<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[help needed]]></title><description><![CDATA[<p dir="auto">has anyone else had issues with full length mirrors? mine ended up breaking because it was pretty weak and low quality. the frame felt flimsy and it did not  stay steady when leaning against the wall. now i am wondering if it is worth trying to repair or if i should just buy a new one. if so  which type or brand of full length mirror do you recommend? any suggestions would be appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19893/help-needed</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 03:33:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19893.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Sep 2025 09:37:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to help needed on Fri, 03 Oct 2025 18:43:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schlomm" aria-label="Profile: schlomm">@<bdi>schlomm</bdi></a>  Yes I had samples from them.</p>
<p dir="auto">In the end I‘ve decided to use the monitor in a nice ancient picture frame without any glass.<br />
So the „mirror“ effect is missing but this fits my usecase better.<br />
The frame is mounted in our living room and I can see all of the information from every place in the room…</p>
<p dir="auto">Warmest regards,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/128437</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128437</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Fri, 03 Oct 2025 18:43:08 GMT</pubDate></item><item><title><![CDATA[Reply to help needed on Fri, 03 Oct 2025 10:22:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schlomm" aria-label="Profile: schlomm">@<bdi>schlomm</bdi></a> said in <a href="/post/128430">help needed</a>:</p>
<p dir="auto"><a href="http://glasstar.de" target="_blank" rel="noopener noreferrer nofollow ugc">glasstar.de</a></p>
<p dir="auto">thanks for your much information</p>
]]></description><link>https://forum.magicmirror.builders/post/128433</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128433</guid><dc:creator><![CDATA[andrenajolly]]></dc:creator><pubDate>Fri, 03 Oct 2025 10:22:20 GMT</pubDate></item><item><title><![CDATA[Reply to help needed on Thu, 02 Oct 2025 19:05:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> Which shop did you use for your glases? I’ve ordered mine at <a href="http://glasstar.de" target="_blank" rel="noopener noreferrer nofollow ugc">glasstar.de</a>, but yes - not cheap!</p>
]]></description><link>https://forum.magicmirror.builders/post/128430</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128430</guid><dc:creator><![CDATA[schlomm]]></dc:creator><pubDate>Thu, 02 Oct 2025 19:05:18 GMT</pubDate></item><item><title><![CDATA[Reply to help needed on Thu, 02 Oct 2025 18:35:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/andrenajolly" aria-label="Profile: andrenajolly">@<bdi>andrenajolly</bdi></a> :-)<br />
Yes for sure. For a „whole body mirror“ of this length you need a strong frame and a mirror with at least 6mm of glass.<br />
Here in Germany we do have some shops which are offering these kind of glass in any size but this an expensive fun …</p>
<p dir="auto">Good luck!</p>
<p dir="auto">Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/128429</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128429</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Thu, 02 Oct 2025 18:35:27 GMT</pubDate></item><item><title><![CDATA[Reply to help needed on Thu, 02 Oct 2025 15:37:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> said in <a href="/post/128411">help needed</a>:</p>
<p dir="auto">most interesting is: what length is “full length” ?<br />
From this it depends for sure how to build the frame and how to choose right glass (kind of glass, thickness) …</p>
<p dir="auto">Kind regards,<br />
Ralf</p>
<p dir="auto">thanks for pointing that out. By full length I mean around 5 to 6 feet tall so you can see your whole body. I guess you are  right that the size makes a big difference in how strong the frame and glass need to be.</p>
]]></description><link>https://forum.magicmirror.builders/post/128427</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128427</guid><dc:creator><![CDATA[andrenajolly]]></dc:creator><pubDate>Thu, 02 Oct 2025 15:37:07 GMT</pubDate></item><item><title><![CDATA[Reply to help needed on Mon, 29 Sep 2025 13:33:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/andrenajolly" aria-label="Profile: andrenajolly">@<bdi>andrenajolly</bdi></a> -  most interesting is: what length is “full length” ?<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/128411</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128411</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Mon, 29 Sep 2025 13:33:27 GMT</pubDate></item></channel></rss>
