<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Remote-Control on LINUX box (NOT RPi)]]></title><description><![CDATA[<p dir="auto">I am having trouble getting the module to load on a LINUX box (ubunto LT16.4 or whatever). Looking over the docs, it does state a lot about RaspberryPi, but I figured I could give it a shot. And failed.</p>
<p dir="auto">Should I have failed, or did I mess up?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/1996/mmm-remote-control-on-linux-box-not-rpi</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 03:21:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1996.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Mar 2017 06:51:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Remote-Control on LINUX box (NOT RPi) on Wed, 08 Mar 2017 00:46:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jopyth" aria-label="Profile: Jopyth">@<bdi>Jopyth</bdi></a><br />
It would probably help if I installed it into MODULES instead of into the ROOT directory<br />
(as a matter of fact, it helped a LOT!)</p>
<p dir="auto">DUH. Sorry to have wasted your time. My bad  :8ball:</p>
]]></description><link>https://forum.magicmirror.builders/post/16777</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16777</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Wed, 08 Mar 2017 00:46:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Remote-Control on LINUX box (NOT RPi) on Tue, 07 Mar 2017 15:00:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amanzimdwini" aria-label="Profile: amanzimdwini">@<bdi>amanzimdwini</bdi></a> Well how do you start it? With <code>pm2</code> (then it is <code>pm2 logs mm</code>) or a simple <code>node serveronly</code>? I am using the latter, and it would just output any possible errors on the console. What happens when you go to <code>localhost:8080/remote.html</code>?</p>
]]></description><link>https://forum.magicmirror.builders/post/16734</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16734</guid><dc:creator><![CDATA[Jopyth]]></dc:creator><pubDate>Tue, 07 Mar 2017 15:00:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Remote-Control on LINUX box (NOT RPi) on Tue, 07 Mar 2017 14:32:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jopyth" aria-label="Profile: Jopyth">@<bdi>Jopyth</bdi></a> No errors; have not checked logs yet. Simply does not load (and then is obviously not accessible either).  Any specific error logs you’re interested in? (not too proficient in Linux, so you’d have to point me in the right direction)</p>
]]></description><link>https://forum.magicmirror.builders/post/16728</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16728</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Tue, 07 Mar 2017 14:32:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Remote-Control on LINUX box (NOT RPi) on Tue, 07 Mar 2017 07:32:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amanzimdwini" aria-label="Profile: amanzimdwini">@<bdi>amanzimdwini</bdi></a> Do you have any errors in the logs, or on the website? I develop on Ubuntu and it should definitely load, however some functions will not work (i.e. switching screen off and on, or reboot without <code>sudo</code> rights).</p>
]]></description><link>https://forum.magicmirror.builders/post/16677</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16677</guid><dc:creator><![CDATA[Jopyth]]></dc:creator><pubDate>Tue, 07 Mar 2017 07:32:23 GMT</pubDate></item></channel></rss>
