<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-MyTasklist]]></title><description><![CDATA[<h1>MMM-MyTasklist</h1>
<p dir="auto">This a module for <a href="https://github.com/MichMich/MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">Magic Mirror²</a>.<br />
This displays a simple Tasklist, you can update through a web frontend.</p>
<img width="319" height="202" alt="image" src="https://github.com/user-attachments/assets/e76f7664-4f41-49d2-b4f6-5a76922591c0" />
<br /><br />
<img width="721" height="370" alt="image" src="https://github.com/user-attachments/assets/10c2eff4-4286-461f-8333-f0ae098d36c7" />
<h2>Installation</h2>
<p dir="auto">Clone this repository in your modules folder, and install dependencies:</p>
<pre><code>cd ~/MagicMirror/modules
git clone https://github.com/htilburgs/MMM-MyTasklist.git
cd MMM-MyTasklist
npm install
<h2>Update</h2>
<p dir="auto">When you need to update this module:</p>
<pre><code>cd ~/MagicMirror/modules/MMM-MyTasklist
git pull
npm install
<h2>Configuration</h2>
<p dir="auto">Go to the MagicMirror/config directory and edit the config.js file.<br />
Add the module to your modules array in your config.js.</p>
<pre><code>{
  module: "MMM-MyTasklist",
  header: "MyTaskList",
  disabled: false,
    tasksFile: "modules/MMM-MyTasklist/tasks.json",
    updateInterval: 300000,
    showCompleted: true,
    maxTasks: null
<h2>Load Webinterface for updating the Tasklist</h2>
<p dir="auto">Open a browser and type <code>http://serverip address:8448</code><br />
So if for example you’re MagicMirror is on 192.168.0.48 then you go to <code>http://192.168.0.48:8448</code> <br /><br />
The Webinterface for MyTasklist will be loaded and you will be able to:</p>
<ul>
<li>choose language for the Webinterface</li>
<li>add tasks</li>
<li>complete tasks</li>
<li>delete tasks</li>
<li>edit tasks</li>
<li>move the order from tasks by drag-and-drop</li>
<li>filter on all, active or done tasks</li>
</ul>
<p dir="auto">All the updates are instantly published on your Mirror</p>
<p dir="auto">NOTE:<br />
With a touchscreen you’re able to check the checkboxes on the Mirror to complete the task. <br /><br />
All these changes are instantly published to the Webinterface</p>
<h2>Versions</h2>
<p dir="auto">v1.0.0  - Initial release<br />
v1.1.0  - Update Look &amp; Feel<br />
v1.1.1  - Change Webinterface port from 8123 to 8448<br />
v1.2.0  - Add possibility to edit the tasks in the Webinterface<br />
v1.2.1 - Update language selector didn’t work correct in Webinterface (always dutch after reload)</p>
]]></description><link>https://forum.magicmirror.builders/topic/20041/mmm-mytasklist</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 10:40:48 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20041.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Jan 2026 21:59:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-MyTasklist on Sat, 17 Jan 2026 20:22:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/getinthegames" aria-label="Profile: Getinthegames">@<bdi>Getinthegames</bdi></a><br />
Thank you, that was the reason for me to create this module, simplicity.<br />
I didn’t need all the extras, just a simple list.</p>
]]></description><link>https://forum.magicmirror.builders/post/129656</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129656</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Sat, 17 Jan 2026 20:22:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Sat, 17 Jan 2026 14:09:15 GMT]]></title><description><![CDATA[<p dir="auto">Seems like a case of CamelToe.</p>
<p dir="auto">I installed MyTaskList instead of MyTasklist.</p>
<p dir="auto">Works great now and love it. Simple for a family shared list.</p>
]]></description><link>https://forum.magicmirror.builders/post/129651</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129651</guid><dc:creator><![CDATA[Getinthegames]]></dc:creator><pubDate>Sat, 17 Jan 2026 14:09:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Sat, 17 Jan 2026 13:49:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
My bad. Case of CamelToe.</p>
<p dir="auto">Installed it in MMM-MyTaskList instead of MyTasklist</p>
<p dir="auto">Works fine now.</p>
]]></description><link>https://forum.magicmirror.builders/post/129650</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129650</guid><dc:creator><![CDATA[Getinthegames]]></dc:creator><pubDate>Sat, 17 Jan 2026 13:49:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Sat, 17 Jan 2026 13:42:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/getinthegames" aria-label="Profile: Getinthegames">@<bdi>Getinthegames</bdi></a> by default MagicMirror is at 8080<br />
Did you update the config.js? And to allow outside system connections?</p>
<p dir="auto">port:<br />
address:<br />
ipWhitelist:</p>
]]></description><link>https://forum.magicmirror.builders/post/129649</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129649</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 17 Jan 2026 13:42:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Sat, 17 Jan 2026 13:36:19 GMT]]></title><description><![CDATA[<p dir="auto">Maybe someone can help.<br />
I cannot seem to reach the web interface using <a href="http://localIP:8448" target="_blank" rel="noopener noreferrer nofollow ugc">http://localIP:8448</a>.</p>
<p dir="auto">I know I got it right because I connect to my RaspberryPi in VNC and SSH without issue, but when I put the IP:8448 i get a “Site Unreachable” error.</p>
<p dir="auto">I’m not running anything but Magic Mirror on the device.</p>
]]></description><link>https://forum.magicmirror.builders/post/129648</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129648</guid><dc:creator><![CDATA[Getinthegames]]></dc:creator><pubDate>Sat, 17 Jan 2026 13:36:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Wed, 14 Jan 2026 21:03:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meikelrix" aria-label="Profile: meikelrix">@<bdi>meikelrix</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/chrisfr1976" aria-label="Profile: chrisfr1976">@<bdi>chrisfr1976</bdi></a><br />
