<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trixie/node v24  - timeouts on request to the internet]]></title><description><![CDATA[<p dir="auto">I’ve migrated my MagigMirror installation on a RPI 4 from Bullseye to Trixie, running now  MM V2.33.0  and node v24.11.1.<br />
After solving some smaller issues with the NetworkManager configuration, everything is now running fine, except that I observe sometimes timeouts on requests to the internet. Fetching Goggle calendar entries or access to Spotify endpoints  sometimes end up in timeouts, particularly visible at startup of MagicMirror. (and no, it’s not related to any wrong URL )</p>
<p dir="auto">The same MM config is running under Bullseye, MM v2.26.0 and node v20.18.0 without any network  issues. It also not a problem of wayland,  as I get the same error messages running the config under x11. It seems that this behaviour is related to node V24. Is this a known issue? Is there  someone who is fighting with similar issues? Has someone a sustainable solution for that problem?</p>
<pre><code>[2025-12-01 11:52:18.102] [LOG]   Launching application.
[2025-12-01 11:52:22.644] [INFO]
####  System Information  ####
- SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.1; virtual: false; MM: 2.33.0
- OS:       platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.47+rpt-rpi-v8
- VERSIONS: electron: 39.2.3; used node: 22.21.1; installed node: 24.11.1; npm: 11.6.2; pm2: 6.0.13
- ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
            WAYLAND_DISPLAY:  wayland-0; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
- RAM:      total: 905.64 MB; free: 397.65 MB; used: 507.99 MB
- OTHERS:   uptime: 23 minutes; timeZone: Europe/Berlin
[2025-12-01 11:52:23.927] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx%40group.calendar.google.com/private-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/basic.ics - Interval: 5400000
[2025-12-01 11:52:24.132] [LOG]   Create new calendarfetcher for url: https://www.schulferien.org/media/ical/deutschland/ferien_nordrhein-westfalen_2025.ics?k=wMVRLvKrstqVXYv0MZJF9BwhEW4cGfQFjuutfjiALP5Hj700di6oEuYaFGd4tDTvYrLNzQgB7m-GlFC60I4jasaxLk6nJd_OY70AeBteoOU - Interval: 900000
[2025-12-01 11:52:24.136] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/de.german%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 900000
[2025-12-01 11:52:24.788] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx%40group.calendar.google.com/private-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/basic.ics TypeError: fetch failed
    at node:internal/deps/undici/undici:14900:13
    at processTicksAndRejections (node:internal/process/task_queues:105:5)
    at runNextTicks (node:internal/process/task_queues:69:3)
    at process.processTimers (node:internal/timers:520:9) {
  [cause]: AggregateError [ETIMEDOUT]:
      at internalConnectMultiple (node:net:1134:18)
      at internalConnectMultiple (node:net:1210:5)
      at Timeout.internalConnectMultipleTimeout (node:net:1742:5)
      at listOnTimeout (node:internal/timers:590:11)
      at process.processTimers (node:internal/timers:523:7) {
    code: 'ETIMEDOUT',
    [errors]: [ [Error], [Error] ]
]]></description><link>https://forum.magicmirror.builders/topic/20007/trixie-node-v24-timeouts-on-request-to-the-internet</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 17:32:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20007.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Dec 2025 11:43:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trixie/node v24  - timeouts on request to the internet on Fri, 12 Dec 2025 14:09:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mr.sponti" aria-label="Profile: Mr.Sponti">@<bdi>Mr.Sponti</bdi></a> do you have the gpu hardware enabled?<br />
If not then I think electron tries to emulate it, probably w the vlc content</p>
]]></description><link>https://forum.magicmirror.builders/post/129220</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129220</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 12 Dec 2025 14:09:13 GMT</pubDate></item><item><title><![CDATA[Reply to Trixie/node v24  - timeouts on request to the internet on Fri, 12 Dec 2025 12:30:39 GMT]]></title><description><![CDATA[<p dir="auto">After further investigations I found the reason for the heavy CPU load. Originator for this behaviour ist the parameter “ELECTRON_ENABLE_GPU=1”. If this parameter is undefined my CPU load is as expected.</p>
<p dir="auto">I’ve also had a deeper look to run the “VLC video player” with RTSP streams from my cameras. Using the following command line parameter leads in my environment to best results:</p>
<pre><code>var opts = { detached: false, env: environ }
var args = ["-I dummy",
   "-q",
   "--zoom=" + this.window.zoom.toString(),
   "--video-x=" + this.window.x.toString(),		//	x,y-positioning does't work
   "--video-y=" + this.window.y.toString(),		//	...
