<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issues with Newsfeed module since 3 days]]></title><description><![CDATA[<p dir="auto">Hi, I have some issues with the Newsfeed module.  I always get the messsage “error in module newsfeed - please check logfile”</p>
<p dir="auto">Where can I check the logfile?</p>
<p dir="auto">My config: ```<br />
{</p>
<pre><code>		module: "newsfeed",
		position: "bottom_bar",
			feeds: [
				title: "Radio Mülheim",
				url: "http://www.radiomuelheim.de/lokalnachrichten.xml",
					title: "Tagesschau",
					url: "http://www.tagesschau.de/xml/rss2"
			showSourceTitle: true,
			showPublishDate: true,
			reloadInterval: 600000,
			updateInterval: 15000,
<p dir="auto">{</p>
<pre><code></code></pre>
]]></description><link>https://forum.magicmirror.builders/topic/19977/issues-with-newsfeed-module-since-3-days</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 00:41:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19977.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 16 Nov 2025 14:10:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issues with Newsfeed module since 3 days on Wed, 19 Nov 2025 21:03:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> Your welcome.  It felt good to be able offer some help instead of always asking for it. Good luck finding your problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/129010</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129010</guid><dc:creator><![CDATA[RonR]]></dc:creator><pubDate>Wed, 19 Nov 2025 21:03:38 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with Newsfeed module since 3 days on Wed, 19 Nov 2025 18:56:37 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the hint - I got an error based on unavailibility of RSS newsfeed service. An update to another newsfeed helped to fix the problem!</p>
]]></description><link>https://forum.magicmirror.builders/post/129008</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129008</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Wed, 19 Nov 2025 18:56:37 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with Newsfeed module since 3 days on Tue, 18 Nov 2025 18:38:34 GMT]]></title><description><![CDATA[<p dir="auto">I thinks these should help you.</p>
<p dir="auto">Restarting your MagicMirror²<br />
pm2 restart mm</p>
<p dir="auto">Stopping your MagicMirror²<br />
pm2 stop mm</p>
<p dir="auto">Show the MagicMirror² logs<br />
pm2 logs mm</p>
<p dir="auto">Show the MagicMirror² process information<br />
pm2 show mm</p>
]]></description><link>https://forum.magicmirror.builders/post/128999</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128999</guid><dc:creator><![CDATA[RonR]]></dc:creator><pubDate>Tue, 18 Nov 2025 18:38:34 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with Newsfeed module since 3 days on Mon, 17 Nov 2025 08:23:17 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for response,</p>
<p dir="auto">Do you know where I can check the logfile?</p>
]]></description><link>https://forum.magicmirror.builders/post/128981</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128981</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Mon, 17 Nov 2025 08:23:17 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with Newsfeed module since 3 days on Mon, 17 Nov 2025 07:27:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> This is quite strange!<br />
Opening of config.js is (AFAIK) non-blocking and doesn’t cause any interaction with the displayed modules.<br />
If you are using Sam’s installation saving config.js should cause a mirror-restart. This is the only interaction between config.js and “Display” I’m aware of.<br />
Is the “correct” displayed newsfeed on the remote desktop, too?<br />
Then this sounds like a browser problem.<br />
In the past I’ve learned that every browser instantiates it’s own session.<br />
(I HAD the meaning that this ist kind of “mirrored” but this was wrong).<br />
I’ve especially seen this on my mirror within the newsfeed module: If you start two browsers the displayed information is NOT synchrone!<br />
So may only your normal browser got a hickup…<br />
-&gt; no idea, why, sorry.</p>
<p dir="auto">Warmest regards,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/128980</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128980</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Mon, 17 Nov 2025 07:27:19 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with Newsfeed module since 3 days on Sun, 16 Nov 2025 17:59:54 GMT]]></title><description><![CDATA[<p dir="auto">Yes - the mirror is online. Seems that the news are displayed if I open der config.js via remotedesktop… After disconnecting the error occurs again.<br />
All other modules are running fine.</p>
]]></description><link>https://forum.magicmirror.builders/post/128970</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128970</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Sun, 16 Nov 2025 17:59:54 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with Newsfeed module since 3 days on Sun, 16 Nov 2025 15:52:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> I often get this message when internet connection isn‘t available…</p>
<ul>
<li>are you online in the moment the module will come up?<br />
Your reload interval is at 60.000 - so you may have to wait these 10 minutes and you will see data if internet connection appears in the meantime.<br />
Config looks OK to me…</li>
</ul>
<p dir="auto">Good luck!<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/128968</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/128968</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Sun, 16 Nov 2025 15:52:56 GMT</pubDate></item></channel></rss>