MMM-MyTasklist is updated to v1.2.1 with correct language support in the Webinterface</p>
]]></description><link>https://forum.magicmirror.builders/post/129611</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129611</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Wed, 14 Jan 2026 21:03:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Sun, 11 Jan 2026 10:05:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrisfr1976" aria-label="Profile: chrisfr1976">@<bdi>chrisfr1976</bdi></a> you can change line 214 in .public/script.js from</p>
<p dir="auto">lang = data.lang || “nl”;<br />
into<br />
lang = data.lang || “en”;</p>
<p dir="auto">This loads english for me as default now. Maybe that can be put into the config.js?</p>
]]></description><link>https://forum.magicmirror.builders/post/129537</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129537</guid><dc:creator><![CDATA[meikelrix]]></dc:creator><pubDate>Sun, 11 Jan 2026 10:05:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Fri, 09 Jan 2026 20:28:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrisfr1976" aria-label="Profile: chrisfr1976">@<bdi>chrisfr1976</bdi></a><br />
That was the reason for me to create this (Simple) module.<br />
Just this and nothing more.</p>
<p dir="auto">On my site, the language is saved in the tasks.json and reloaded when I reload the page. I have to check. I’m Currently in a short holliday, but if you can you can make an issue in github so I don’t forget. I come back to you.</p>
]]></description><link>https://forum.magicmirror.builders/post/129511</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129511</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Fri, 09 Jan 2026 20:28:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Fri, 09 Jan 2026 20:23:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> I love this module already due to its simplicity. One small issue: the web interface always jumps back to Netherlands on a reload. Maybe this can be saved in the json with the tasks. Or as an Option in the config.<br />
And on a phone display the text for edit and delete is quite wide. Maybe just symbols would be better.</p>
]]></description><link>https://forum.magicmirror.builders/post/129510</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129510</guid><dc:creator><![CDATA[chrisfr1976]]></dc:creator><pubDate>Fri, 09 Jan 2026 20:23:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Thu, 08 Jan 2026 20:41:24 GMT]]></title><description><![CDATA[<p dir="auto">I Just published v1.2.0<br />
This is an update with EDIT possibility in the Webinterface</p>
]]></description><link>https://forum.magicmirror.builders/post/129490</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129490</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Thu, 08 Jan 2026 20:41:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Thu, 08 Jan 2026 19:19:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a><br />
I know that is an option. The fast fix now is that I have changed the port to 8448</p>
]]></description><link>https://forum.magicmirror.builders/post/129486</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129486</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Thu, 08 Jan 2026 19:19:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Thu, 08 Jan 2026 18:52:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> said in <a href="/post/129481">MMM-MyTasklist</a>:</p>
<p dir="auto">Is there a tule for the Ports? Which I can use or not use?</p>
<p dir="auto">you could add a config param for the port so that everyone who collides with 8123 could choose another one without hacking the source code</p>
]]></description><link>https://forum.magicmirror.builders/post/129485</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129485</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Thu, 08 Jan 2026 18:52:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Thu, 08 Jan 2026 18:17:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> none that I know of.  Anything  8000 and above is ‘free’ of system requirements.</p>
]]></description><link>https://forum.magicmirror.builders/post/129483</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129483</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 08 Jan 2026 18:17:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Thu, 08 Jan 2026 17:54:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrisfr1976" aria-label="Profile: chrisfr1976">@<bdi>chrisfr1976</bdi></a><br />
Thank you 👍</p>
]]></description><link>https://forum.magicmirror.builders/post/129482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129482</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Thu, 08 Jan 2026 17:54:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Thu, 08 Jan 2026 20:41:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Oké, I didn’t know. Let me see in an hour.<br />
Is there a rule for the Ports? Which I can use or not use?</p>
]]></description><link>https://forum.magicmirror.builders/post/129481</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129481</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Thu, 08 Jan 2026 20:41:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Thu, 08 Jan 2026 17:48:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> you might consider changing the port number. HomeAssistant uses 8123<br />
so both on the same machine will collide</p>
]]></description><link>https://forum.magicmirror.builders/post/129480</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129480</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 08 Jan 2026 17:48:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyTasklist on Thu, 08 Jan 2026 17:13:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> Really nice and useful. Great job!</p>
]]></description><link>https://forum.magicmirror.builders/post/129479</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129479</guid><dc:creator><![CDATA[chrisfr1976]]></dc:creator><pubDate>Thu, 08 Jan 2026 17:13:10 GMT</pubDate></item></channel></rss>