   "--no-audio",
   "--video-on-top",
   "--no-video-deco",
   "--no-osd",
   "--no-video-title-show",
   "--network-caching=1000",
   "--rtsp-tcp",
   `${this.streams[stream].url}`
//console.log(playerPath + this.player, args)
this.streaming.player = spawn(playerPath + this.player, args, opts)
]]></description><link>https://forum.magicmirror.builders/post/129219</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129219</guid><dc:creator><![CDATA[Mr.Sponti]]></dc:creator><pubDate>Fri, 12 Dec 2025 12:30:39 GMT</pubDate></item><item><title><![CDATA[Reply to Trixie/node v24  - timeouts on request to the internet on Wed, 03 Dec 2025 12:34:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mr.sponti" aria-label="Profile: Mr.Sponti">@<bdi>Mr.Sponti</bdi></a> thanks for the feedback, hadn’t expected node to be the problem .</p>
<p dir="auto">As for the vlc perf issue , not sure . There have been vlc issues in electron before.</p>
<p dir="auto">You might try the next release develop branch<br />
See <a href="https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code">https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code</a></p>
<p dir="auto">A quick way without touching your existing setup use my backup script to save the module list , config and css<br />
Rename the MagicMirror folder<br />
git clone the repo, checkout the develop branch<br />
Oh it needs node 24 (use n or nvm to switch version)<br />
npm install<br />
Run the restore script to put the modules, config and css in the new MagicMirror folder</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
]]></description><link>https://forum.magicmirror.builders/post/129163</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129163</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 03 Dec 2025 12:34:10 GMT</pubDate></item><item><title><![CDATA[Reply to Trixie/node v24  - timeouts on request to the internet on Wed, 03 Dec 2025 08:33:24 GMT]]></title><description><![CDATA[<p dir="auto">Hi Sam, thank you for your  fast response and support!<br />
I’ve played with the mmFetchTimout parameter without success. As I didn’t had any network issues with Bullseye, MM v2.26.0 and node v20.18.0, I downgraded node to v22.18 and the network issues are gone.<br />
But I’m now  faced with another big issue under Trixie. If I schedule modules using graphic functions like vlc,  the CPU load increase dramatically. There is one electron process with parameterer <strong>–type=zygote</strong> consuming the whole CPU capacity.</p>
<p dir="auto"><img src="/assets/uploads/files/1764749586449-14c23523-77f0-4375-ae25-1a860a46b883-image-resized.png" alt="14c23523-77f0-4375-ae25-1a860a46b883-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">From copilot I got the answer: <em>High CPU usage from  electron --type=zygote  is usually tied to Chromium’s zygote process, which forks renderer processes.</em></p>
<p dir="auto">Do you have any idea how to get this problem under control?</p>
]]></description><link>https://forum.magicmirror.builders/post/129162</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129162</guid><dc:creator><![CDATA[Mr.Sponti]]></dc:creator><pubDate>Wed, 03 Dec 2025 08:33:24 GMT</pubDate></item><item><title><![CDATA[Reply to Trixie/node v24  - timeouts on request to the internet on Tue, 02 Dec 2025 22:49:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mr.sponti" aria-label="Profile: Mr.Sponti">@<bdi>Mr.Sponti</bdi></a> our code uses a 30 second timeout, but it can be changed by setting an environment variable , here 45 seconds</p>
<p dir="auto">export mmFetchTimeout=45000<br />
In the script used to launch MagicMirror</p>
<p dir="auto">See the doc here<br />
<a href="https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples</a><br />
I submitted a change to fix the doc which has two defaults specified</p>
<p dir="auto">But I think you need to fix you network</p>
]]></description><link>https://forum.magicmirror.builders/post/129149</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129149</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Dec 2025 22:49:44 GMT</pubDate></item></channel></rss>
