<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wallberry theme: disable unsplash]]></title><description><![CDATA[<p dir="auto">I’m loving the Unsplash module style &amp; layout but I don’t want to use Unsplash for the background images.<br />
Is there an easy way to disable Unsplash entirely and use MMM-BackgroundSlideshow instead?</p>
<p dir="auto">I have MMM-BackgroundSlideshow working but I had to enter an API for Unsplash to stop it giving an OAuth error and it’s still displaying Unsplash photo tags in bottom right (even though the images are mine!)</p>
<p dir="auto">Below is my current Wallberry module config:<br />
modules: [<br />
{<br />
module: “WallberryTheme”,<br />
position: “fullscreen_below”,<br />
config: {<br />
unsplashAccessKey: “REDACTED”, // REQUIRED<br />
//collections: “” // optional - leave empty for a random photo<br />
}<br />
},</p>
<p dir="auto">On down my modules list I have MMM-BackgroundSlideshow setup as below:<br />
{<br />
module: ‘MMM-BackgroundSlideshow’,<br />
position: ‘fullscreen_below’,<br />
config: {<br />
imagePaths: [‘/mnt/nas/’],      				<br />
recursiveSubDirectories: true,<br />
transitionImages: false,<br />
randomizeImageOrder: true,<br />
slideshowSpeed: 600000,<br />
}</p>
]]></description><link>https://forum.magicmirror.builders/topic/19929/wallberry-theme-disable-unsplash</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 10:51:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19929.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Oct 2025 08:04:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wallberry theme: disable unsplash on Fri, 24 Oct 2025 18:00:13 GMT]]></title><description><![CDATA[<p dir="auto">Managed to figure it out: just bracketed out the position line in the Wallberry CSS and it’s suppressed</p>
<p dir="auto"><img src="/assets/uploads/files/1761328809981-css.png" alt="css.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/128674</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128674</guid><dc:creator><![CDATA[mrchips83]]></dc:creator><pubDate>Fri, 24 Oct 2025 18:00:13 GMT</pubDate></item><item><title><![CDATA[Reply to Wallberry theme: disable unsplash on Fri, 24 Oct 2025 12:09:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrchips83" aria-label="Profile: mrchips83">@<bdi>mrchips83</bdi></a> I don’t know the answer to either module</p>
<p dir="auto">I use MMM-ImagesPhotos, and link It’s hard coded uploads folder to whatever source you want. I link to a mounted server share</p>
]]></description><link>https://forum.magicmirror.builders/post/128671</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128671</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 24 Oct 2025 12:09:20 GMT</pubDate></item></channel></rss>
