror.builders/post/129214</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129214</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 09 Dec 2025 23:34:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HAEV: Electric vehicle charge info via Home Assistant on Tue, 09 Dec 2025 22:04:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robotfish" aria-label="Profile: robotfish">@<bdi>robotfish</bdi></a><br />
Do you have any pointers to what you set up on HA to get this going?  I’ve tried MMM-Bluelinky but it only works occasionally.</p>
<p dir="auto">I would love to get your module working and get my wife’s Ioniq hooked up to HA.</p>
<p dir="auto">Any info or links you can share would be most appreciated!</p>
]]></description><link>https://forum.magicmirror.builders/post/129213</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129213</guid><dc:creator><![CDATA[UncleRoger]]></dc:creator><pubDate>Tue, 09 Dec 2025 22:04:52 GMT</pubDate></item></channel></rss>
