<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-RAIN-MAP covers part of the module above it]]></title><description><![CDATA[<p dir="auto">I’m trying to position MMM-RAIN-MAP so it does not cover part of the module above it.  I have tried 3 suggested custom.css entries with no help.</p>
<pre><code>.MMM-RAIN-MAP {
  margin-top: 20px; /* Move down by 20px */
  /* or */
  top: 20px; /* If positioned relatively or absolutely */
.MMM-RAIN-MAP {
  position: relative;
  top: 20px; /* Moves the map down by 20px */
<p dir="auto">They do not seem to have any affect on the position.  When I start mm MMM-RAIN-MAP seems to be lower on the screen and then it jumps up to cover the bottom part of the calendar module above it.</p>
<p dir="auto">What else can I try to get it to position where I want it?</p>
<p dir="auto">TIA, Ron R</p>
]]></description><link>https://forum.magicmirror.builders/topic/20011/mmm-rain-map-covers-part-of-the-module-above-it</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 22:19:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20011.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Dec 2025 19:42:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-RAIN-MAP covers part of the module above it on Sat, 06 Dec 2025 00:13:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ronr" aria-label="Profile: RonR">@<bdi>RonR</bdi></a> ctrl-+. Should zoom in</p>
]]></description><link>https://forum.magicmirror.builders/post/129203</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129203</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Dec 2025 00:13:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RAIN-MAP covers part of the module above it on Sat, 06 Dec 2025 00:05:48 GMT]]></title><description><![CDATA[<p dir="auto">Sam, thanks for the info on the developers window.  I’ve looked at it briefly for a couple other issues but had not thought about it for this.  I’ll give it a look.  The only problem with it is that I need a microscope to  read anything.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/129202</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129202</guid><dc:creator><![CDATA[RonR]]></dc:creator><pubDate>Sat, 06 Dec 2025 00:05:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RAIN-MAP covers part of the module above it on Fri, 05 Dec 2025 20:23:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ronr" aria-label="Profile: RonR">@<bdi>RonR</bdi></a> I do not know, but if you use the developers window, elements tab,  you can test and discover what it should be<br />
(without adding stuff the custom.css try it, etc,etc,etc.etc)</p>
<p dir="auto">see the second link in my signature below for a short topic on the elements tab</p>
<p dir="auto">I ‘think’ you want the .module-content  class div to move it…<br />
relative is to the thing it is INSIDE, absolute is to the screen,</p>
]]></description><link>https://forum.magicmirror.builders/post/129196</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129196</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Dec 2025 20:23:26 GMT</pubDate></item></channel></rss>
