<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM- Carousel]]></title><description><![CDATA[<p dir="auto">Hi friends, liebe Grüße Freunde!<br />
The concept of Carousel is more complicated than MMM-pages where I succeeded. This unfortunately not working, ignoring my usb keyboard and I still see on the middle of screen " module M_Carousel …etc" ps I’m a Newbie</p>
<pre><code class="language-js">let config = {
    address: "0.0.0.0",
    port: 8080,
    basePath: "/",
    ipWhitelist: [],
    useHttps: false,
    httpsPrivateKey: "",
    httpsCertificate: "",
    language: "en",
    locale: "en-US",
    logLevel: ["INFO", "LOG", "WARN", "ERROR"],
    timeFormat: 24,
    units: "metric",
 		module: "MMM-KeyBindings",
   			evdev: { enabled: false },
			enableKeyboard: true,
  			keyBindings: [
        				key: "ArrowRight",
        				notification: "PAGE_INCREMENT"
        				key: "ArrowLeft",
        				notification: "PAGE_DECREMENT"
      		module: "MMM-Carousel",
      		position: "bottom_bar",
        		transitionInterval: 10000,
        		ignoreModules: ["clock", "alert"],
        		mode: "slides",
        		showPageIndicators: true,
        		showPageControls: true,
        		slides: {
          			main: ["calendar", "compliments", "weather"],
          			"Slide 2": ["weather", "newsfeed"],
          			"Slide 3": ["MMM-PublicTransportHafas"]
        		keyBindings: {
          			enabled: true,
          				map: {
            					NextSlide: "ArrowRight",
           		 			PrevSlide: "ArrowLeft",
            					Pause: "ArrowDown",
            					Slide0: "Home"
         		 mode: "DEFAULT"
            module: "alert"
            module: "updatenotification",
            position: "top_bar",
            header: "US Holidays",
                        symbol: "calendar-check",
                        url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
		module: "MMM-Touch",
		module: 'MMM-ViewNotifications',
		position: "bottom_right",
		header: "Notifications",
                // See below for Configuration Options
		module: "compliments",
		position: "lower_third",
            module: "weather",
            header: "Weather Forecast",
                weatherProvider: "openmeteo",
                type: "forecast",
                lat: 40.776676,
                lon: -73.971321
            module: "weather",
            header: "Weather Current",
                type: "current",
                lat: 40.776676,
                lon: -73.971321
            module: "newsfeed",
                feeds: [
                        title: "New York Times",
                        url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                showSourceTitle: true,
                showPublishDate: true,
                broadcastNewsFeeds: true,
                broadcastNewsUpdates: true
		module: 'clock',
      		position: 'bottom_bar'
		module: "MMM-PublicTransportHafas",
            	position: "bottom_left",
                	stationID: "645239",
                	stationName: "18.-März-Straße",
                	direction: "",
                	excludedTransportationTypes: [],
                	ignoredLines: [],
                	timeToStation: 10,
                	displayLastUpdate: true,
                	maxUnreachableDepartures: 0,
                	maxReachableDepartures: 7,
                	showColoredLineSymbols: true,
                	customLineStyles: "",
                	showOnlyLineNumbers: false,
                	showTableHeadersAsSymbols: true,
                	useColorForRealtimeInfo: true
            module: "MMM-Remote-Control",
            //position: "bottom_right",
                customCommand: {},
                showModuleApiMenu: true,
                secureEndpoints: false,
                showQRCode: true,
                qrCodeSize: 150,
                qrCodePosition: "below"
/***** DO NOT EDIT THE LINE BELOW *****/
<p dir="auto">Thanks in advance,/Vielen Dank im voraus</p>
]]></description><link>https://forum.magicmirror.builders/topic/20025/mmm-carousel</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 02:51:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20025.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Dec 2025 15:15:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM- Carousel on Wed, 20 May 2026 22:42:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mati_93" aria-label="Profile: Mati_93">@<bdi>Mati_93</bdi></a> you will get older more times than not thru google…</p>
]]></description><link>https://forum.magicmirror.builders/post/131177</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131177</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 20 May 2026 22:42:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Carousel on Wed, 20 May 2026 22:36:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a> I know topic is old…well instead of searching inside the app, I have been digging in Google browser . " Magic mirror modules"</p>
]]></description><link>https://forum.magicmirror.builders/post/131176</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131176</guid><dc:creator><![CDATA[Mati_93]]></dc:creator><pubDate>Wed, 20 May 2026 22:36:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Carousel on Tue, 30 Dec 2025 00:15:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mati_93" aria-label="Profile: Mati_93">@<bdi>Mati_93</bdi></a> This sort of thing happens to others from time to time as well. It would be really interesting to know how you came across the old version 🕵️. We have <a href="https://modules.magicmirror.builders/" target="_blank" rel="noopener noreferrer nofollow ugc">the module list</a>, which refers to the fork from shabatm since a while. Did you come across the old version in the forum?</p>
]]></description><link>https://forum.magicmirror.builders/post/129338</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129338</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Tue, 30 Dec 2025 00:15:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Carousel on Sat, 27 Dec 2025 20:29:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  topic solved. I’ve downloaded older version from the first guy, not the forked one.  Now everythings works perfect from shbatm.</p>
]]></description><link>https://forum.magicmirror.builders/post/129332</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129332</guid><dc:creator><![CDATA[Mati_93]]></dc:creator><pubDate>Sat, 27 Dec 2025 20:29:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Carousel on Sat, 27 Dec 2025 19:00:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Ok sorry , in hurry.<br />
Why? Because mnm-pages does not support keyBinding module. I want to move pages manually before I order IR touch frame.</p>
]]></description><link>https://forum.magicmirror.builders/post/129331</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129331</guid><dc:creator><![CDATA[Mati_93]]></dc:creator><pubDate>Sat, 27 Dec 2025 19:00:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Carousel on Sat, 27 Dec 2025 16:56:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mati_93" aria-label="Profile: Mati_93">@<bdi>Mati_93</bdi></a> why did you change from pages?<br />
also, future posts</p>
<p dir="auto">if config, or code or log files, use the code block around them</p>
<p dir="auto">paste text to message editor, blank line above and below<br />
select the text just pasted<br />
hit the &lt;/&gt; button on the message editor tool bar</p>
<p dir="auto">I have fixed first post</p>
]]></description><link>https://forum.magicmirror.builders/post/129330</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129330</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 27 Dec 2025 16:56:13 GMT</pubDate></item></channel></rss>
