<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Best Bathroom Mirror with Built-in Lighting | Expert Recommendation to Choose]]></title><description><![CDATA[<p dir="auto">I researched about the best Bathroom Mirrors with built-in lighting for the past few days because I’m planning to upgrade my bathroom setup and want something that’s modern, durable, and possibly compatible with smart or DIY lighting features. I read reviews on The New York Times (Wirecutter), The Spruce, and Popular Mechanics, and they’re marking these two as some of the best options:</p>
<p dir="auto"><strong>USHOWER 2-Pack Black Bathroom Mirrors</strong><br />
<a href="https://www.amazon.com/USHOWER-Mirror-Bathroom-Rectangle-Mounted/dp/B0B3XPZX8B?th=1&amp;linkCode=ll1&amp;tag=german0478-20&amp;linkId=07bd6a92e3c42e302a48d5c5c732a8ab&amp;language=en_US&amp;ref_=as_li_ss_tl" target="_blank" rel="noopener noreferrer nofollow ugc">[https://www.amazon.com/USHOWER-Mirror-Bathroom-Rectangle-Mounted/dp/B0B3XPZX8B]</a><br />
<strong>LOAAO 40X32 LED Bathroom Mirror with Lights</strong><br />
<a href="https://www.amazon.com/LOAAO-Bathroom-Anti-Fog-Dimmable-Waterproof/dp/B09TP75Y82?th=1&amp;linkCode=ll1&amp;tag=german0478-20&amp;linkId=e578b720bb96a6d00798369c4d9532f9&amp;language=en_US&amp;ref_=as_li_ss_tl" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.com/LOAAO-Bathroom-Anti-Fog-Dimmable-Waterproof/dp/B09TP75Y82</a></p>
<p dir="auto">However, I’m having trouble deciding which one would best suit my needs and would appreciate some expert advice. I’d prefer something that’s bright, anti-fog, and easy to integrate with a smart switch or LED controller if possible.<br />
Has anyone here tried building or modifying one of these mirrors for smart home integration or MagicMirror setups?<br />
Would love to hear your experiences, wiring tips, or hardware suggestions before I decide.<br />
Thanks in advance!</p>
]]></description><link>https://forum.magicmirror.builders/topic/19945/best-bathroom-mirror-with-built-in-lighting-expert-recommendation-to-choose</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 09:35:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19945.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Oct 2025 19:17:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Best Bathroom Mirror with Built-in Lighting | Expert Recommendation to Choose on Wed, 29 Oct 2025 03:36:18 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/user/jonson" aria-label="Profile: jonson">@<bdi>jonson</bdi></a> — great question!</p>
<p dir="auto">If you’re thinking of building your own smart mirror setup, you can actually make it look a lot cleaner and more “custom” by framing it with cut-to-size MDF panels or lightweight boards. That gives you a sleek finish and lets you easily mount LED strips or smart controllers behind the frame.</p>
<p dir="auto">For example, at <a href="https://mdfdirect.co.uk/" target="_blank" rel="noopener noreferrer nofollow ugc">MDF Direct</a>, you can get MDF boards cut to your exact measurements — ideal for mirror frames, wall panels, or even bathroom cabinetry. If you want a moisture-resistant option, their moisture-resistant MDF is a solid choice for bathroom environments.</p>
<p dir="auto">Pairing that with a two-way mirror (as <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> mentioned) and a smart LED controller gives you the perfect mix of tech and design.</p>
<p dir="auto">Hope that helps, and good luck with your smart mirror build!</p>
]]></description><link>https://forum.magicmirror.builders/post/128767</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128767</guid><dc:creator><![CDATA[esmail11]]></dc:creator><pubDate>Wed, 29 Oct 2025 03:36:18 GMT</pubDate></item><item><title><![CDATA[Reply to Best Bathroom Mirror with Built-in Lighting | Expert Recommendation to Choose on Tue, 28 Oct 2025 19:21:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jonson" aria-label="Profile: jonson">@<bdi>jonson</bdi></a> if you are going to smart mirror/magicmirror you need a 2 way mirror, and these are generally not finished.</p>
<p dir="auto">see <a href="https://twowaymirrors.com" target="_blank" rel="noopener noreferrer nofollow ugc">https://twowaymirrors.com</a>  for a clearer view of the glass needed …</p>
<p dir="auto">a regular mirror will not work  as the coating on the back is opaque, non-see thru</p>
]]></description><link>https://forum.magicmirror.builders/post/128756</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128756</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 28 Oct 2025 19:21:42 GMT</pubDate></item></channel></rss>
