<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-MarineWeather]]></title><description><![CDATA[<p dir="auto">Bonjour,</p>
<p dir="auto">L’un d’entre vous utilise t’il ce module?</p>
<p dir="auto">Le mien est bloqué sur “Chargement…” bien qu’étant inscrit sur le site <a href="https://dashboard.stormglass.io/" target="_blank" rel="noopener noreferrer nofollow ugc">https://dashboard.stormglass.io/</a></p>
<p dir="auto">Y a t’il une manip à faire dans le fichier nano config.js :<br />
sur The StormGlass API base URL.</p>
<p dir="auto">apiBase : Default value: ‘<a href="https://api.stormglass.io/" target="_blank" rel="noopener noreferrer nofollow ugc">https://api.stormglass.io/</a>’  ???</p>
<p dir="auto">Mon fichier de config :</p>
<pre><code>            {
                    module: "MMM-MarineWeather",
                    header: "Conditions Marines",
                            latitude: XX.XXXXXX, // Latitude
                            longitude: -X.XXXXXXXX, // Longitude
                            appid: "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx-xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx" // StormGlass API key (docs.stormglass.io)
<p dir="auto">Merci pour votre retour.</p>
]]></description><link>https://forum.magicmirror.builders/topic/20000/mmm-marineweather</link><generator>RSS for Node</generator><lastBuildDate>Sat, 13 Jun 2026 00:12:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20000.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Nov 2025 17:27:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-MarineWeather on Thu, 11 Dec 2025 20:55:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/videogame95" aria-label="Profile: videogame95">@<bdi>videogame95</bdi></a> the new v3 api requires a credit card for over use charges.  First 1000 requests per day are not charged</p>
<p dir="auto">OpenWeatherMap has told us repeatedly that they are terminating the old 2.5 api, over and over<br />
We change the module to default to the new 3.0 /onecall api</p>
<p dir="auto">There is a pinned topic in the troubleshooting section on this</p>
]]></description><link>https://forum.magicmirror.builders/post/129217</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129217</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 11 Dec 2025 20:55:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MarineWeather on Thu, 11 Dec 2025 20:00:42 GMT]]></title><description><![CDATA[<p dir="auto">I’m having the same problem with open weather map module<br />
put  secret id from open weater maps<br />
added  lon :<br />
and     lat:</p>
<p dir="auto">updated  install script still not loading ?<br />
sorry I can’t help.<br />
any suggestion help please</p>
]]></description><link>https://forum.magicmirror.builders/post/129216</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129216</guid><dc:creator><![CDATA[videogame95]]></dc:creator><pubDate>Thu, 11 Dec 2025 20:00:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MarineWeather on Sat, 29 Nov 2025 17:50:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrisfr1976" aria-label="Profile: chrisfr1976">@<bdi>chrisfr1976</bdi></a></p>
<p dir="auto">Merci pour ce retour.</p>
<p dir="auto">J’ai finalement trouvé le problème qui vient de Node.js (node-fetch) qui n’était pas installé sur ma version de Magic Mirror.</p>
<p dir="auto">Je l’ai donc installé dans le répertoire du module :</p>
<p dir="auto">/…/MMM-MarineWeather</p>
<p dir="auto">npm install node-fetch@2</p>
<p dir="auto">-&gt; Il faut installer la version 2 car la version 3 n’est pas compatible.</p>
<p dir="auto">puis redémarrer le Magic Mirror est le tour est joué.</p>
]]></description><link>https://forum.magicmirror.builders/post/129138</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129138</guid><dc:creator><![CDATA[RocoJo]]></dc:creator><pubDate>Sat, 29 Nov 2025 17:50:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MarineWeather on Fri, 28 Nov 2025 16:46:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rocojo" aria-label="Profile: RocoJo">@<bdi>RocoJo</bdi></a> said in <a href="/post/129114">MMM-MarineWeather</a>:</p>
<p dir="auto">MMM-MarineWeather</p>
<p dir="auto">Pour vérifier ce qui bloque le module, regardez dans la console du navigateur (F12 → « Console »). Vous y verrez les éventuels messages d’erreur :</p>
<ul>
<li>401 Unauthorized → clé API incorrecte</li>
<li>400 Bad Request → coordonnées erronées</li>
<li>Failed to fetch → problème de réseau ou quota API dépassé</li>
</ul>
<p dir="auto">Cela permet généralement d’identifier l’origine du problème. Je ne connais pas non plus ce module en détail. Peut-être que vous verrez l’erreur dans la console et pourrez ainsi la corriger.</p>
]]></description><link>https://forum.magicmirror.builders/post/129135</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129135</guid><dc:creator><![CDATA[chrisfr1976]]></dc:creator><pubDate>Fri, 28 Nov 2025 16:46:32 GMT</pubDate></item></channel></rss>
